Page 1 of 2 12 LastLast
Results 1 to 100 of 131
    Blanco
    Shimano Nexus 8 "Red Band" gearhub: review thread
    First Impressions: Technical Data and Installation Issues
    If you just want to know what it's like to ride one, skip forward to the next message. I'll update this thread as I get more riding time, so keep checking back.
    I just got my 29" rigid bike set up with a Shimano Nexus 8 "Red Band" gearhub, SG-8R25-VS, with no rollerbrake. This is the premium level gearhub that is purportedly rated for off-road use: it is distinguishable from the regular version only by a small red band next to the drive side hub flange. GT uses this hub for an internal transmission on their iT1.
    Sheldon Brown's website (http://www.sheldonbrown.com/harris/shimano-nexus.html) has a lot of good information about this hub, and makes good background reading. However, it is out of date in a couple respects, which I'll note throughout the review.
    Claimed weight is 1550g. The bike shop scale showed 1590g without the rear sprocket or axle nuts, but with the rear axle. It only comes in 36H. There is a black version available in Europe, but I was unable to get anything but silver here in the USA.
    The 305% gear range is roughly equivalent to a 1x9 with an 11-34 cassette. Sheldon's website claims only a twist shifter is available: this is wrong. You can also get a two-button shifter/brake lever: each thumb button moves one gear up or down at a time. There is no independent button shifter, so if you want to run hydros you'll need to run the twist shifter. The shifters are not compatible with anything else: SRAM ESP 8-speed shifters pull just about the right total amount of cable, but the Nexus shifter has exactly equal cable pull between gears and derailleur shifters don't.
    Installation is tricky, especially if you or your shop hasn't done it before. The hub is 130mm OLD, so to use it on a standard 135mm MTB frame you'll have to add spacing washers, or do a funky trick with the non-turn washers. "What are non-turn washers?" you ask. They're little metal bits that sit in the dropouts and keep the axle from spinning. Shimano provides three pairs of them for different angles of slotted horizontal dropouts, but if you have vertical dropouts, you'll need to order the appropriate pair separately.
    And then comes the funky bit. The approved method of assembly is for the non-turn washers to go on the outside of the dropouts. Well, if you don't have or don't want to find spacing washers, you can use two of the same washer (instead of one R and one L) and flip one so it goes inside the dropouts, then dish the wheel slightly to keep it centered. I think you have to do it this way, with the hub slightly offset to the non-drive side, if you want to run a rear disc brake -- but I can't yet verify this.
    This took about a week for the local bike shop to figure out. But finally it was done, and I had a rigid 29er with an internal gearhub.
    My bike now weighs between 2 and 2.5 pounds more than it did as a singlespeed: bathroom scale weights aren't exact, even if they are the nice doctor's kind with the sliding weights. This is less than a pound heavier than going 1x9 with LX.
    Now you might say "The Nexus doesn't allow a disc brake, just those crappy Rollerbrakes that weigh three pounds, make it impossible to fix flats, and don't actually stop." Not quite. You can get a disc adapter here: http://shop.cnc-bike.de/catalog/prod...roducts_id=988, and possibly from Cannondale, who make one for this bike: http://gb.cannondale.com/bikes/06/ce/model-6BR1.html
    But I am running V-brakes right now and have not tested either of these.
    Next installment: I ride it.
    Reputation: dhpimp's Avatar
    I also have this exact hub and LOVE it. I can't say enough great things about internal gears. The shifting is fast, effortless and quiet (except in 5th gear where it changes to the 2nd clutch mechanism - but that's normal). I've been riding one for about 18 months solid and haven't had to touch it at all for any sort of adjustment. It is recommended to service it once every 6 months (intense use) but I opened it up after 1 year and it still looked normal. What awesome sealing for year round commuter bike use!
    Quote Originally Posted by El Caballo
    [B]I just got my 29" rigid bike set up with a Shimano Nexus 8 "Red Band" gearhub, SG-8R25-VS, with no rollerbrake. This is the premium level gearhub that is purportedly rated for off-road use: it is distinguishable from the regular version only by a small red band next to the drive side hub flange. GT uses this hub for an internal transmission on their iT1.
    A little correction here - this hub is NOT designed for offroad use on the rear of the bike. The only reason GT is allowed to use it is because it is mounted inside the frame of the bike and does not put torsional loads on the axle (where the gear change is made). If you use this on an MTB offroad then your probably going to scrap the internals after a short period of time of riding.
    Shimano's got a DISC Brake verison of this hub coming out next year, but again it's only for commuter use
    On MTBR hiatus :(
    Looking forward to your next installment. I've got a Nexus 8 on a street bike and like it for what it is, and have heard good things about the Red Band.
    Personally I'm holding out for Sram's upcoming i-motion 9 with a 340% gear range. However, it's at least a few months from release, and I'm very curious about your experiences with your install.
    speedub.nate
    ∑ MTBR Hiatus UFN ∑
    Blanco
    First Ride Report
    But first, a couple more tech notes.
    Wheel removal is easy if you don't have the Rollerbrake. First you disconnect the shifter cable. Shift into first gear (no riding required!) and get down near the rear wheel. You'll see the rotating collar that pulls the cable. Push it back down and around with your thumb, putting slack in the cable, and then pull the little nut out of the slot. There's a trick to it but it's hard to describe: once you figure it out it's very easy. Then you loosen the axle nuts, just like with any singlespeed. Remember that the non-turn washers aren't solidly attached to the hub, so they might migrate a bit, and you'll have to push them back into place before it'll go back into the dropouts.
    The chainline is slightly adjustable because the cogs (it comes with 18T and 21T, I think) are dished. Flip them over for several mm of adjustment.
    OK, first riding impressions.
    Shifting is uncanny. You feel the cable pulling and then you're instantly in gear, as if by magic. No grinding, no noise, no delay, and it happens as fast as you can push the button. If you're really cranking hard on the pedals while you shift, it won't grind or crunch, it'll just not shift until you let up the pressure some.
    Sometimes the 4 -> 5 transition requires more lever effort than the other shifts, but it's not a problem, just something you notice. Also, it seems like the freewheel makes more noise in some gears than others. It's not loud, and I don't notice at all unless I'm listening for it.
    Freewheel engagement is the same as every other mountain or road hub I've owned. I feel 32 clicks.
    The big complaint I hear about gearhubs is that they're less efficient. Some people claim clearly perceptible drag, particularly on cheaper hubs with lots of gears (like the Shimano 7-speed) or new Rohloffs that haven't broken in yet. I think I have a decent basis for comparison, since the bike is rigid, and was a singlespeed before I added the gearhub.
    I was really looking for drag. Well, I put it in 1:1 (5th gear) and couldn't decide if it felt any different from before, or whether I was just thinking what I expected to find. I rowed up and down through the gears, trying to figure out if there was extra effort involved with some of them versus others. I'm still doing it, and all I can say is that if there is a loss of efficiency, it's subtle enough that I can't clearly pin it down.
    This jibes with the article in issue #52 of "Human Power" magazine (put out by the IHPVA), which shows the results of exhaustive efficiency testing on several gearhubs and a standard Ultegra drivetrain. The article was written in 2001.
    http://www.ihpva.org/pubs/HP52.pdf
    They showed the Shimano 4, Shimano 7, Sachs 7, and Rohloff 14 to all be within half a percent of each other, and 2%-2.5% less efficient than an Ultegra drivetrain. Since the Nexus 8 is claimed to be substantially more efficient than the Nexus 7 (described by one as "pedaling through oatmeal"), and the "Red Band" is supposedly even better, I can easily believe that the efficiency is comparable to a derailleur-based drivetrain, if not superior under less than ideal circumstances.
    Anyway, I don't find drag to be an issue.
    Next installment: I ride it on trails.
    I also just set up my bike with the red strip hub this weekend. I put it on my cross check commuter. I'm glad there is a thread on this hub as there is hardly any info about it anywhere.
    My first impressions: installation was a little confusing to me. I've never worked with an internal hub of any kind, so I was immediately confused by the installation of the cog. The directions show the cog already on the hub, and then to install the dust cap. What they don't show is that there is a split ring that holds the cog firmly in place, so at first I couldn't figure out why my cog had play in it. It's probably common knowledge to use the split ring though. ONce I figured that out, the rest was easy.
