Results 1 to 3 of 3
    Reputation: tkbiker's Avatar
    Replaced '07 mkiii rear tri on an '06 mkiii
    I thought I was immune to the broken mkiii plague but found out in July that the rear cracked in the same place much like others but I also had this in addition which was located on the left seat stay. Still a mystery since I never felt any drag when riding.
    I had to resort to riding my old hardtail cdale with 60mm front travel since then until today! Damn do I miss the squish! Thanks to KevinB for the great deal on the rear triangle. I had the LBS powdercoat and install it. Used all the links, hardware, and rockers from the '07. I took it for a little spin this afternoon with my sons and it feels just like before; great!
    The mkiii lives on....
    Quote Originally Posted by tkbiker View Post
    Your LBS did a great job on powder coating that triangle I sent you!
    Thanks for posting!
    Edit: Did you end up needing any of the other hardware I sent along?
    Kevin, yeah everything that you sent was used. Thanks again!
