    Shim rotor, or trim caliper body?
    Installing a new rohloff on a surly 1x1 rat ride, I have the chainline lined up, but I could either shim the rotor out a little, or trim the inside of the caliper body to get the rear brake lined up properly, anybody have any suggestions?
    Can Tree Member
    Reputation: Dad Man Walking's Avatar
    Sep 2004
    Shim it. Cheap, easy, and most importantly...reversible.
    Dad is sad.
    Very, very sad.
    He had a bad day.
    What a day Dad had!
    Yeah, that makes the most sense Dad, it could be really quick and easy with some flat alum fender washers, or I could go the extra mile & get some flat alum sheet, and make a gasket type of shim so the entire surface of hub is in contact with the rotor. It's no rush so I'll probably do it with the flat sheet
    Can Tree Member
    Sep 2004
    Check around on-line or with your LBS...you can probably get shims made for this that come in a couple of different sizes; you can mix-and-match to get the exact clearance you need.
    Dad is sad.
    Very, very sad.
    He had a bad day.
    What a day Dad had!
  1. Trim or shim new shoes?
    By jadedbee in forum Apparel and Protection
    Last Post: 11-28-2014, 10:08 PM
  2. Shim under rotor - or caliper mount.
    By Broccoli in forum Brake Time
    Last Post: 01-02-2009, 04:56 PM
  3. Forced to shim... Caliper or Rotor?
    By rydog9991 in forum Brake Time
    Last Post: 06-04-2008, 04:08 AM
  4. Replies: 4
    Last Post: 02-29-2008, 06:02 PM
  5. Rotor rubbing on caliper body!
    By Muzza1975 in forum Brake Time
    Last Post: 10-29-2004, 04:31 PM