    I had to buy the hub-bub adaptor ($54.00!!!) in order to use the twist shifter with my on-one midge bars. It's a little funky having the extra length in the drops on one side. I do not want to cut the bar shorter because the shifter indicator takes up a lot of real estate in the drops and it would hit my hand. It works fine, but I think a flat bar would work better with this shifter.
    My first ride on it today was my 8 mile commute to work. Formerly my Cross Check was fixed gear/single speed, so it was a completely different experience having the gear range. I'm using the 19t cog and have 44t chainring up front. Shifting felt a little vague at times, like I would make the shift and there would be some hesitation before I felt it in the pedals, sometimes it took me by surprise. I read somewhere on line today that I may need to tension the shifter cable some--beyond the point where the yellow indicators line up.
    El Caballo -- I'm anxious to hear your impressions of this hub off road. Also, can you post your cog/chainring combo? I bought it with the idea in mind that I would use it on my SS karate monkey someday. I'm hearing conflicting reports on whether it is actually suitable for off road use though. [ dhpimp, can you confirm this hub is not suitable for offroad use]
    I'll also post my impressions with it as I get some more time on it.
    Blanco
    Trail Ride Report
    I took the bike out to my local singletrack, which takes anywhere between 45 to 90 minutes for my usual loop. It begins with a couple hundred feet of steep uphill grind, which I could never clear on a SS. Well, with the gearhub in "1" I scooted right up, only dismounting once where I lost traction in a bunch of loose, freshly cut dry grass. (I'm still running 30-18 on a 29er, so "1" is about 30-34, or about 32-34 on a 26er.)
    I head through some swoopy ups and downs, most smooth, some rooty. Actually I can pretty much spare you the details of the ride, because everything worked just like you'd hope. I push the button, it changes gear. Nothing made grinding noises, the chain didn't skip (even though it's a tensioner setup, not sliding dropouts), and the ride was free of mechanicals. It felt like a singlespeed, except without as much suffering.
    However, I have to say that I really, really don't like the Nexus "3-finger" brake levers, which are designed for ham-fisted use on comfort bikes. I want my two-finger levers back, but that's not an option unless I use the twist shifter. (The pushbutton shifter is integrated with the brake lever.) I can make them work if I carefully adjust the brakes so the lever doesn't hit my other fingers when I squeeze it, but it's still not what I want.
    So far, here are the good and bad points.
    + No drivetrain issues. Feels like a singlespeed but with gears
    + I'll say it again: no issues. No dropped chains, no bent hangers, no bashing derailleurs on rocks, nearly impervious to mud
    + Excellent, well-protected shifter cable routing will never snag on anything. No click box, Speedbone, or anything external required
    + Over a pound lighter than a Rohloff or the upcoming SRAM iMotion 9
    + Gear range equivalent to 1x9 (11-34)
    + No obvious drag issues, unlike some other gearhubs
    + Maintenance. I think once a year I'm supposed to squirt some grease in there.
    - Disc brakes require expensive, hard to find adaptor
    - No separate button shifter. Brake levers on integrated button shifter aren't designed for mountain biking
    - Weighs more than 1x9. Gearhubs not the best solution for suspension bikes because of unsprung weight, but this is the lightest solution out there
    - Why doesn't it come with the non-turn washers for vertical dropouts?
    ? Durability. No one really knows how it'll hold up to trail riding. I'll try to find out.
    Blanco
    Second Ride Report
    I jammed a couple laps around Demo Forest, which involves some fast, moderately bouncy trails, quite a few log crossings, and -- yes -- I took it off some sweet jumps, including about seven times off the 2.5 footer before the photos finally came out. I'm also working on my urban, and finally cleared the double stage curb to 3 steps up that I could never quite get before. So I'm not making any attempt to be nice to this thing.
    I'm debating going to the 21T rear, which would let me sit down more on steep climbs, but at that point it's usually faster to walk anyway.
    If anyone thinks of any way to get a real trigger shifter on this thing, speak up. (I want to disassemble a SRAM ESP trigger someday and see if there's a way to modify it to work...if you have a spare 8 or 9 speed 1:1 pull trigger shifter for cheap, PM me.)
    At this point I don't have a lot to add. I'll let people know if anything breaks or needs maintenance, but other than that, you can assume I'm out riding.
    So far, I'm glad I made the switch.
    On MTBR hiatus :(
    How about pictures?
    speedub.nate
    ∑ MTBR Hiatus UFN ∑
    LTS
    LTS is offline
    Second Ride Report
    You don't need to mess around with modified derailleur triggers. Your wish will be fullfilled when the Shimano Alfine group is released.
    picture: alfine rapidfire
    Blanco
    Quote Originally Posted by LTS
    Thank you for the news! I guess I can suffer until then.
    The Alfine looks pretty much exactly like the Nexus 8...at least the cassette joint, axle, hub shell, and non-turn washers look identical. Maybe that means the disc adapter is the same and we can order it through Shimano...? Let's hope so.
    Differences I can see: the cassette cog has a chainguide around it, and it's clearly drilled for less than 36 holes (maybe 24-28).
    Another neat trick of a fully broken in Nexus 8, is the 4 pawl freewheel likes to make the occaisional little slip, same as most tandem hubs. This is quite alarming, although unharmful. Also, it takes a very long time (about 500 miles) to break in gears #4 and #8. Once they're broken in, riding at very high speeds in #8 is great fun.
    In fact, the efficiency in the top several gears is simply stunning! This is best seen when the cog, chainwheel, and chainline are all perfectly straight.
    It is greatly helpful not to locate the gap in the cog's circlip directly onto a spline gap. Instead, center the gap of the circlip directly between the spline gaps (under the ridge/lip). You'll see.
    Now, press all around the circlip with a screwdriver to make sure it is all nicely even.
    For either single speed or for gearhub use, one should use evenly numbered gears for high efficiency. I've used 20 against 46 for flat country or 20 against 42 for rolling hills (that was a 26" bike--reduce chainring or increase cog by 2t for a 700c bike).
    24 against 42 is necessary for mountains on the 26" bike or 24 against 40 for mountains on the 700c bike.
    However, at this point, it is probably wise to install a "dingle" adapter ($65 simplified rear derailleur) and a smallish front crankset with no more than a 20t difference between highest and lowest. Perhaps a "compact double" would be of great benefit.
    A dual-chainring setup is unnecessary for all but mountain dwellers. It is possible to get a lovely low gear, that is lower than a typical road bike, road "triple" setup while still able to run along at 24 mph should the desire arise.
    And the gear range of the Nexus 8 is so very easy to change with just one front chainring or just one rear cog.
    The inexpensive $11 Rocket multi-fit chainring is highly efficient as a mate to the Nexus 8 because there are no tooth effects for shifting. Anything from the BMX sport also works.
    The high-efficiency setup for the Nexus 8 will use a 7 speed chain. The Shimano HG 70 is perfect for this task.
    Yes, it looks like a tight fit, but it isn't a tight fit at all because the chain always runs in a straight line. That HG70 is a very efficient mate for the Nexus cog.
    To fit vertical drops despite a possible mismatch, you can use chainrings/cogs with just 1t more or less, or if you are serious about avoiding odd-tooth gearing, KMC has a 7/8 speed chain compatible half-link for about $5. There's one on my bike.
    The chain does not go extremely tight. When you apply crank pressure, you should see a very slight droop.
    The easy way to get the cable out to change a tire is to shift to first gear and then pull the cable jacket right out of the rear cable attachment. This will slack the cable enough to easily remove the little metal bolt from its plastic hanger with no risk of damage to the hanger or your thumb.
    The Nexus 8 has been approved by Shimano for mountain bike and off-road use.
    The revo+brake combination and the trigger+brake combination shifters are both more accurate than the revo-only shifter. This isn't bothersome in practice, but I'd really suggest using the more accurate shifters for competition use.
    Cassoulet forever !
    Reputation: 20.100 FR's Avatar
    Do you think a 2 rings front - nexus rear would be interesting fot a MTB ?
    The need for a tensionner would bring the same weight as a derailleur, so the whole thing might be on the heavy side...
    Frenchspeaking 29"ers community site http://VingtNeuf.org
    Actually, the "dingle" idea was a very bad idea--unless you've already invested in a Nexus system and you're getting:
    1: "Stuck" going up hills
    or
    2: No high gears
    If you're living in a mountain area, just avoid the Nexus alltogether.
