Results 1 to 2 of 2
    Pinball Wizard
    Shortening chain on Hollowpoint -- where is the chainstay length the longest?
    Hi,
    Well, I swapped the bigring for a bashring on my 2k4 Hollowpoint Expert and have not yet shortened the chain. I was hoping someone might be able to tell me the best method for shortening it, or where in the travel the chainstay length is the longest (full extension vs. full compression, or somewhere in between). Thanks.
    Cheers,
    Colin
    death is a star.
    On MTBR hiatus :(
    If you haven't done it already, you can partly deflate your rear shock and then compress the suspension, watching for where the derailleur "bends in" the greatest amount. Likewise, you can tie a piece of string around your BB spindle, zip-tie it to the QR or QR nut, and look for where in the suspension cycle you get max string tautness (everywhere else it will have slack).
    As for chain sizing, for a 2x9 type setup I'd still use the Shimano/SRAM recommended "big-big" method, but since you'll actually be running in your big-ring big-cog (unlike a 3x9), I would add an extra link or two to let off your rear derailleur just a bit.
    SRAM & Shimano "Big-Big" chain sizing method:
    <img src="http://gallery.consumerreview.com/webcrossing/images/chainlength(1).jpg">
    Long cage derailleur at Max extension on a typical big-big setup:
    <img src="http://gallery.consumerreview.com/webcrossing/images/bigbig.jpg">
  1. What do you use to lock up your bike?
    By LavaPunk in forum General Discussion
    Last Post: 02-06-2005, 01:20 AM
  2. Good info on bike locks.
    By 2melow in forum General Discussion
    Last Post: 02-06-2005, 01:02 AM
  3. Optimal chain length?
    By moxfyre in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-06-2004, 10:21 AM
  4. Paging Kman: Fuel 100 chain length??
    By CODMAN in forum Weight Weenies
    Last Post: 05-10-2004, 01:07 PM
  5. Calculating chain length for a SS conversion
    By od_the_roadie in forum Singlespeed
    Last Post: 04-02-2004, 03:58 PM
