Results 1 to 5 of 5
    2008 azure rear wheel clearance.
    Did the rear wheel clearance change on the 2008 models versus previous models? Would a crossmark 2.1 fit without rubbing?
    I have WTB weirwolf 2.1 on my 2008 AZURE and they dont rub.
    Is the weirwolf 2.1 a true 2.1 tire?
    hi wraydp
    my wife has a 2006 IH Azure.....she was running a Hutchinson Spider Air Light
    26x2.0 on the rear.....she wanted to try a different tire, so i put on a Kenda
    Nevegal DTC 26x2.1......both tires clear without rubbing.........we are currently
    riding in the Southwest/dry trails......
    Jan 2009
    In reply to OP - i usually run a 2.1 crossmark. clearance is tight at the front but fine for the type of trails you would use a crossmark on. When it gets wet a crossmark doesn't pick up much mud so it still fits fine, just not the tyre for those conditions. Look 2.0 or smaller for wet riding.