    $980 isn't too high a price to pay for the high performance Rohloff that wins competetions frequently, has low gears and has high gears.
    If you're in a mountain area and on a budget, still continue to avoid the Nexus because a traditional system will serve you better. Check out the SX5, 8 speed cassette, PC58 (strongest chain available), SX5 shifters from SRAM along with an inexpensive Deore derailleur. This all costs much less than a Nexus and will seriously outperform it.
    Although, it will not put you ahead in competition like the Rohloff gearhub.
    Blanco
    I don't think gearhubs are a smart idea with rear suspension, because they add so much unsprung weight -- and you need a chain tensioner anyway, so most of the benefit is lost. Same with any setup that involves gears + a gearhub.
    The point of a gearhub, to me, is that I feel that quiet, direct drivetrain like I'm riding a singlespeed, and I don't have to maintain a complicated bunch of shifters and gears -- except that when I get to the brutal climbs I don't suffer.
    Yes, Rohloffs are cooler and have a larger gear range. But they cost $1000 vs. $170 for the Shimano, weigh a pound more, and don't fit on all frames.
    Maybe I'll blow mine up or it'll start skipping and my opinion will change. But for now, I'm just riding it and waiting for the Alfine trigger shifters to appear.
    Blanco
    Pictures!
    Here are some pictures.
    Still to do: clean up cable routing (right now it's just full housing zip-tied to the frame).
    Baby Bear is in the house
    Reputation: r1Gel's Avatar
    El Caballo - - - Nexus price?
    Great thread, very informative
    You mentioned lower down you got the Nexus hub for $170. Do you know of any e-tailers selling at this price? Harris Cyclery has it at $200. I'm assuming your price is for the hub only; no brakes or shifters, right?
    I'm seriously considering converting my rigid mtb to Nexus...
    Better to have and not need it, than to need it and not have it.
    danielhaden, some questions for you
    Quote Originally Posted by danielhaden
    Without getting too technical, would you please explain why this is so?
    Why would that be better than a dedicated single-speed chain, say a SRAM PC-1? Wouldn't a 1sp chain fit better and be more durable?
    Why do you think this is so? Does this mean you've tried all the shifter types for the Nexus 8? When you say "more accurate" does that mean the revo-only shifter has a tendency to mis-shift? Which do you prefer between the push-button and Revo shifter?
    Pardon my questions. I'm researching on everything I could on the Nexus components as I plan to convert my rigid mtb to internal gearing.
    Blanco
    Quote Originally Posted by rigel
    Yes, $170 is just the hub itself. Since Harris is so expensive, I just had my LBS do it.
    This will cost about $170 for the hub, $30 for spokes, $25-40 depending on what shifter you get, plus tax and wheelbuilding labor. My bike came with 36 hole rims, but if yours aren't, you'll need to buy a rim too. Add another few bucks for the non-turn washers, and probably a new chain.
    Plan on about $300 if you build it all yourself, $400 if you have a shop do everything.
    I'm using a KMC singlespeed chain. I don't know why a 7-speed chain would be more efficient -- if anything, I figure you'd drop it more since it's designed to shift.
    rigel: let us know if you do it. We don't have good reliability data on this thing yet...we need a few out there on the trail to figure out whether it'll stand up to abuse.
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    Awesome thread El Caballo, great project!
    But it looks like your tension might still be improved upon for a couple bucks? I worked on the 10-quid On-One Otherdoofer yesterday, and it seems on par with but much more practical than the 50-bucks Rennen Rollenlager. It's worth to get a halftlink that fits your chain when buying one to improve tensioner position. A halflink might do a lot for your setup already?
    When a friend used a similar tensioner in simlar position to your's due to chain length, his chain would skip under the slightest loads, even with a Shimano DX cog. Tensioner pushing up makes a huge difference, even in drivetrain "feel". When yesterday I swapped gearing and corrected chain length on someone's SS road setup to make the Otherdoofer work as push-up, he immediately notice the improvement in "directness".
    Blanco
    Where to buy them
    http://www.aebike.com
    Search on "Nexus". They have all the parts, including the non-turn washers. Anyplace that has the QBP catalog online will work, but I think aebike is the cheapest.
    $140 for the hub (SG-8R25 Premium Hub)
    $10 for non-turn washers (unnecessary if you have SS or track dropouts)
    $16 for the revo shifter, or $37 for the tapfire brifter
    $53 for a "Quality Wheelhouse" wheel build
    (I don't know how well they will cope with something like this...let me know if you find out)
    $16 for a new chain
    $??? for a 36H rim
    Theoretical total: $245-$266 + rim + tax/shipping + your labor to install (but not build the wheel)
    Blanco
    Quote Originally Posted by Cloxxki
    You are correct: the On-One (or any other upward-pushing tensioner) is a better system if it fits your chainstays.
    Currently I'm just using the tensioner that came with the bike. Any less tension and it skips, but it's working fine for now. If it becomes a problem I'll upgrade to the On-One.
    That better be dust; not rust on your chain
    Your chain looks thirsty. Give it a good slathering of Pro Gold or Nashbar Dry Lube. Those lubes can even repel most dust. Don't let them touch your skin, I suspect they are neurotoxic or muscle toxic or do something to the joints.
    Bankrupt the terrorists: commute by bike.
    bike geek
    Reputation: tamjam's Avatar
    $16 for a new chain
    $??? for a 36H rim
    Don't hesitate to check with your LBS either. I had been researching on Sheldon Brown and was prepared to spend $300 for one of his pre-built wheels until I walked into my LBS to ask them about it. They ordered me the Red Band hub, which includes cogs and the non-turn washers, and built me the complete wheel (on a cheap Mavic Open Sport rim) for $235. They also ordered me the shifter, but I got the Hub Bub adapter from SB. So all-in I am into this over $300. I have gotten the everything installed on the bike yet, I just need to hook up the cable. This will be my geared commuter, old Della Santa road frame with forward-facing horizontal drops, 130mm spaced.
    Quote Originally Posted by steevo
    Steevo- Can you help me out here? The instructions that come with the hub are terrible. I first put the cog on, then snapped the dust cap in place, and had tons of play. Then I figured I wasn't getting the dust cap into the right place on the hub, so grabbed a flathead screwdriver and was able to get the little thing over another ridge, but my cog is still a tiny bit loose. Am I missing a part? I'm not sure I got this "split ring" you refer to with all the other bits. Does this go on between the cog and the dust cap?
    Thanks.
    Quote Originally Posted by tamjam
    Thanks.
    You do need the split ring. Cog first, split ring second then dust cap. I used a screw driver to open the slit ring enough to get it between the cog and that little ridge on the hub. Then the dust cap goes on. The directions completely leave the split ring out for some reason. Oh, i know the reason--Shimano.
    You did well for total cost. I had harris cyclery build mine and it ended up over $400. The hub was $200, i had them lace it to a DT Swiss TK7.1 which was about $73, then the cost of the wheel build, shifter and then $50 for the hubbub. That killed me, but I needed it for the midge bars.
    yesterday I tested my inbred with nexus 8 hub. This is my first ride. Instead of going off road.....my 4 yr old daughter wants to tag along. So I fix on a child seat + rack. My daughter is around 18-19kg.
    We rode about 10km....around the park....to the beach...ride on some uneven grass patch...tarmac + etc.......
    I would say NEXUS 8 is the perfect children friendly hub........
    no problem going up/down...20-30deg slope.....The best part...when you have to stop at some slopy area and you are on a higher gear.....you can easily switch to a lower gear.
    With a derailuer bike, this is a problem when you have a kid behind. It is not so easy to switch gear if you are stationary......
    Music & Bikes
    Reputation: fokof's Avatar
    Quote Originally Posted by ppyk
    That's the best part of gearhubs ( I have a Rolhoff )
    You know when your on a technical part and have to put your foot down , usualy with a derailleur , you'll have to spin the wheel to change speed or risk the chain, not with those.
    From speed #14 to speed #1 , while coasting........ whoooo hoooo......
    "There is a big difference between kneeling down and bending over" -FZ
    Belltown Brazer
    Reputation: MDEnvEngr's Avatar
    Nexus Disk Adapter
    All, I'm going ahead with the Nexus experiment on my 29er. I need the disk adapter though.
    I've been in contact with the CNC bikeshop in Germany to get a hold of one of these. It is possible, but it's a royal PIA to get one. The bike shop only takes wire transfer into their bank account. Who knows what government list I'll be on for wiring $$$ to Germany.
