Results 1 to 11 of 11
    blet drive
    Reputation: JUNGLEKID5's Avatar
    Cool-blue Rhythm shimano nexus hub
    SO how long has your igh lasted you ? I am going on 5 mounths and it is not working very well. it makes lots of grumpy noises and if you back pedal it thunks and grinds , you can feel it in your feet. Any thoughts?
    hear is my bike.
    Civia Cycles
    Save a tree & wipe your butt with an owl.
    Thank your local Sierra Club.
    blet drive
    has any one run this hub
    Music & Bikes
    Reputation: fokof's Avatar
    It's not a Nexus but an Alfine
    I had a previous generation Nexus , lasted a year before it died.
    The newer one have better seals like the Alfine.
    If you take care , it should last long.
    "There is a big difference between kneeling down and bending over" -FZ
    blet drive
    so more or less i got screwed
    Music & Bikes
    Frt Range, CO
    Reputation: pursuiter's Avatar
    Quote Originally Posted by JUNGLEKID5 View Post
    Your hub's cones need to be adjusted and correctly counter-locked. Try finding an LBS that has a clue or learn to DIY. You'll need a 15mm and 17mm cone wrench.
    blet drive
    cool thanks will talk to the lbs and see whats up. thanks again...
    It has been an up and down road with the alfine 11spd for me. Bought one of the first models produced and it ran nicely for a couple of months but then started leaking oil. To/Fro with shimano, new seals etc before they finally agreed that there was an issue with the initial run and completely replaced the internals. Since then it has been bulletproof. Wickedly good for winter commuting...A mate has a later version and he has not had the same issues I faced.He raves about it...
    blet drive
    cool so there could be hope
    blet drive
    wahoo shimano sent me new internals.
    Frt Range, CO
    When the hub is on the bike it should spin freely with no play. Don't let them tell you it needs to be tight until it breaks in.
