Results 1 to 3 of 3
    Tires
    Reputation: Gritter's Avatar
    Dec 2010
    What are these 3 black pieces for the Alfine 11? And where do they go?
    Does anyone know what these three black pieces are in this picture, and where they go? Is the smaller one a dust cap for the non-drive side?
    Soma, Surly, Salsa, Schwalbe, SRAM, Sun-Ringlé
    Reputation: itsdoable's Avatar
    http://techdocs.shimano.com/media/te...9830799961.pdf
    Chain guard (big ring, goes between the hub and cog)
    Rotor Spacer (small ring - for use with a disc brake)
    Rotor Mount cover (tall one - covers the rotor spline when not used)
    Tires
    Dec 2010
    Quote Originally Posted by itsdoable View Post
    Thank you, itsoable.
    I plan on running a 6-bolt adapter and I'm wondering if I need to use the "Rotor Spacer" or is that only for use with "Center-Lock" rotors?
    I removed my cog and installed the inner "Chain Guard", looks much better and streamlined. Thanks for you help!