    Anyway, the part is 55 euro, shipping is 35 euro...making the whole business 90 euro...which is $116.
    Add to that a $35 wire transfer fee and you're got an expensive part here.
    The wire transfer fee won't change at all, and the shipping won't change much if I order 10 of these things verses 1.
    I'm thinking of doing just that, hoping that there will be an interest in these adapters, such that I could defray the cost of the adapter, and get them out to those that need one.
    I'm thinking that I would have to sell them for $100 each to make that happen. Yea, it is an expensive piece, but that is still much less than the $151 it would take to order one yourself...not to mention the hassle of the contact/wire transfer business, etc.
    Let me know either here or by PM if you would be interested. If there is enough interest, I'll get more than one.
    Thanks.
    Bob
    East Hampton, CT
    Blanco
    MD:
    Have you checked with Cannondale? They make a Nexus 8 disc adapter for their "Bad Boy Disc" model, and you might be able to order it as a separate part. I'd look into that first, as it's likely to be cheaper than dealing with the Germans.
    i don't give a shift
    Reputation: collideous's Avatar
    Thanks for the review. I think that's how I'm going to add gears to a current singlespeed so that my wife can ride it. Seen that Shimano is releasing a new group, the Alfine. It's designed for vertical drop-outs and comes with a nice chain tensioner.
    Did you try Harris Cyclery for the adapter?
    Oh, and did you try the better one of the two roller brakes?
    I'm sure there's not much weight difference between that and a disc brake.
    They're both waterproof, but the roller is modulated for a safe gravel downhill (not grabby) and a sealed away from an accident with the chain lube. Rocks won't bother the roller brake and the cooling fin equipped premium model does not overheat.
    Not sure which type of brake handle it requires, but I was thinking that it took a cyclocross brake lever rather than a mountain bike lever. The action is a bit different.
    Of course, the action between a modulated brake on the back and a grabby brake on the front could be a bit disturbing, but I'm sure you could even them out just by using whatever kind of front brake is known for a safe gravel downhill.
    Blanco
    Quote Originally Posted by collideous
    And a standalone trigger shifter!
    I'll bet you a donut that the Alfine hub is a Red Band 8 with a disc adapter and a chainguide around the sprocket.
    Maybe we'll be able to order the disc adapter as a replacement part?
    Blanco
    Another disc adapter!
    39 Euro! Hey MDEnvEngr -- do you read/speak German enough to figure out their overseas shipping rates?
    http://www.cesur.de/assets/s2dmain.h...=nexus&x=0&y=0
    They also sell several complete mountain bikes with the Nexus 8 and this adapter on them:
    viva la v-brakes!
    Reputation: FishMan473's Avatar
    Jan 2003
    I've been thinking of putting together a dedicated icebike/snow bike for the a while, and I'm figuring an internal geared hub is the way to go. What do y'all think are the possibilities of using this hub in sub-zero weather or wet snowy conditions right around freezing, and everywhere in between?
    I have a car. I made a choice. I ride my bike.
    Music & Bikes
    Quote Originally Posted by FishMan473
    For the last ten years , I am using internaly gear hubs to commute in winter time. Up here in Montreal , winter are very tough on a drive train.
    A Nexus hub lasts 2-3 winters on my bike. And I open it up twice a year.
    If you don't do city rides with calcium, and stuff alike , it's probably gonna last longer.
    I presently have a Rohloff on my main mountain bike , and I do Snowmobile trails in wintertime with it , and I can tell you that it's the perfect system for winter , with the right oil in it. Nexus is not as nearly effective and durable as the Rohloff , but is cheaper.
    One problem I always have with Nexus in winter are the cables/shifter that always jam-freezes.Ice get stock on the hub where shifting occurs and makes it tough to shift.
    I don't have that problem with the Rohloff because of the "gearbox" ( protected )
    viva la v-brakes!
    Jan 2003
    Quote Originally Posted by fokof
    Thanks for the feedback,
    I do a lot of winter commuting too, but this bike would be just for trails, or at least I would do my best to not expose it to salt. Still, I know how difficult winter conditions can be on a standard drivetrain, that's why I'm looking towards internal gearing.
    How is the Nexus hub different from the Rohloff so that the Rohloff doesn't freeze up but the Nexus does? Can you just use lock de-icer to solve this problem?
    When you say your hub only lasts 2-3 winters, are you talking about the standard Nexus hub, or the "red stripe"?
    Music & Bikes
    On the shimano , the "gear box" is exposed to external conditions. You put the cable around a fixed part , and a bolt at the end of the cable pushes and pull the gear system. All this is exposed. When snow stick there , and it has time to freeze up , then it's unshiftable...
    On certain days you would have to stop every Km to de-ice it , not practical.....
    When that happens to me , I put it in Single Speed mode
    On the Rohloff , the "gear box" is a closed system , not completly sealed , but it never failed on me.
    I always had the standard Nexus.
    But I would be very surprised if the Red stripe would last longer.It's still a exposed "gear box".
    I'll probably have to change the hub next winter on my commuter , maybe I'll give it a try , it's not way over price compare to the original one.....
    The Rohloff is way more expensive , but I used 4 Nexus and Sach hubs so far , at around $250 each , the Rohloff would have been paid for......
    According to Paul Lange Alfine uses Shimano's Center-Lock system for the disc. Very nice group, I'm certainly waiting until it's out.
    Other nice set of components is the new DXR BMX group. I'm pretty sure some singlespeeders will jump on this one, especially with cranks up to 180mm length.
    Blanco
    There is something called a "Wet Conditions Cassette Joint" for the Nexus hubs. I have no idea how it is different or what it does. Anyone seen one?
    Hi everyone,
    I've been through this whole experiment already so I can answer any questions.
    The wet-weather joint has a rubber boot to keep out some mud. You can see it in the manual, available on sheldon brown.
    I set this up on a specialized bighit, with the adapter from cesur. That adapter ended up costing me about $240 canadian - sick. I loved it for about 10 rides. It was awsome at whistler and the shore, but it died a quick death. Horrible grinding noises and jamming.
    I can't believe cesur is selling those big bikes with this hub, it is not up to the task. Also they have terrible cable routing with a huge kink where the cable inters the joint.
    Now I'm running Rohloff.
    Alfine would be very nice on a commuter.
    Woah!
    Does this finally legitimize Nexus 8 for off-road use?
    That orange bike is strange... it has a pretty expensive chain tensioner -- a Saint rear derailleur?
    LTS
    LTS is offline
    And why is the chain tensioner on the white bike hidden behind high grass?
    Quote Originally Posted by evrac
    Hi everyone,
    I'd like to know: Where has Shimano explicitly stated that the Nexus 8 Red stripe hub is suitable for off road use? I keep hearing contradictory things, and this thread is no exception. Clearly, in your experience it did not hold up to downhill type riding. Did you try to warranty the hub with Shimano? Do they claim it's more for dirt paths and not aggressive riding? It seems to me that if Shimano has claimed somewhere that the hub is suitable for off road use, they should stand behind it, or be very clear on what they consider off-road use.
    I've experiemented with the hub on my 29er for a few rides. It performed fine, but I wasn't beating the crap out of it either. I put it back on my cross bike for now, which only sees relative smooth dirt paths and single track, so I'm not worried about it holding up. But it would be nice to know the official word from Shimano. Manufacturers installing them on full sus bikes is not a validation of it's off road-worthiness in my opinion.
    Did you say kink or severe angle in the cable? OH NO!!
    Almost ANY angle in the cable of a Nexus 8 will kill the hub.
    So will operating it off-road without the trigger shifter.
    Whatever happened to the cable routing directions?
    For a full suspension bike, it needs several bits of clear hose barely bigger than the cable jacket, zip tied to the frame in several places. Put the cable through these. This allows for play. Please don't use a "kink" or "loop" to take up slack for a full suspension bike. Keep the cable in a nearly-straight line or say goodbye to the hub.
    One very large, very gentle bend to get the cable from the shifter to the frame (Down Tube), plus one more very large, very gentle bend to clear the bottom bracket is maximum tolerance on cable routing for the Nexus 8.
    The bike builder actually put in a kink? If they're in the U.S. then they are fully liable to buy you a new hub, because it was installed in a manner against the manufacturer's cautions. It is only $175 for the hub plus a wheel build, but small claims court might take care of that foolishness for half that price.
