Results 1 to 5 of 5
    Spoke length with Nexus 8-speed hub SG-8R36
    Hello:
    At final stage of converting bike to IGH as specified above.
    Stuck at calculating spoke length.
    Wheel rim is by Rigida (no model info is available, )---several measurements give ERD (from base of spoke/nipple to opposite) of 532mm. Plugging in data Spocalc and also #1 Wheel Building SPOKE CALCULATOR Now Online | PROWHEELBUILDER
    gives spoke lengths of 223.8mm and 223.1mm
    This seems on the low side.
    Why?
    2*spoke length + flange diameter of hub = 224 + 224 + 93 = 541mm -- only 9mm more than ERD of 532mm.
    This does not take into account the spoke length inside the rim and the fact that the spoke is angled wrt the plane of the wheel.
    Appreciate suggestions.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by anga View Post
    Hello:
    Why?
    How many crosses?
    mtbtires.com
    1-cross
    Dec 1998
    1-cross
    That explains it. 1X is nearly radial.
    But why use 1X? It is terrible for torque transfer. The hub is not large enough to require lacing it that way. Should still be able to use 3X.
    mtbtires.com
    Even with radial lacing, the spoke lengths seem to be short.
    How deep do the spokes go inside the surface of the rim?
  1. Nexus hub SG-8R36: dimensions?
    By anga in forum Internal Gear Hubs
    Last Post: 10-21-2011, 01:03 PM
  2. Shimano Nexus 3 speed on Flow 36H spoke length?
    By dblspeed in forum 29er Bikes
    Last Post: 09-07-2011, 11:42 AM
  3. Alfine 8 Speed - Spoke Length how to
    By mtb101 in forum Internal Gear Hubs
    Last Post: 06-17-2011, 07:06 PM
  4. Nexus 4 speed
    By jjsinglespeed in forum Internal Gear Hubs
    Last Post: 01-03-2011, 08:26 AM
  5. nexus 7 speed hub ???
    By stan4bikes in forum Vintage, Retro, Classic
    Last Post: 01-03-2008, 10:32 PM
