Results 1 to 3 of 3
    Dec 2008
    6 point 8 frame headtube size
    Hey,
    Does anyone know off the top of their head what the headtube size is for a 6 point 8 frame?
    Is it the 44mm zerostack headtube or a true 1.5 headtube?
    If it is the 44mm headtube, does anyone know how far they machined down the 44mm inside diameter? I plan on using a nukeproof 44mm headset w/ two external cups to run a 1.5" fork in the frame. I think the cups need 15-20mm of space to be pressed in.
    Thanks much,
    Jonathan
    Reputation: Gman086's Avatar
    44mm and cups are 10mm deep. 6 Point has such a steep HTA tho I would look at Works angle sets for 1 1/8 steerer if I were you.
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    Dec 2008
    Going to be running a nukeproof headset that runs a 1.5 headtube w/ 44mm external cups. I think they need 14.8mm of depth into the headtube. I guess if the headtube only has it milled down to 10mm, I will run the headset cups through a lathe to get the correct depth.
  1. 04 bullit headtube size?
    By synkronized23 in forum Santa Cruz
    Last Post: 09-24-2007, 03:29 AM
  2. Lefty/headtube size
    By SpinWheelz in forum Cannondale
    Last Post: 09-16-2004, 03:37 PM