    Why would operating it offroad without a trigger shifter kill the hub?
    The $16 revo shifter plus Shimano Tourney quality cable isn't capable of the precision shifting necessary for constant under-load shifts. Every time it misses an under load shift from a performance athlete, some damage is done to the hub. This doesn't happen with the $16 shifter in city riding.
    That's why Shimano recommends the trigger shifter for performance applications. Its precision prevents damage to the hub.
    Where are you getting all these little tidbits of info about the Nexus hub set up and performance? Can you direct me to where Shimano recommends the trigger shifter for performance applications?
    I found no information anywhere (instruction manuals, Shimano website) regarding what shifters Shimano recommends for Nexus 8 offroad use.
    So far, from this thread I've learned that my Nexus 8 red stripe hub is:
    -suitable for offroad use
    -not suitable for offroad use
    -suitable for offroad use but not downhill or freeriding
    -suitable for offroad use but only with the trigger shifter (which isn't even available yet)
    -only suitable for all weather commuting if I buy a separate "wet conditions casette joint"
    Belltown Brazer
    I asked my favorite Cannondale shop girl to look into that for me, and Cannondale said they won't sell the part. So, I asked if if I hypothetically ran over my Big Bad Boy's rear wheel in the driveway, could I source an entire new wheel from you guys? She's looking into that. too late for me, as I already ahve the wheel, but might be good info for someone else.
    B
    El Caballo
    Thanks for the pics. I'm thinking of setting up my road bike first with the Nexus 8, try it out, then maybe the mtb.
    Do you have a picture of those tap-fire shifters? I'm thinking of ordering a pair but I've got to wrap them around the curve of bullhorn bars like one could with old style quill stems (by prying them open if necessary). I can't find a pic of them anywhere on the web although people do sell them.
    Hey, if you are interested in bypassing the chain tensioner, even on the vertical dropouts, check out this site -
    http://www.peak.org/~fixin/personal/fmu/php/index.php
    Belltown Brazer
    I finally assembled all of the parts including the disk adapter from Germany. I never could get one from Cannondale. The disk adapter was spendy...$150 total, including shipping and wire transfer charges. But in the name of experimentation, it was worth it.
    I fooled around to get my disk in the same place as on my AC hub so that I don't have to move the caliper when changing wheels.
    My intent with this wheel is to have it around for longer rides or crappy weather, or other times when I don't feel like riding my single speed. I have it set up with the same cog, so the chain doesn't need to change at all. Getting everything to fit so that I could swap wheels and throw on the shifter was inportant to me.
    This thing is heavy. My AC wheel, with the single cog on it is super light. The difference is dramatic. But, that's the difference between SS and gears. Derailleur setup to internal setup not so dramatic. Also, this has whatever rim and spokes that Harris is selling them with. If the hub meets the test, I will relace wheel with lighter spokes and a lighter rim.
    I just rode it around the driveway last night, and the shifting is cool. Wierd, but cool. You move the shifter and all of a sudden you're in a different gear...just like that. It feels like a single speed with the straight chain and all.
    Well, I'll start the beating tomorrow and report back in a while as to the durability and any other issues I have with it.
    B
    ballbuster
    Reputation: pimpbot's Avatar
    I wonder....
    ... if slathering it in a jacket of grease would prevent this. Not that I know anything about cold weather, living in Northern California in the Bay Area. I just read somewhere that sometimes folks slather stuff in grease in snow country to keep it moving.
    Music & Bikes
    Quote Originally Posted by pimpbot
    ......been there , done that......
    Hey everybody, i just registered so i could weigh in on my inter8 experience.
    so i have two inter8s, one silver with the red band, on my commuter bike, and a black one, (which is equivalent to the red band hub afaik) which i run on a sporty XC frame. i call it sporty because it is set up to dirt jump, street ride, and rip around all over. i've had the hub on it for close to six months, and in that time it has seen tons of offroad use, XC races, large-ish (5' tall x 15-20' long) dirt jumps, lots of bunnyhop gaps, drops to flat, stairs, and a trip to colorado where it completed the monarch crest trail, and several other trails of that nature while I was there. it was also installed on my xtracycle for a short time hauling around a 20lbs load.
    during its service it has perfourmed freaking excellent for me, and only very occasionally crunches gears (mostly between 4 and 5) usually due to overtwisting the gripshifter. i've found in my time riding it, that the hub must ALWAYS be perfectly adjusted, or very close, and every few rides or so requires a quarter turn or so either way at the shift adjust barrel to dial it in. i don't really have this problem with the one on my commuter, and while I do ride it offroad some, it doesnt get beat as hard. in my opinion it is also a good idea to keep the cable fresh on it, as slow or gummy cable response can cause it to crunch too.
    i've also noticed the way in which it is shifted makes a BIG difference, and i coast and shift whenever possible, especially if the shift is gonna be under load. although, with the right amount of finnesse a smooth shift under heavy load isn't too tough, but i figure the nicer i am to it, the longer i will be able to get away having it serve as an off road component.
    That sounds awesome... do you have any pics?
    Do you notice the weight of the rear hub when jumping and bunnyhopping?
    yeah, the weight is a big factor with the hub, but it just shifts like money, so i find it worth it. i would say it takes my bunnyhop down a few inches, but it is pretty transparent when jumping. climbing hills can be a bit of a chore too, but again, it is so quick and easy to shift i see it as acceptable.
    Quote Originally Posted by ulcerpentacidis
    Thanks very much for chiming in. I noticed the same thing as you with the occasionaly clunking ghost shift, and yes, usually between 4 and 5. SHifting can be a little vague if the cable tension isn't just right.
    Otherwise, it's been great to me so far, though I haven't thrown nearly as much at it as you. Good to know it's holding up.
    yeah, they are the hot **** in my opinion.
    as soon as the alphine group becomes avaiable, i plan on picking up one of the new rapid fire shifters to replace the grip shift on my mtb.
    i'm also planning on picking up the new disk hub for my cove full suspension.
    wtf this site censors expletives???
    Blanco
    ulcer: thanks for sharing your experiences!
    With the tapfire shifter, I definitely notice that the 4->5 shift sometimes requires more effort than the other shifts. However, I've never missed a shift...if I'm under load, it just sits there in whatever gear it was in until I let up on the cranks a bit.
    I also have only adjusted the cable once. But I haven't ridden nearly as much as I wanted to this summer, so I can't say I beat mine up like ulcer does.
    I think the Alfine triggers will be the way to go. I know that shifting is more reliable and precise, and I suspect the hub will last a lot longer, with the tapfire. The revo shifter has a lot of slop in it, even compared with a SRAM Grip Shift.
    No news to report otherwise.
    clutch adjustment?
    i've got a bike that won't shift down to first gear. could use some help with how to make correct adjustments.
    Music & Bikes
    Try to wash the shifting system ;
    remove the wheel and take off the plastic lock ring on top then remove other part under (the one that has cable stop)
    Wash/oil generously everything , put back , should be OK.
    Before installing cable , try to turn the mechanism by hand to see if it moves freely....
    Important to open a beer after.....
    Quote Originally Posted by keenen
    have you made certain the two yellow dots match on the cassette joint? bear in mind the shifter must be in 4th gear to check this properly. if it is a small amount, you should be able to make up the difference by adjusting the barrel at the shifter, otherwise, a readjustment of the cable nut might be in order. if the two yellow dots line up, try cleaning the cassette joint like the above poster mentioned, or try new cable/housing, as i've found a sticky cable can really detract from the shift reliability.
    on another 8spd related note, i recently tried modifying my shifter by sawing off around half of the actual gripping area. while it feels alot less intrusive being trimmed back, it turns out there is a tiny lip on the out edge which holds the shifter together. once it was sawed off the shifter came apart, and wouldn't shift right. it seemed like it was fukt, but after stuffing the lipped portion into the handgrip i was using backwards so it'd press against the shifter, and adding a gripshift spacer it seemed to hold ok. i'm planning on picking up a pair of lock-ons that i can get up against the shifter tight to really hold it in place. i figure if i tighten up the lock a bit, and tap it tight into place it'll hold pretty solid.
    so yeah, you can cut the shifter back to improve the holding position, giving more regular grip to hold onto, and better brake lever reach as well. keep in mind though, it does technically wreck your shifter, and it takes a bit of rigging to get it to work right, but it really does feel solid, and is MUCH better to ride aggressively with. btw i will probably post pics when i switch to some lock on grips.
    rep
    rep is offline
    Sep 2004
    Rohloff hubs are happier in the winter because they use oil instead of grease. My Nexus 7 complained a lot more in the cold than does my Rohloff. For that matter, my Sram 7 complained about the cold as well, though not so much as the Nexus 7, which still shifted but made grindy noises.
