Results 1 to 7 of 7
    Dec 2010
    Sturmey Archer CS-RK3, 3x9 IGH
    Anybody ever try/saw this for offroad use? is it good for cross country riding?
    well, the internal gear is 3 speed, it imitates triple crankset, and you can use 8/9 speed cassette on it, so consider it's a 3x9 (yeah not, 27 speed IGH).
    Sturmey Archer
    CS-RK3
    Specs
    Speed 3 x 8/9 Speed
    Type - Freewheel
    Hub Shell Material - 6061 Aluminum
    Axle Diameter - 13/32 Slotted
    Axle Length - 179mm
    Over Locknut Dimension - 135mm
    Right Axle Protrusion Length - 22mm
    Left Axle Protrusion Length - 22mm
    Spoke Holes - 36
    Pitch Circle Diameter - 67mm
    Center to Flange Right - 21.4mm
    Center to Flange Left - 35.4mm
    Flange Width - 53mm
    Spoke Compatibility - 13g or 14g
    Cassette Sprocket Type - 8/9 Speed
    Max Sprocket - 34T
    Min. Sprocket - 11T
    Chain Line: 45mm
    Indicator Chain - HSA716 Mark 8
    Weight - 1155g
    Gear Ratio
    Overall Range - 177%
    Gear 1 - 75% (-)25%
    Gear 2 - 100% Direct Drive (Gear 1 + 33%)
    Gear 3 - 133% (+)33.3% (Gear 2 + 33%)
    Ride da mOOn Moderator
    Reputation: NEPMTBA's Avatar
    Thought about it but SA stuff is usually really heavy...
    ...did I figure right, that baby is 4 pounds?
    What's the cost on that unit?
    Sep 2012
    I've been thinking about giving that hub a go on my Trek Marlin, but with single cog in back (for excellent chainline adjust ment) with a barend shifter on a Paul Thumbie for the 3 speeds. Can't actually find anyone who has ever used the hub though. The way it is marketed by SA would suggest it's durable enough (ie 3x9 replacement), and you can't beat the sub $125 price I've seen them on ebay.
    Dec 2010
    it's 2.54 pounds and it's cheaper also lighter than alfine maybe it's beacuse only 3 speed internally, but with RD and cassette it must be the same (or maybe heavier?)
    Sep 2012
    Adjitridika, don't think, just buy, install then ride, and deal with the risks later. :-)
    Ok thanks...
    ...I seem to remember these being 3x7s back a while ago and I wondered why they never caught on. Now with 3x9 more usable than ever.
    Guys please keep us updated on your success.
    Cheesiest
    Reputation: intheways's Avatar
    I had one on my commuter for a while, but it was really draggy. It probably would have broken in, but I got a SRAM Dual Drive instead. I never tried it offroad, but it was much smoother than the SA. I think heavy pedaling would beat up the gears.
