Results 1 to 6 of 6
    Reputation: sikkfreerider's Avatar
    Nov 2006
    2008 MkIII making creaking noise! help
    Well my MK hasn't broke the rear triangle after about 2 1/2 years of riding so i think i should be good on that hopefully.
    The problem I'm having is a creaking noise when I pedal hard. I'm pretty sure I tracked it down the the lower rear linkage of the dw link. So I think the sound just kind of resonates through the frame making that annoying creak sound on every stroke of the crank. The bearings had a little bit of play so I'm hoping that is the problem. I greased the bolt and put everything back together and i've did this about 3 times. The bike is good for a ride or 2 then the creaking comes back. I'm sure i should just replace all the bearings but i just ordered those 2 bottom bearings so well see if this fixes my problem.
    Some people said it could be caused from the cracked triangle but I inspected it and no crack.
    Any other mkIII's had this problem or fixed it some how?
    I had a similar problem, and was completely annoyed by it. It's something you may need to get used to because otherwise it may need some serious input. For me, the noise comes from the lower link when it moves on the long bolt(well, the thingy with two little bolts in it) in the rear triangle. At first, tightening the little allen bolts helped, but i think the lower link, since it's made of aluminum, simply wears out a tiny bit, becomes ovalized and begins moving around. Your option is either live with it, regularly checking the bolts (old problem, many reported them becoming loose over time, some loctite works for me) or getting a steel insert pressed into the existing hole. A steel insert should take care of the problem, though
    break that ironhorse, he he...
    I've had similar problems on my old IH Hollowpoint. Replacing the bearings, or in some cases, simply overhauling them (replace old grease with new grease) would often help.
    If the creaking is due to some slop or play between the pivot axle and the other surfaces, you could try using a retaining compound.
    Mar 2011
    Anyone have the specs (size, type, etc) on the cartridge bearings for an 08 IH MKIII? Thanks.
    Mar 2011
    thanks.
    Quote Originally Posted by Inuitbiker View Post
    kapusta posted the MkIII bearing specs here.
    Note too that Enduro Fork Seals sells Iron Horse bearing kits.
  1. Flatline rear making creaking noise.
    By Hangingchads in forum Rocky Mountain
    Last Post: 12-04-2010, 11:37 AM
  2. Help! 2008 Pitch making a weird noise
    By e1eveN in forum Specialized
    Last Post: 09-19-2009, 04:15 AM
  3. Rear coil making creaking noise?
    By CountryBoy in forum Downhill - Freeride
    Last Post: 07-25-2008, 02:30 PM
  4. My seat making creaking noise
    By mrpercussive in forum Beginner's Corner
    Last Post: 09-14-2006, 11:56 AM