    Reputation: beegirl's Avatar
    Apr 2005
    Could something like this be used? http://www.fullcycles.com/product_in...1a21eebc418051
    For what its worth.
    Talked to my LBS yesterday and they ordered the Shimano Alfine shifter in from California. Should come in mid-April - $45 Canuckian. However, a la Henry Ford, "you can have any colour you want, so long as it is black".
    According to the Shimano Techs in Cali the Nexus hub is compatible with Alfine shifter. Hope that helps solve some issues out there.
    Any more trail ride reports with the Nexus hub? I didn't ride mine much over the winter and I just have it set up on my commuter/tourer with the awkward gripshift setup anyway. Looking to transfer it to the MTB some time this year.
    i don't suppose you'd elaborate on how exactly you got the shifter,
    i'd love to get my hands on one as well.
  67. #67
    Reputation: dwnz's Avatar
    Dec 2004
    I got my hands on a Alfine trigger shifter last month and replaced the Nexus Revo shifter I had actiavting my Nexus Red-band 8 sp. The difference is like night and day. Whatever version of the hub you have, don't waste time with the twist grip.
    The Red-band has been in service off-road since July last year and also recently undertook a 200km weekend dirt road ride that involved a a few major climbs. I can barely tell that I'm running internal gears and the bike also has that short-chain s/speed quiet drivetrain benefit.
    A Rohloff costs several times as much as the 8 speed and the Shimano's 3.1:1 gear range is plenty wide enough for those who don't feel the need to pedal when going really fast. What's not to like?
  68. #68
    On MTBR hiatus :(
    I may have to pop one on my commuter if SRAM doesn't get their Inter-9 to the states soon (re-DICK-U-luss to announce a product so early and not make it available).
    I'll let youse guyz play guinea pig with the Nexus off road a bit more. In fact, now that you mention it, there are spots on nearly every ride where I spin out my Rohloff, and other times where I (guiltily) wish for one more gear lower. Not saying the Nexus wouldn't fill most my need, just observing that 5.26:1 sometimes doesn't cover all the bases.
    I'll probably give the triggers a try no matter which of these hubs I pick up, but the benefits of a twister is outrageous when choosing amongst 14 speeds.
    speedub.nate
    ∑ MTBR Hiatus UFN ∑
  69. #69
    I just had to talk to one of the shops locally who had a contract with Shimano (apparently not everone does as you have to buy over $2500 worth of product). So that meant that I had to go to a shop that I don't normally deal with, but they were good guys and called Shimano up in California. Sure enough, they would have them in by mid April. So I guess I should qualify by saying I haven't seen the shifter yet, but do expect to have it in hand soon. I think $42 Canadian is what it comes out to. Good luck with getting one, if you really get stumped, let me know.
  70. #70
    @adelorenzo
    Reputation: anthony.delorenzo's Avatar
    Tips on wheel build-up
    I figure I'm going to take the plunge and build up a wheel for my MTB (Karate Monkey 29er). I just can't drop $1K on a Rohloff, as much as I want to.
    It looks like Harris is the only on-line source for them. I am going to try LBS today, but it sounds like these 'red band' ones can be hard to track down.
    I'll likely use a Rhyno Lite 700C laced with DT straight guage stainless. Is there any dish to this wheel? Where can I find the hub specs? Any other tips on wheel build-up with this hub would be greatly appreciated.
    Thanks,
    Anthony
  71. #71
    Music & Bikes
    They are 36 only....
    Go there
    http://www.dtswiss.com/index.asp?fuseaction=home.main
    -Choose "spoke calculator"
    -In rear wheel hub , choose "other"
    -then to the right , you can choose Shimano Inter 7
    Maybe confirm with somone the exact dimention of a red band , but it should be very close to that
    If your rim choice is not there , ERD is the distance between two opposite wholes +- 3-4mm
  72. #72
    Egads!
    Maybe try a Velocity rim instead of the poor Sun product? The pricing is similar, but speed results and ease of use are quite different.
    Although Harris Cyclery is the only one to stock the Nexus 8, many places can build on the Nexus hub because it is catalog standard part for the two largest vendors of bike parts. Check at your local bike shop.
    I believe that Wheelsmith DB14 would make a stronger wheel because it would be able to react to the terrain. That sounds better than the behaviour of DT comp straight which would transfer all of the jolts right into your hub.
    The new sport specific hub is black in coloring and has more options as for the number of spokes and brake styles, although durability has been shown as identical to the Nexus 8. It is expected that the unclear "red band" model will be discontinued in favor of the the black-colored model which has more obviously performance-centric marketing and features.
  73. #73
    Quote Originally Posted by dwnz
    Forgot about this thread.
    I ended up going back to derailleur in place of my red band hub becuase of the Revo shifter. I hate that thing. All the little yellow dots line up, but I just don't get good performance. I suspected the trigger would be an improvement, so it's good to hear that it is. Now if I can only get one
    It's May now...did anyone get a shifter yet?
  74. #74
    I remember when I first got mine that I had about 3 issues with it.
    Some of the gears took about 400 miles break-in before they became efficient. They all smoothed out in just fine, one-by one. #4 and #8 were the last to break in, but they too, eventually became easier to pedal than a derailleur.
    Even for the first few miles, it was especially sensitive to cable routing. It needed a straight shot down the down tube, under the bottom bracket and bee-line straight to the hub. If there was any creativity involved, then there was no shifting. I suppose that Jagwire Kevlar could help.
    By all means, find the sport-centric shifter if you can!
    I had installed the Nexus on a frame that was prone to drivetrain drag. It took several different cog sizes, an 8 speed chain, and a "narrow chain" half-link, before I had worked out the efficiency. The 20 tooth cog worked nicely. Keep watch on that darned cir-clip when it flies!
    Basically, the alignment needed by my particular frame was with the hub "all the way" back in the dropouts, which wasn't easy to do. That was a frame alignment deal for 1 particular frame, though. But, I mention it just incase you have the same thing.
    With the rotary shifter, mine preferred to be just a hair tighter than the dots perfectly even. Of course, they were still almost touching. If the nexus rotary is too loose, it would miss a shift. If it is too tight, then it will make a loud "bark" noise when it shifts. Having neither issue requires zero cable bends and some finesse. You can figure out where the optimum adjustment is after you align the dots. Yes, that rotary is "touchy" but it can be tamed!
  75. #75
    weird, i have a bit of bend with the nexus on my mtb, and it shifts fine even with the gripshift. i do agree the cable does like to be a hair tighter than the dots indicate. really, i've found sticky cables to be the biggest detriment to shfiting with mine, and if i slide the housing off, and grease the cable every so often it shifts like a wonder, even if the dots aren't lined up too great.
  76. #76
    faster than walking
    Reputation: Cody Broken's Avatar
    That is it. I want one. I got a wheel with the Nuvinci hub, and it is cool and I think it will last forever, but it is too damn heavy! The wheel weighs 11-1/2 pounds!
    I want a red band.
  77. #77
    weirdo
    Reputation: rodar y rodar's Avatar
    Hey, has anybody called to see if these folks really stock inter-8?
    http://edinabike.com/page.cfm?PageID...ils&sku=HU7860
    I made a command decision today to beg my wife for permission to buy wheel parts next payday and I think I`m going to try there for my hub.
    Also, has any body built a wheel from the lengths on the DTS calculator? A while back in this thread, I think a suggestion for Spocalc was made, but that`s a slightly different model too. Actually, two models and I don`t know which to use. One last question for now- since this is going to be my first wheel build, is it a bad idea to start off with something so oddball? In one way, I think it might be a good first lace because it`s just going on a "townie". It won`t have to put up with any abuse and "close enough" will cover quite a range when it comes to my mistakes. Thanks for this awesome thread, by the way.
    Recalculating....
