Results 1 to 2 of 2
    mkiii shock mounting?
    I have a 2007 mkiii that has the shock mounted "upside-down" from the factory compared to most bikes including the older and newer models, does anybody know if it can be flipped over like normal? I think it would help prevent oil from coming out of the air valve when I adjust the shock pressure.
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    totally normal. You can mount them either way, won't effect performance.
    Oil comes out of the valve either way, this is normal.
