Results 1 to 3 of 3
    May 2010
    2007 6 point frame - mounting hardware
    I have a 2007 6. frame, just bought 8.75x2.75 DHX 5.0 Coil to put on it. What is the mounting hardware size I should be looking at ?
    btw: anyone any idea if the geometry of the rear triangle between 6 point frames from 07', 08', and 09' is any different ?
    You need 10x30x1/2'' reducers. 10 inside, 30 length, 1/2 external diameter See Universalcycles they have them for like $15. You need 2 kits.
    May 2010
    awesome, thanks for info.
