Results 1 to 3 of 3
    2006 warrior ds rattling suspension
    I have a warrior that has been a great bike. The only issue I have had is the rear shock has a really bad knock. I have replaced the bushings that go in the shock and the spacers that go over the pins through the shock and it is still just as bad. I think the pins themselves are worn out. Does anyone know how to order the bolts that hold it together or another solution to the problem?
    Reputation: Uncle Jemima's Avatar
    You are going to need to do alot of things, minor things, to get a tight-feeling suspension again.
    Check for wear of the mounting tabs on the frame. Likely, due to neglect, there will be compression-wear. The energy this loose-shock had had to go somewhere, and it wore half-moon compressions into these frame tabs.
    Check your SwingArm (back-half) shock mount also for this same pattern.
    If wear is present, clean off with a small, fine handfile any raised material -- that's it. Don't cut-down the surface until it is smooth ! You will never get the two to meet.
    If what you are calling 'pins', they are only shock mounting hardware/bolts, are suffering from another type of compression wear, they will have to be replaced. But, provided there are no surface-related interfaces (beveled Bolts, tapered sides) you may get the same bolt, with the same amount of thread/non-thread in the grip-length. Any competent Hardware Store should be able to get you nearly the same size and a matching teflon Nut.
    What is holding your shock in place is the binding of these parts between the swingarm & frame mounts. With the potential for wear on these, get your exact replacement rubber bushings that are on the spacers you said you replaced, and double them; only if you have wear however. Otherwise you will bind the ability of the Shock to rotate as it travels.
    You could find machine-washers to fill this gap, but the Spacer-Bushings are more readily availible.
    If this vauge play on the rear suspension does not go away, and you tried thin metal washers, your frame is run-out and would either have to be filled w/ weld, and smoothed (a weak-link due all the load) or 'faced' with alot of good intentions and a handful of washers to factor into how much material is taken away.
    Any of these options is going to be a patch on an old suit, so I'd save for a new frame or bike and take all the preventative care to it.
    Best advice if you get a DW-Link Bike -- lower Link bearings will ride much better if you manually rotate them about a quarter-turn after a good ride. As they do not have the typical workload of a Bearing, only allowing the links to move from a fixed point to a fixed point on an Axis, they will develope wear-patterns. I'll do this after a ride. Repeating this process will put all the inner and outer bearing races into use, and provide a better dynamic-usage even if you have to interfere with hand-tools.
    Same problem -- what bushings?
    Quote Originally Posted by runctrack View Post
    I'm having the same problem with the same bike -- my LBS said the whole bushing set needs to be replaced (both the shock and the bottom piece too) but I'm not exactly sure what pieces I need to order. The LBS said they can't order them and I'm trying to figure out where I order them from, or at least the specs on what I need to order. (My self-repair skills are fairly limited.)
    Where did you get the replacement parts / what did you order?
  1. 2006 IronHorse Warrior Expert
    By sportnmud in forum Bike and Frame discussion
    Last Post: 07-01-2006, 12:44 PM
  2. 2006 warrior pro
    By glacierangel in forum Bike and Frame discussion
    Last Post: 05-26-2006, 08:07 AM
  3. What do you all think of the 2006 Warrior Trail DS?
    By Contriver in forum Bike and Frame discussion
    Last Post: 03-30-2006, 09:01 PM