  78. #78
    weirdo
    Huh. Just now I looked and saw that Jenson has changed their listing from "Unavailable" to "Ships tomorrow". I wonder if Shimano changed their PITA marketing strategy? A.E.Bike still says the manufacturer requests that they not sell. What the hell has Shimano been smoking anyway? For all the money and work involved in producing something, they sure seem like they don`t want to sell their product.
    Recalculating....
  79. #79
    Reputation: climbbikesurf's Avatar
    I was waiting on the Alfine but couldn't wait anymore so I got the Tapfire brifter and it shifts great. Then again, I haven't taken it on the dirt yet.
    I got the red band wheelset over the weekend and the shifting is incredible with the tapfire. I've been using my wife's Nexus 8 with revo shifter for the last couple of months and I always have to overshift to make sure it is in gear. I check the yellow dots and they are lined up. I'm thinking about changing her to the Tapfire brifter too.
    Anyway, I'm glad I got found this thread since it made my decision on the nexus easier. Tomorrow will be the first offroad ride
  80. #80
    I'm disrespectful to dirt
    Reputation: Shaun K's Avatar
    Has anyone heard about Shimano discontinuing the twist shifter? I was at my LBS ordering a Karate Monkey yesterday, and I was about to order a Nexus hub and shifter to go with it. QBP listed the shifter as "out of stock", and BTI listed it as "discontinued".
    The only options now seem to be integrated brake/shifter units, which do me no good on drop bars. Does anyone know if it's possible to remove the brake lever from the combo unit? If not, it looks like I'm stuck with a derailleur until the SRAM stuff comes out.
    o l d s c h o o l m t b
    Wanted:
    Mavic 117/217 rims
    Gravity Research parts
    Yo Eddy in Aqua Fade
    XTR 1" threaded headset
  81. #81
    Quote Originally Posted by Shaun K
    I had trouble sourcing one until my LBS contacted Shimano directly last week. I don't know if they're cleaning out the end of the inventory, but I'm supposed to have one tomorrow or Friday.
    Jack
  82. #82
    weirdo
    Seems to me it`s pretty hard to get ahold of ANY Nexus stuff. The Inter-8 is gone from Edinabike`s site now and back to "unavailable" on Jenson`s. I just ordered one with a tap-shifter from Airbomb. Tried Harris for the gripshifter? They have it on their website (but not the tap shifter), don`t know if it`s actually available.
    Again, has anybody laced an inter-8 from the Spocalc numbers? If so, did it work out OK and exactly which model did you enter? Anybody have it laced to Mavic 317s? I haven`t ordered my rims yet, but that`s what I`m planning to use.
    EDIT: that`s the rim brake version XM317 that I`m most likely going to use.
    Recalculating....
  83. #83
    I may have to call around to some other shops and see if they can source the shifter for me. On the other hand, this might be a good excuse to just wait and see what 2008 brings in the way of internal hubs...
    Wanted:
    Mavic 117/217 rims
  84. #84
    Quote Originally Posted by rodar y rodar
    Spocalc worked great for me. I used:
    S: 2.6 dL: 92.6 WL: 30.3 dR: 92.6 WR: 24.9
    from "Shimano Nexus Inter-8 8-speed internal SG-8R20 2004 Jan 22CaptBike@sheldonbrown.com"
    My application is a 406mm rim (bmx size) with a Sun CR18. Just got my custom Sapim 15g spokes yesterday from J. at gaerlan.com, and they laced up great. You can use the same size on both sides of the wheel, though in my application the left should be about 1mm longer than the right. Mine could have been a mm or two shorter on both sides than what Spocalc told me, but I still have some threads left after fully tensioning and stress relieving the wheel, so no problems. (I think my rim measurement may have been slightly off.) Gaerlan has great prices/service on spokes, btw--just the number you need, exactly the size you specify.
    Jack
  85. #85
    weirdo
    Thank you, Jack. By my understanding, the 8R20 is the original Inter-8 and the red band is 8R25, did you use those specs for a red band model or an original? No coaster brake? This is going to be my first lacing job, so I`m probably making things more complicated than neccesary, but I really appreciate the advice. Thanks for the Capt Bike link too. I already tried e-mailing him through the link on his own site and I couldn`t get through. If I`m still uncomfortable with the numbers, I`ll ask there. And since I`m buying my spokes and nipples from LBS, hopefully they`ll let me exchange them if they don`t work out right the first time.
    Did your twist shifter come in yet?
    Recalculating....
  86. #86
    I'm always nervous about spec'ing spoke lengths, too, so I did my own measurements and saw that they matched up with the 8R20 in the worksheet. Mine is the red band premium 8R25 model, but it looks like they both share a common hubshell. I'm not using a version w/ a brake.
    My twist shifter came in late last week, and I've now got about 65 miles on the hub. I like it a lot. I'm having a minor issue with a few clunks after switching gears, mostly after upshifting from three to four. I can feel that the gear has changed, but after a crank rotation or two, there's a minor "clunk" sound from the hub. It's happened in some other gears too. I'm letting off pressure before changing gears, but not actually coasting. I'm not overly concerned about the clunks as they aren't violent in any way, and it's only happened a dozen or so times in the miles I've covered. I'm hoping a couple hundred miles of break-in will help, as others have reported. But other than that one issue, I'm very happy with the setup. The weight and extra friction don't detract from the riding experience.
    I'd like to try the Alfine pushbutton shifter, but I'm also thinking about switching to drop bars on this bike, and there the revo-shifter probably makes more sense.
    Good luck with your build!
    Jack
  87. #87
    This German shop has some Alfine parts for seemingly fair prices:
    http://os-bikes.de/
    Shifter is about $40.
    They accept Paypal. The website doesn't support shipping outside Europe, but you could always e-mail and ask them. If they won't ship to US and you need 'relay' service, e-mail me and I'll try to help.
  88. #88
    weirdo
    Still waiting. I ordered my I-8 hub and the shifter/brake combo from Airbomb a little over two weeks ago and haven`t seen it yet. The next day I ordered rims, a Shimano dynohub, and a light from Harris and that order arrived lickety-split. I called Airbomb yesterday and the guy assured me that my parts really do exist, the shifter is in their store right now and the hub is on it`s way from New Mexico to them. I hope so.
    Shaun K- I`ve thought of a few options for running Nexus with a drop bar. One of them might be acceptable to you: First, it may be feasible to cut off the end of a drop bar where you want the shifter to sit and have a tube the same length as your cut-off and the diameter of a flat bar welded on or pressed and pinned into place. Second, do you think nonindexed friction shifters would work? (This might have already come up, but the combination of a slow computer and laziness prevent me from rereading the whole thread.)
    Recalculating....
  89. #89
    I-8 hub is out of stock
    I have a buddy with a QBP account and the I-8 is out of stock right now but the shifter/brake combo is in stock. That's for either the revo or tapfire combo. About a month ago, there were a couple of I-8 hubs but they got picked up within a week.
    I hope you get your hub. I've been using mine for two months now with the tapfire/brake and it is great. No problems shifting at all as compared to the revo shifter. My wife's bike has the road I-8/ revo and I tend to slightly overshift to get it in gear. With the tapfire, it is very accurate.
  90. #90
    Shaun K- I`ve thought of a few options for running Nexus with a dropbar. One of them might be acceptable to you: First, it may be feasible to cut off the end of a drop bar where you want the shifter to sit and have a tube the same length as your cut-off and the diameter of a flat bar welded on or pressed and pinned into place. Second, do you think nonindexed friction shifters would work? (This might have already come up, but the combination of a slow computer and laziness prevent me from rereading the whole thread.)
    I thought about this too. I have a method that should work for me, one that doesn't involve cutting or welding my nice new WTB Mtn Drop bar . I also decided not to wait on Shimano and their Nexus; I went with a 1x8 setup and a thumbshifter for now.
    I'd have the bike done this weekend but my wife went into labor 5 days early, so I'm typing this from the hospital on my laptop. Looks like I have other things to keep me busy besides bikes now
    Wanted:
    Mavic 117/217 rims
  91. #91
    weirdo
    That`s fine, the bike can wait. Good luck to you, your wife, and your newest addition!
    What is QBP?
    Recalculating....
  92. #92
    What is QBP?
    Sorry, I should have explained myself. QBP is Quality Bike Parts and they are the wholesale supplier to lots of the bike shops.
