Results 1 to 18 of 18
    What spokes for IGH?
    Rohloff states in their website
    Lacing a SPEEDHUB with extra thick 2.3mm spokes is not permitted. Doing so may well result in hub shell warranty loss.
    How about Shimano's Nexus and Alfine 8-speed hubs?
    Should one not use Sapim's strong or DT Swiss Alpine spokes? They are single-butted, 2.3 mm at the hub and 2 mm at the nipple.
    Did you use Sapim strong or DT Swiss Alpine spokes for Nexus/Alfine 8-speed hubs?
    I can highly recommend the sapim polyax nipples - with the large flange diameter of an alfine hub I had excessive angles at the rim & was breaking spokes at the start of the thread & polyax nipples have eliminated that failure.
    I use Sapim race so can't comment from experience on the Sapim strong or DT alpine spokes.
    Anything I have learnt is from Roger Musson's book and he has this to say about the Sapim strong & DT Alpine
    Oversized spoke elbows are not a cure for spoke breakages, good building technique solves spoke breakages, nor do they give the wheel added strength. With today's higher grade of steel, the standard double butted spoke is more than strong enough for all wheels and consequently I have never used these oversized spokes. If you decide to use these large diameters spokes then make sure they pass through the spoke holes in your hub
    turtles make me hot
    Reputation: NYrr496's Avatar
    I built a couple of Alfines to Marge Lites with DT Swiss Champion spokes. They built up fine.
    I like turtles
    What was the spoke-crossing?
    Quote Originally Posted by find_bruce View Post
    Quote Originally Posted by anga View Post
    3 x
    Shimano recommends 2 x
    Steve at SRLPE is just finishing an Alfine 8/WTB i23 build for me. It has prompted a similar discussion in the Wheels and Tires forum:
    Effect of spoke crossing number on spoke angles Effect of rim spoke hole and nipple seat drilling angles with large flange hubs
    Steve (4slomo on MTBR) has finished my wheel. Here is a photo and Steve's usual detail-oriented wheel-build report.
    Got a link? I have not found any shimano recommendation either way. [edit]for the Alfine 11, Shimano recommends 3x or 4x lacing, but not radial[/edit]
    BTW in checking I noticed shimano use 2.3 1.8 2.3 spokes in their wheel but this has a different hub case to mine (fewer spokes & a couple of other differences)
    I noted some comments for a wheel-build but not the sources. IIRC, it was from a Shimano source. Couldn't find it on google either!! But several sources weighed towards 2-cross lacing for larger hubs. Some argue for 3-cross lacing.
    Sapim states http://www.sapim.be/sites/default/files/checklist.pdf
    For extra large hub flanges like Nexus, Elan etc., which have a greater risk of spoke/nipple mis-alignment, you should cross 2.
    Dec 2012
    I utilise Sapim CX-Rays with my Rohloff build.
    I was going to go with Alpines but there was availability issues at the time.
    Just as well as I found out later that using a 2.3mm spoke voids the Rohloff warranty and is expressly forbidden.
    Glad I coughed up for the Rays.
    Reputation: thasingletrackmastah's Avatar
    Due to the increased diameter of the hub flanges and PCD of the Rohloff SPEEDHUB 500/14, the spokes need cross only two times but do so at roughly the same angle as a three cross lacing pattern on smaller flanged hubs.
    Alfine hubs are about the same size (and so are your rim and spokes).
    I used 2x lacing in my 29" MTB, no problem. that was Alfine 8, DT Comp and brass nipples, Mavic TN719 rim.
    Belgian beer and Scotch whisky.
    Reputation: Andy R's Avatar
    Nov 2008
    If it's any help to you I built a wheel with an Alfine 8 hub, Sun Ringle EQ27 rim and DT Swiss 2.0/1.8mm spokes about three years ago - I laced that 3X, it's had plenty of hard use and never given any trouble.
    I know some people recommend 2X on these hubs, and maybe that's how I should have built it, but I built up a second one about 18 months ago the same spec. as the first and that's been trouble free to date too. It's not had anywhere near the use of the first one though.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    Quote Originally Posted by Andy R View Post
    ...I know some people recommend 2X on these hubs, and maybe that's how I should have built it....
    Yes, it's very obvious by the angle of the nipple, take a look at your nipples and report back.
    If you know better and are building new, why would anyone build 3x?
    Nov 2008
    Quote Originally Posted by pursuiter View Post
    Actually I don't "know better" ( I did say "maybe", BTW), I was simply saying what I did - and if I built one wheel, and used it pretty hard with no trouble for over a year and a half then, when I had need of another, why not build another identical one? I'm certainly not the only wheel builder to build Alfine hubs 3X - there's another one just above, for example. Seems like that guy knows what he's doing too?
    Frt Range, CO
    ...Seems like that guy knows what he's doing too?
    I've built thousands of wheels including wheels for RAAM winners and Olympic team members. I'd never build up an Alfine 3x because it's not optimal and the right configuration cost the same as the wrong one.
    Nov 2008
    Well, when I regularly start breaking spokes at the nipple I'll rebuild them 2X. In the meantime we'll carry on as we are.
    I'm not after every time I post on this forum it ending up as some sort of confrontation, it surely wouldn't in "real life" - we'd just chat about it over a beer.
    This internet forum stuff just dehumanises people - there's an answer to that, of course....
  1. 32 spokes VS 36 spokes - Big Difference?
    By 4nbstd in forum Clydesdales/Tall Riders
    Last Post: 01-02-2018, 01:41 AM
  2. Replies: 9
    Last Post: 04-10-2013, 08:35 AM
  3. Replies: 6
    Last Post: 10-04-2012, 12:54 PM
  4. Titanium spokes vs stainess steel spokes
    By ayjay69 in forum Weight Weenies
    Last Post: 02-11-2012, 08:26 PM
  5. Spokes
    By GOONRock in forum Downhill - Freeride
    Last Post: 02-13-2011, 11:21 AM
