Results 1 to 6 of 6
    Reputation: bighit's Avatar
    Sturmey Archer shifter compatibility?
    i have a X RD8 rear hub and it comes with some ugly gripshift. does anyone know if there is any triggers shifters or thumb shifters that will index correctly with it. i didnt even call them because i am sure they will say there is none.
    2013 mongoose Fat bike
    2012 Moonlander.
    http://undergroundvelo.proboards.com/
    Do you have an XRD8 (2002-2008) or an XRD8(W) (2009- )?
    The only factory shifter is the TSS82.
    Jtek makes a bar end shifter for drop bars. I've used one for the last two years and the shifter and the hub [an XRK8(W)] are great.
    Thats the stock shifter I have, and it dosent fit the build well.
    I have a new hub I bought this year. I will check the numbers. I was hoping there was a SRAM or shimano that would index.
    2012 Moonlander.
    Jan 2009
    Quote Originally Posted by john_dalhart View Post
    Thanks for the tip.
    Just emailed jtek and they are also working on a thumb shifter version of the XRK8(W)... currently under test.
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
    Sturmey-Archer 8 spd: 34.5mm total cable pull in seven even steps
    Shimano 8 spd: 39mm total cable pull in seven even steps
    SRAM iM9: 79.5mm total cable pull in eight even steps
    Rohloff: 96.2mm total cable pull in thirteen even steps
    SRAM P5: 34mm total cable pull in four even steps
    Sturmey-Archer AW family: 1->2, 7.4mm; 2->3, 11.2mm
    Sturmey-Archer RSRF3 hub: 1->2, 8.6mm; 2->3, 15.0mm
    Feb 2013
    Hi John,
    do you have the cable pull for 3-speed-hubs, too. I have got a SRAM I-Motion 3 hub, but wanted to use thumbies, for examaple the nice Sturmey Archers SLS30 T3.
    What do they mean by "classic ratio"?
    Thank you
    Best regards from Germany
    Rainer
