    Nov 2006
    headset for my 6point
    i am rebuilding my spare 6point bike and i wanted to get a new headset for it. i dont have a press or anything to remove the old cups. can i just buy an integrated headset and just put the bearings inside the existing cups from the old zerostack headset?
    Nov 2006
    So does anyone have any info or advise on this matter? I want to buy a new headset soon but not sure which way i should go.
    Nov 2006
    no one knows?
    Dec 2005
    nothing special to the headset. You need a zero stack, somethings referred to as semi-integrated. An integrated HS will not work as they are just bearings that go right into the frame.
    Don't have the model number on hand but pretty much any Zero Stack for 44mm will work. Cane Creek seems to be very popular. I would recommend a sealed bearing unit rather than loose ball bearings.
    Good luck.
