Results 1 to 9 of 9
    Oct 2011
    Sturmey Archer RS-RF3 Does it exist?
    The S.A. web page shows it, but does such a rotary shift three speed exist in the wild?
    I'm holding one in my hand.
    jd
    Oct 2011
    And where did you find that one?
    I got mine (retail) from biketoolsetc about six months ago.
    Any USA/NA bike shop should be able to get one (wholesale) through United Bicycle Supply.
    jd
    Oct 2011
    Thanks John, my Google searches have turned up nothing, and my lbs seems unaware of it's existance.
    Mine is in queue for a project build and I'm frustrated that hasn't happened yet. Anyway, for those who are unfamiliar with this hub, on paper it should be the cat's pyjamas among three speeds. The std Sturmey pull chain arrangement has been replaced in this model by a rotary cam, with the shift actuation inside the dropouts. The shift cable is simple to attach/remove with no unthreading/readjusting of anything. The R-SRF3 has a solid axle not weakened by any internal passageways or cut outs, and the axle nut threads are 3/8" like Shimano rather than 13/32" like other S.A. hubs. Otherwise, it continues with Sturmey goodness: the beautiful polished hub shell, NIG, comes in the box with all the nuts, washers, cable, shifter, cog, etc you need to put it in service, &etc.
    jd
    Note: The cable pull requirements to shift the R-SRF3 are greater than the classic AW family of hubs, and it uses a different (factory) shifter. Mine came with a dual paddle 'push-push' (RapidFire style) straight bar shifter.
    Oct 2011
    John, would you know if the hub housing on those two 3 speed hubs is interchangeable?
    Quote Originally Posted by talljako View Post
    I do not know. They look the same outside, and the computer drawing in the Sturmey catalog make them look the same on the inside.
    jd
    Oct 2011
    Wow, nice photo. This is helpful to me because my current project with the SRF looks like it won't leave a lot of clearance (fat aluminum frame, external shift cable, big feet). My thought was that I might be able to swap guts on my already built wheel, however this photo shows that a much greater dish would be required.
    I plan to now run the cable up the seat stay and see how that works.
    Thanks once again John!
