Results 1 to 7 of 7
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    strumey archer 3 speed
    I was wondering what the length of the hub is on the strumey archer system
    "If women don't find handsome , they should at least find you handy."-Red Green
    My other ride is your mom
    Reputation: Maadjurguer's Avatar
    Which strumey archer? I have an older one on my Batavus which I could measure for you....but not sure which year/model/whatever you are looking for....
    <object width="425" height="344">
    <embed src="http://www.youtube.com/v/2927iGT5nvM&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></object>
    I had a similar question to the OP. I'm wondering if Sturmey Archer makes a 3 spd coaster brake hub that will fit BMX (110mm) hub spacing? Its a little hard to tell on their website. Does teh "over the locknut" measurement indicate the hub spacing?
    Quote Originally Posted by bolandjd
    it probably will, if its steel, it can flex a few mm or am i wrong
    The narrowest OLD available on a factory Sturmey 3-speed is 107mm which will fit ancient utility and children's bikes. The widest is 163mm, designed for fat tire cruiser/low rider bikes.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    The old vintage SA 3 speed coaster and rim brake hubs are all ~110mm OLD.
    Thanks. Do you know which model has the 107mm OLD?
