Page 30 of 34 FirstFirst ... 20 26 27 28 29 30 31 32 33 34 LastLast
Results 726 to 750 of 827
  1. #726
    When in doubt, go faster
    Reputation: =ChrisB='s Avatar
    You can do 203mm.
  2. #727
    Reputation: norcobryce's Avatar
    so i have someone buying my aniki, and i got a new bike a Norco Shore 2, they are selling so fast here, now there are no more for sale in westren canada for a while, i love this bike. i might miss my aniki...
  3. #728
    how much is that bike right there
  4. #729
    Quote Originally Posted by NikeDSK
    $3100 Canadian
  5. #730
    hey guys look at my new name lol
  6. #731
    dirt visionary
    Reputation: clockwork's Avatar
    Quote Originally Posted by norcobryce
    Thats the funniest thing I have heard all week . BTW I like the new bike better and I am sure you will like the horst pivot 4 bar over the single pivot of the aniki.
    Life should NOT be a journey to the grave with the intention of
    arriving safely in an attractive and well preserved body.
  7. #732
    Quote Originally Posted by scrublover
    I've never had mine come loose, and this is now the fourth bike/build it's been on.
    If you want absolute DH type chain security though, get a full on DH guide. There are several out there that let you still run two front rings.
    i just got mine and i installed it, but i have trouble running it through the first gear, second gear is no problem
  8. #733
    hey guys im looking for a new rear shock for my aniki 07, any price range would be fine.
    Can you guys help me find a good rear shock, thanks
  9. #734
    Te mortuo heres tibi sim?
    coil? air? new? used? shorter/longer to tweak travel and geometry?
    how much are you wanting to spend, max? that'll dictate what you can get more than anything else.
  10. #735
    i want coil, and i was looking at those new Rock Shox Vivid 5.1's
    im not as sure as the geometry of the shock is but I read ironhorse's specs on the 07 aniki and it says 8.75X2.5, but my shock seems different, it does say 400X2.85 on the coil.
  11. #736
    the stock size for the 07 shock is 8.75 x 2.5. the 400 number refers to the spring rate of the coil. so there you go. order up a vivid in that size, with that spring weight. or less/higher depending on how the stock 400# feels. too soft? go up a bit. so firm? go down a bit.
    the new RS stuff has the same hardware sizing (afaik) as the fox stuff, so you should be able to reuse the stuff off your stock shock.
  12. #737
    this is the shock im talking about
    http://www.gambacicli.com/images/cat...rock_Vivid.jpg
  13. #738
    hey, um, I looked and they dont have any size that is 8.75 X 2.5, is 8.75 X 2.75 close enough?
  14. #739
    that doesn't change anything i posted above. you still need to order the right size and spring rate. if you want to stick with the stock size and spring weight you have, then order it 8.75" x 2.5" with a 400# spring. if you get a vivid, you'll be able to reuse the hardware off your stock fox shock.
    it isn't rocket surgery...
  15. #740
    u mean rocket science, did u read my other post that say they dont have the 8.75X2.5, so I must custom order it right?
  16. #741
    rocket science + brain surgery = rocket scurgery. considering you made that post about the same time as my last reply, nope, i'd not read that.
    nope, they don't. so you either get a different shock that comes in that size, or you run the longer stroke. which shouldn't contact your frame at bottom out, considering it's the same frame as the ojiki, and it has that longer size as a stock shock without any bottom issues.
    granted, maybe not. try to see if a local shop has any shock in that longer stroke size you'd be able to throw on the frame to measure for bottom out/frame contact issues.
    or just buy a vivid and see ofr yourself if it fits. if it doesn't work, you'll likely be able to sell the vivid again very easily.
  17. #742
    I wear two thongs
    Reputation: Eric Hoefer's Avatar
    Using the 8.5X2.75 should work it will give the bike an extra inch of travel though. Look back through this thread rear shocks have been covered a bunch. Im pretty sure the Swinger 6 way I put on my bike is 8.5X2.75 the 8.5 is how long the shock is eye to eye and the 2.75 is how long the shocks stroke is (how far the piston goes into the shock) and these measurements are all in inches.
    Hiking is just walking where its okay to pee... Sometimes old people go hiking by accident. -Demetri Martin-
  18. #743
    thanks bro, is ur air dhx 8.75X2.75?
  19. #744
    nope. to confuse the issue more, i'm running a 8.5 x 2.5 shock. lowered the bb height, slackened the head angle a bit, tightened up the back end a bit, and gives me ~ 6.4" of travel - all stuff i wanted with this bike.
  20. #745
    IM just going to order the manitou vivid 5.1 with 8.75X2.75
  21. #746
    bros, my bolt off my rear shox is almost slipping
    where do i get another mounting bolt for it
  22. #747
    I just read all 30 pages of this and I feel the need to contribute after doing so........... I JUST BOUGHT AN ANIKI!!!
  23. #748
    Oct 2007
    What are some good forks to check into for upgrading from the spinners? Any help is appreciated. Thanks
  24. #749
    whats your price range?
  25. #750
    Oct 2007
    $300 or below would be good, if possible. It is not a huge issue though.
