Results 1 to 6 of 6
    Pinball Wizard
    Changing rear travel on Hollowpoint -- 'rotate' rear shock?
    Hi,
    I just picked up a Hollowpoint this weekend and want to change the rear travel setting. To use the 4.5"-travel setting, I realize I need to flip the shock over so the adj. knobs clear the linkage. I've tried to read up on some of the great post here, and someone mentioned keeping on end of the shock bolted in place and then just 'rotating' the free/'linkage' end around. Is this so? Or no? I'm leaning towards no, but thought I'd ask.
    Colin
    death is a star.
    Let air out of shock. Unbolt the shock and the shock shuttle on the linkage end. Rotate the shock cyclinder (an allen key or similar inserted into shock hole will give you some leverage). Reattach shock with the shuttle flipped.
    Worked for me, thanks to the advice of people here.
    Steve
    Reputation: gmaki's Avatar
    Yep just rotate it. Looks like this when done..
    Apr 2005
    Is this the 4.5" setting? See picture
    I'm new to this frame and am wondering what setting I'm on. Mine is in the top holes(unlike the picture)
    Industry Loudmouth
    Reputation: ska todd's Avatar
    Jan 2003
    Top = 3.75"
    Lower = 4.5"
    -ska todd
    Apr 2005
    Quote Originally Posted by ska todd
    Top = 3.75"
    Lower = 4.5"
    -ska todd
    Thanks Ska Todd!
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. Replies: 45
    Last Post: 10-12-2004, 12:04 PM
  4. Anyone has a Talas rear shock travel adjust that does not work?
    By BanzaiRider in forum Shocks and Suspension
    Last Post: 04-20-2004, 09:34 AM
