Results 1 to 3 of 3
    Angled headset for Iron Horse MkIII, which one to get?
    Hi!
    Been thinking about getting an angled headset for my 09 MkIII, but how do I know which one will fit? Where can I find the dimensions of the headtube?
    Been looking at getting one from Works Components.
    It's a 44mm internal headset, and you can just use a tape measure to find your length. I would email them and ask them which one to get, just in case. I was thinking about getting the -1.5 Works Components headset for my MKIII, looks like it would be fun.
    Thanks, 44mm is what I suspected since the outer diameter is roughly 50mm. I measure the height to 125mm.
    They offer a semi integrated 1.5 degree headset with internal bottom cup and external top, so it will build a bit higher than the stock headset, but right now there are a couple of shims there that I can remove, so it doesn't matter.
    I think -1.5 degrees will put the geo spot on! I will be running a 150mm travel Marz 44 Micro Ti fork with approximately 14mm higher A-C than the stock 33 fork, that slackens out the HA by about 0.7 degrees already, so I guess I should end up around 67 degrees. The angled set will also lower my BB and steepen the seat angle slightly to compensate a little for the A-C rise.
  1. Iron Horse mkIII 05-06 Set up.
    By tkojames in forum All Mountain
    Last Post: 02-22-2011, 09:20 PM
  2. Iron Horse Mkiii???
    By BIGME in forum Clydesdales/Tall Riders
    Last Post: 08-28-2007, 01:04 PM
  3. FXR, XCT or Iron Horse MKIII
    By Mastersonics in forum Foes
    Last Post: 06-29-2007, 05:51 AM