  93. #93
    weirdo
    Whoohoo! It`s all here (except spokes and nipples, which I`ll buy locally). The bummer is that it took so long that I`m ready to leave on almost back to back vacations and now I won`t be able to do anything with the new stuff for a good three weeks. Also a little miffed that the shifter/brake didn`t come with a matching front brake lever, but I`ll get over that. If I order one before I leave it`ll probably be here before I need it. Even if it isn`t, I can ride just as well with mis-matched levers.
    Recalculating....
  94. #94
    Reputation: itsdoable's Avatar
    FYI: This is available in North America from Brodie:
    Alfine hub with Avid Discs, trigger shifter, 700c cross wheels.
    http://brodiebikes.com/2007/2007_bikes/ocho.php#
  95. #95
    Music & Bikes
    This looks good too;
    http://www.bikes.com/bikes/2007/city/metropolis.aspx#
    Alfine , disks....
  96. #96
    weirdo
    Hey, everyone- I finally got all the stuff and built my wheels. It was my first build and after a whole bunch of confusion and lost time they`re done and, at least with the bike upside down, they look perfect! I`m relly jazzed about them! As I say, I don`t know how they`ll work when they`re UNDER the bike because I ran out of wekend before I got the rest of the bike put together. We`ll know soon enough. The rear has a red-band I-8 and the front has a 32h Shimano dynohub, both laced to Mavic XM317 rims. I`m putting them on an old Univega mtb frame that last served as my commuter until I started robbinbg parts off of it. Here are all the details if anyone is interrested:
    1st build spoke fiasco
    Recalculating....
  97. #97
    bcd
    bcd is offline
    Reputation: bcd's Avatar
    anyone ride the alfine yet?
    diff from red8?
  98. #98
    bcd
    bcd is offline
    also do you guys think there is something "better" in the alfine?
    or is it just glamed up with a triger shifter and forged body?
  99. #99
    weirdo
    On the road
    I have about a month and a half with my I-8 on my commuter now and thought I`d share my impressions and a few pics (also ask a few more questions). I have a redband with the tap-shifter/brake lever laced to Mavic 317 with straight ga #14 spokes on an old rigid mtb frame.
    After quite a hassle in getting the parts, then another hassle (due to my own brainfart) with spoke lengths, I finished the wheels and had no trouble with mounting and setup. So far I`m perfectly happy with my hub and mostly happy with the shifter. For a few days I was hearing a clunking and grinding, sometimes even a sharp bark and I kept dinking with the shift cable adjustment trying in vain to make it go away. Turned out to be my bb. DOH! At any rate, the shifter/hub performed pretty well even when they quite a bit out of adjustment as I was trying to solve my "shifting" problem. The index marks had to be way off before it caused any problems. For the record, I have a nice sweep in the cable comming out of the shifter, but I put a pretty sharp curve in it under the bb shell in order to keep it up out of the way. I read the posts about it needing to be very smoothly routed and figured I`d try it this way and change it later if needed. My usual method of shifting is to let off a little while I push the button, then it shifts magically- just like the others said. When I try shifting under a moderate load, it goes but it feels like it doesn`t like the idea, so I seldom do it that way. Honesty, I haven`t tried shifting under a heavy load so I can`t comment on whether it waits for me to let off. The real slick part of internal gearing, as has been mentioned several times, is being able to shift without pedaling. I love it! The next thing for me would have to be the novelty of the system. That`s half the reason I went with a Nexus in the first place. For wheel removal, I`ve found it almost impossible to get the little stopper and nut out of the slot in the shift collar with the wheel in place even with the cable completely slacked (out of the last cable stop). It`s much easier for me to put the wheel out of the dropouts first so I can rotate the hub forwards a quarter turn or so.
    Like I said, the shifters shift with no problem and don`t seem to be the least bit finicky about adjustment or cable routing, but I still have a few complaints. First, they take up a lot of space on the bar. The band is a good bit wider than the combined width of regular trigger shifters and brake lever bands and the whole aparatus just LOOKS huge. Maybe it`s because I`m not used to "brifters". Second, the buttons are almost the same position and feel as the Sram trigger on my mtb, except reversed. As a result, I keep shifting the wrong way for the first hour of so on each bike after getting accustomed to the other. I`m considering ordering a twist shifter for the second reason, but the first problem has me leary of that option. Maybe the thing to do would be to put twist shifters on my mtb. As for the brake lever, I don`t blame anyone for not liking it on a mountain bike (it really is clumsy), but it suits me just fine on my commuter/bike path menace.
    I have my gearing pretty low due to a lot of short steep climbs, a heavy bike with at least a small load and sometimes up to maybe 15lb of groceries, strong winds, and extra drag from the dyno hub when it`s dark out. I had 39-19 originally and liked it more or less, but thought about gearing up just a little. Last week I got a new crank and lost the 39t option, so I have it at 42-19 and I think I need to gear down a bit. Tomorrow I`m going to swap on a 44t ring and the 21t sprocket and see how I like that. All the changes have been pretty minor and I`m happy with the range. Compared to the 2X8 system on my mtb, I lose about two to three gears of granny and the top end feels about the same- maybe a little better with the Nexus.
    I did have one incedent that bears mentioning. While riding on a dusty, sandy road recently, the shifting collar somehow popped off. Could be that I never put it back on correctly after changing the sprocket the day before, or it could be that the sand jammed the collar against something and allowed the shifting action to work it loose. I popped it back together on the spot, then cleaned it out good when I got home and so far no more trouble.
    I know this is a thread for the back hubs, but I have to say that I`m equally impressed by my front set up. I have the DH-3N71 hooked up to the cheapest model B and M Lumotec light and it works great. It certainly puts out less light than many battery powered halogen systems and probably can`t compare with HIDs, but it lights up the road on the darkest of nights plenty well to ride at my speeds (20 MPH?). The drag when it`s turned on is noticeable, but not a big deal for me. When it`s off, I can`t say I notice any, but I have to admit I haven`t tried a similar set up with a non-dyno hub. The 26X1.5 are obviously going to roll better than my Fire XCs and the old Montgomery Wards 5-speed I was commuting on before this felt like I was dragging a truck behind me at all times. The additional weight is about the same as carrying a battery pack, so no real savings there, but it`s just plain cool.
    Now my questions: Sheldon Brown says that it`s a simple deal to disassemble, clean and lube the Nexus 8-speeds. He also said that you basically just start unscrewing everything you can on the left side, then pull the guts out in one piece. It looks to me like it`s the right side to disassemble. Any comments? Also, now that I have a few hundred miles on the hub, it seems like it would probably be a good idea to flush it all out and relube it as a post break-in measure (not that it really seemed to need much breaking in). Have the rest of you been doing that? I read about the shifter boot and it seems like a good idea even though it almost never rains here. Are they available in the US? I haven`t looked yet, but I don`t remember seeing them offered anywhere. Rain or no rain, even though I don`t do any off road riding with this bike, it sees it`s share of "unpavement". Like my street, for instance. Anything I can do to combat the dust would be nice.
    Here are a few pictures of my internal frankenbike. More are on the photobucket link. Since I`ve taken any pictures of it, I replaced the ripped up saddle, the ugly crankset and pedals and finished a new stem. I just put the new stem on tonight along with a Nexus left brake lever to match the right side. The big `ol monster of a stem in the pictures was my own design and build too and it was (is) fully adjustable because I wanted to see what length and about how high to make the permanent stem. I also built the basket from 10mm hydraulic tubing. I have a lot of plans for stuff I want to do, ending with a nice paint job. Hopefully that will be in another six to eight months.
    http://s161.photobucket.com/albums/t...xus%20Univega/
    Recalculating....
  100. #100
    Thanks for the detailed review! I'm glad you're generally happy with the setup. Personally, I'm having less-than-great shifting, using the revo-shifter. Unless I let up almost completely on the pedals, I sometimes get a clunk up shifting from 3 to 4, and 4 to 5. The shift seems to take effect, but I get this nasty-feeling clunk 1/2 to 1 crank revolution later. I hate it. I'm hoping the twist shifter is part of the problem. I think my cable routing is fine, but the shifter itself doesn't feel precise. I keep hoping the Alfine trigger will become available in the States, but I'm getting close to buying the Nexus brake/tapfire combo that you have.
    So I want to warn you that the twist shifter MAY not be what you want. However, I would encourage you to try it nonetheless, so I know if that's what's giving me grief.
    Beautiful basket, by the way!
    Jack
Page 1 of 2 12 LastLast
Members who have read this thread: 11
