Results 1 to 2 of 2
    New question here. ProPedal on a Hollowpoint?
    would upgrading to a ProPedal or SPV type rear shock be beneficial on a hollowpoint frame? or does the dw-link already address this issue sufficiently?
    i thought someone posted about experimenting with a fox propedal unit on their HP (speed-ub?) but there was a problem due to the high leverage ratio of the linkage.
    i ask this question since i'm considering upgrading my rear float ava r to platform style shock.
    On MTBR hiatus :(
    Between the Pro Pedal and the AVA, I didn't get along with the Fox shock, and much prefer my relatively low-tech Cane Creek AD-12.
    I'm convinced the dw-link likes -- maybe even <u><i>needs</i></u> -- a rising rate shock to squelch any bottom-out tendencies. Even in the smallest AVA setting, I couldn't stop the suspension from banging out a couple times a ride on just moderate terrain.
    As for the damping, conversations with Fox tech led me to believe that somewhat high 3.2:1 leverage ratio (5" links) combined with my 200+ pound weight was overpowering the maxed-out damper Pro-Pedal shim stack the shock had installed. Fox volunteered to specially modify the damping to an even higher "custom" level, but instead I experimented with the 4.5" links, then eventually switched back to the AD-12.
  1. Looking to improve Iron Horse Hollowpoint...
    By sircrashalot in forum Shocks and Suspension
    Last Post: 08-10-2004, 07:33 AM
  2. comparison of ProPedal, Float and ALPS on same frame
    By ccm in forum Shocks and Suspension
    Last Post: 06-15-2004, 08:37 AM
  3. Vanilla coil - Propedal or Push?
    By keen in forum Shocks and Suspension
    Last Post: 05-17-2004, 11:12 AM
  4. Update, 2002 FSR with a new ProPedal rear shock
    By OldSchool in forum Specialized
    Last Post: 04-30-2004, 09:50 AM
  5. Replies: 1
    Last Post: 04-05-2004, 09:41 PM
