Go Back   Mtbr Forums > Mountain Bike Manufacturer Forums > Iron Horse
Reply
LinkBack Thread Tools Display Modes
Old 10-16-2010   #1
Tater Like'um Bike Ridez!
Ullrite's Avatar
Rep: Ullrite is on a distinguished road
user gallery
New question here. 2005 7point frame/shock questions
Building a 2005 7Point frame, and understand there may be some limitations to what rear shock the frame will take. Is there anywhere I can find a list of shocks that will work? After searching around I gather that the 2005s have a different linkage than the following years. They made a different link to accommodate DHXs, ROCOs, Vivids etc. supposedly... Can this linkage still be found to buy/whatever now that IH has gone under?
Also, any suggestions for a coil spring weight for a 175lb rider? Don't plan on getting a platform shock, looking to maximize the DW link plushness... probably a Vanilla or Vivid...
__________________
[SIZE=4]SEEK THE GNARL, LEST IT FIND YOU FIRST.[/SIZE]
Ullrite is offline   Reply With Quote
Old 10-18-2010   #2
Rep: Mk3Rider is on a distinguished road
user gallery
I run a vivid on my 05 7 point and a vanilla R on my 08 7 point.
I like the vanilla R better. I am 200# or so and run a 400# spring on one bike and a 350# spring on the other. You will ned around a 300# to 350# spring depending on how much sag you want.
Check out bikewagon.com for a cheap vanilla R ($130) You will need 8x30mm mounting hardware for the shock that can be found at universal or jenson.
Hardware: Need M8x30mm
http://www.universalcycles.com/shopp...s.php?id=19939
Mk3Rider is online now   Reply With Quote
Old 02-01-2012   #3
Rep: drinkhit is on a distinguished road
user gallery
a normal 8.75 x 2.75 shock on a 2005 7 point? What do you need to do to get this done?
drinkhit is offline   Reply With Quote
Old 02-01-2012   #4
user gallery
Mounting hardware for the 05 7 point should be 8mm x 30mm. That year of 7 point used an 8mm dowel pin for mounting up the shock.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Hot Deals
Latest Mountain Bike Articles
Latest Lights Shootout Articles
Press and News Articles
Interbike - Virtual Trade Show Booths
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Search Engine Friendly URLs by vBSEO 3.6.0
