Results 1 to 16 of 16
    Shimano Alfine spinning resistance
    I finished building up a Alfine laced to a Salsa Delgado Cross...and it seems as though there is some significant resistance spinning the wheel in the stand and on the bike. I haven't ridden it yet because this is my first experiance with any IGH and I wanted to make sure this wasn't a symptom of a larger issue.
    Is it common to have some significant (in my mind at least) spinning resistance from the Alfine?
    dru
    dru is offline
    They don't coast as good as a regular hub. Mine's got almost a 1000 miles on it now and it coasts better than when new.
    Drew
    occasional cyclist
    I have seen no difference on mine than from when I was on a cheapo single speed hub. When upside down, I like to see a wheel, as it comes to a stop, gently roll backwards as well. When this happens, I know that the brakes are not dragging and the wheel has total freedom of movement.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    Ride it 1000 miles, then give it an oil bath:
    dru
    dru is offline
    You're a brave man, cracking the safe like that!
    I'm a phenomenal mechanic and the innards of the Alfine frighten me big time.
    I'll take mine apart when/if I break it.
    I am getting near the 1000 mile mark, however.....
    Drew
    occasional cyclist
    Frt Range, CO
    I didn't dis-assemble the guts, just pulled, soaled and re-install 'em. Back in the day, I installed a TransGo shift kit in my Impala's 4L60e trans, after that, pulling the guts on an Afine or Nexus is child's play.
    Quote Originally Posted by pursuiter
    How did you come to use this as the oil of choice for the Alfine? Are other brands suitable as well? What's the oil weight BTW?
    Bike Dork
    Reputation: themanmonkey's Avatar
    Quote Originally Posted by dru
    Shimano hubs are a piece of cake unless you want to take them all the way down. Just do it and you'll see.
    dru
    dru is offline
    Thanks, Monkey! I suppose at some time I'll need to adjust the cones anyways. Good to know.
    Drew
    occasional cyclist
    Frt Range, CO
    Quote Originally Posted by sealcove
    After much navel gazing and intense internet forum discussions, I used what I had left over in my garage. Years ago I hot rodded an Impala SS and have some spare quarts of Mobil1 ATF. On the internet I tell everyone they are the best lubes in the world
    I did decide to use the synthetic Mobil1 ATF for cold weather performace. The difference in a car's trans when the temp is below 0*F is very noticable, it doesn't clog up an auto trans, I figured it would be a good lube for an IGH. The cost is very reasonable compared to almost any special bike lube.
    to pull the 'guts' out, only remove the non-drive side cones and push the assembly out from that side. it will stay in one piece that way. if you remove the drive side cones, things can get ugly.
    Bike Dork
    pursuiter in the pic you left the white lithium grease in the hub. That stuff and ATF doesn't play well and mix up when I did similar experiments years ago. Does the Mobil1 stuff mix with the white lith?
    The "speed" trick we used to do on Sachs and S-A hubs was remove all the grease and then dunk in 90 wt. gear oil. Let it sit for an hour or so, pull it out and put a little grease on the bearing surfaces only with a grease gun.
    Frt Range, CO
    Quote Originally Posted by onespeedfreak
    FYI; Nexus pushes out, Alfine unscrews counter-clockwise.
    Quote Originally Posted by themanmonkey
    pursuiter in the pic you left the white lithium grease in the hub. That stuff and ATF doesn't play well and mix up when I did similar experiments years ago. Does the Mobil1 stuff mix with the white lith?...
    Hasn't been an issue, I'll pull apart the Nexus next spring and see how it looks.
    Heads up Flyboy!!
    Reputation: mountaingoatepics's Avatar
    dru, its not bad...just remember the drive side dust cap unscrews counter clockwise and your golden....a few words and pics from my teardown last night
    Frt Range, CO
    Quote Originally Posted by mountaingoatepics
    ...few words and pics from my teardown last night
    Nice blog, I see you "de-greased" the guts. How did you achieve that, did you soak them in a de-greaser or just wipe down the outside surfaces of the guts?
    Heads up Flyboy!!
    Flushed with degreaser, cleaned and then let sit in oil for about 12 hours. Now this was more due to family obligations then any exact reasoning. I then wiped down the outside surfaces of the "guts" to remove any excess oil and regreased the ball and needle bearings with Phil Wood waterproof grease. I also greased the races inside the hub shell. I plan on taking apart the guts on the next go around but I plan on having some spare parts on hand, just in case. Here's the oil bathing and reinstallation words and pics. Hub spins much smoother and with less resistance then before, put a little over 25 trail miles on it today.
    <a href="http://www.flickr.com/photos/goatshell/4003831968/" title="PA120114 by Goat in a Turtle Shell, on Flickr"><img src="http://farm3.static.flickr.com/2424/4003831968_233bb35b3c.jpg" width="500" height="375" alt="PA120114" /></a>
