Results 1 to 9 of 9
    A Surly Maverick
    Reputation: Dr Feelygood !'s Avatar
    What chains are you using with your Alfine ?
    Is it better to use a single speed chain or a BMX 1/2 link chain.
    Or is it ok to stay with a 9 speed `normal` chain?
    Thanks,
    Dr FG
    Life IS a Beach and then you Corrode
    I ran a 9spd chain and it worked OK for a while, but I ended up breaking it multiple times in one ride on some high torque, low cadence efforts - switched to a cheap KMC single speed chain and I've not had any problems since. YMMV.
    dru
    dru is offline
    Sram pg 830. I don't know if I trust the 9 spd stuff.
    Drew
    occasional cyclist
    Frt Range, CO
    Reputation: pursuiter's Avatar
    KMC 510 6 speed chain for me.
    Master of None
    Reputation: presslab's Avatar
    I use the Shimano CN-HG93 (9-speed) chain and I have no problems. I'm about 215 lbs geared up and I do like to ride it like a singlespeed sometimes: stand and mash.
    Music & Bikes
    Reputation: fokof's Avatar
    I use 8 speed chains , stronger than 9 and lighter than SS chains.
    "There is a big difference between kneeling down and bending over" -FZ
    Old, stale, negative
    Reputation: bstrick's Avatar
    KMC 710 SL.....= Me happy!
    A Surly Maverick
    Thanks for the advice all
    I went for this one in the end, Wippermann Anti-Rust Star 1Z1 Single Speed :- http://www.chainreactioncycles.com/M...?ModelID=11284
    I do alot of beach biking so the antirust was a plus !
    Aug 2005
    KMC Z610 for me. It's a bit heavy if you care about that sort of thing, and it's sometimes hard to get into a smaller chain tool. I had to hammer it into mine the first time which spread the tool a bit and now can put it into place by hand. It's a bit hard to find, but is a 3/32" chain unlike a lot of the other heavy duty KMC chains. With cheater links too.
