Results 1 to 6 of 6
    Dec 2010
    Two Years With the Rohloff
    I've had my Rohloff for two years. Counting my Tour Divide attempt, training, and other random rides I probably have 5000 miles on it.
    There is no question that it is a quality piece of equipment. I have bought a lot of bikes and bike parts over the last ten years but this is the first thing I have bought that improves the more you use it. After two years it runs better and smoother than when I first bought it and, after doing a routine oil change yesterday after swapping it to my gravel bike (see my other thread), I may have to revise some of my earlier criticisms.
    Truly I have reached some point where the thing has seated, broken in, or whatever and it is so smooth now that I hardly know it's there.
    And it is absolutely reliable and has required no maintenance of any kind. I probably didn't need to change the oil but I did it to do it. I have no leaks, the old oil looked pretty clean, and I took out about what I put in the last time.
    The shifter cables still work perfectly, as well, although I haven't touched them in two years.
    Since I run an eight-speed chain on a Surly chain ring and Hope bottom bracket the rest of my drivetrain is pretty robust, too.
    Reputation: ladljon's Avatar
    I have two Rohloffs, one 9yrs old. haven't done anything but change oil and turn cog around to wear teeth the other way, and of course new chains when needed.
    Tread killer....
    Haha, young pups!! Mine is 19, spews most of it's oil on the bootroom floor every year when I change it and has never missed a beat. The start of some sketchy shifting means it's time for new inner/outer cables every few years. Fantastic bit of kit and worth every penny, lord knows how much it's saved me over the years.
    Music & Bikes
    Reputation: fokof's Avatar
    Same here
    The first one I got is now 16 years old , shifts better than the 3 others, and it's still going strong !!
    I change the oil every year , even if I don't have to , changed chains , cable 1 or 2 times , that's it.
    Same here : The amount of money I saved running this over 16 years has probably paid the unit twice. (I paid 900$)
    Only love !
    "There is a big difference between kneeling down and bending over" -FZ
    Dec 2010
    The Rohloff is a pretty cool conversation starter. They are not that common and a lot of cyclists are pretty interested in them.
    I've even been accused several times of having a motor. The shifter cables going into the external gearbox apparently look suspiciously like wires.
    The knowledgeable questions are almost always about weight and drag. The weight is obvious and people are a little put out when they lift the rear of the bike off of the ground. I don't know what to say about drag. I think I still notice some in the low gears but in the top seven gears (the money gears) I don't notice a thing.
    Sep 2018
    Hi. Thinking about get an the hub for my ebike.
    Can anybody comment on the chain tension.
    I am also considering the ETR-B tensioner.
    Anbody have any experience with a similar setup?
  1. 1 Rohloff, 3 Bikes, which one gets the Rohloff?
    By Jason Rides Bikes in forum Internal Gear Hubs
    Last Post: 08-15-2018, 11:26 PM
  2. Replies: 5
    Last Post: 05-01-2012, 12:16 AM
  3. Replies: 9
    Last Post: 04-07-2012, 11:21 AM
  4. Two Days....Two Rides....Two Vids
    By Jaydude in forum Colorado - Front Range
    Last Post: 03-08-2011, 05:37 PM
  5. Replies: 4
    Last Post: 03-08-2011, 11:25 AM
Members who have read this thread: 35
