Results 1 to 6 of 6
    Looking for MKIII rear triangle
    Can anyone direct me toward a rear triangle for my MKIII?
    I'm not ready to give up on this frame yet! Any help is much appreciated!
    26 for life.
    Reputation: KiwiJohn's Avatar
    Feb 2007
    I just got mine welded. Not a big job for someone that knows there stuff.
    Reputation: ride the biscuit's Avatar
    yo, ill make a separate post, but i am about to part out my 2008 MKIII
    the only thing wrong with it is a TINY crack in the rear triangle, so if you are comfortable getting it welded, it would suit you just fine and be pretty damn cheap
    the only reason i didnt go that route is that i was really starting to want to hit bigger jumps and ride outside the bike's design spec and would be really likely to break it again
    Reputation: hado_pv's Avatar
    I've got one (06?) hanging in the garage. It has very tight tire clearance, was replaced under warranty when a 1.95 Nevegal wore a hole in the brace between chain-stay and seat-stay. Yours if you send me 10 bucks for shipping.
    PM me if you want it.
    http://facebook.com/CharlemontTrails
    NEMBA Past President...
    fiind a rear triangle? Im selling my welded one. It held up great. it is a green rear triangle from a 2008.
    my front is white and just had a white triangle welded up.
    to see the green triangle http://forums.mtbr.com/showthread.ph...29#post7479129
    Oct 2012
    Iron Horse MKIII rear swingarm factory new
    Hello. I have three factory new Iron Horse MKIII with bearings and hanger dropouts. Check out my eBay ads under Iron Horse. All three are matte black finish. You can also call Castle Hill Bike Shop at 718-597-2089 of The Bronx.
