Results 1 to 7 of 7
    Sprocket availability for Alfine
    I am just about to buy my Alfine unit, am I right in thinking that they do not come with a sprocket and if this is true, I have calculated that an 18T would suit me just fine.
    Where are they available from as I see a lot of 20T sprockets, I am assuming that the sprocket is special to the Alfine unit. Cheers, I am UK based.
    Reputation: eric_syd's Avatar
    Mine came stock with a 18T
    Quote Originally Posted by EFMax
    It is special to the Alfine but you should either get it upfront or buy it here:
    http://www.jensonusa.com/store/produ...ette+Cogs.aspx
    or here
    http://sheldonbrown.com/harris/sturm...html#sprockets
    or even here in the UK:
    http://www.sjscycles.co.uk/product-S...Gears-2825.htm
    Big Thank You...
    Just ordered it plus the 6 bolt to centre lock adaptor... from your UK recommendation..
    Just need to find someone selling the Nexus Twist shift.. any pointers appreciated..
    They're common IGH cogs, actually. My LBS even has a bin full of old steel Sturmey Archer/Shimano cogs and snap rings, all identical to the new Alfine stuff.
    Reputation: komekomegaijin's Avatar
    Nov 2008
    Schmucker, do you know if the Sturmey Archer cogs have the same amount of dish as the Alfine cogs? I've been wondering If I could adjust at the rear...
    Reputation: coastkid71's Avatar
    Big Thank You...
    theres a nexus twist shift on UK ebay, just search `alfine`
    plan it...build it....ride it...love it....
    http://coastkid.blogspot.com/
    They looked like they had the same dish. They did look thicker, however. Probably 1/8 cogs.
