Results 1 to 8 of 8
    Over 50, & not '2' tired
    Reputation: unigeezer's Avatar
    Good job! From 26er to 39er with one Click!
    <object width="480" height="390"><param name="movie" value="http://www.youtube.com/v/aYOk1SMKSpE?version=3&amp;hl=en_US&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/aYOk1SMKSpE?version=3&amp;hl=en_US&amp;rel=0" type="application/x-shockwave-flash" width="480" height="390" allowscriptaccess="always" allowfullscreen="true"></embed></object>
    www.unigeezer.com
    "Over 50, and not '2' Tired!"
    Reputation: mojojojoaf's Avatar
    UNI you are a mad man. Cool video cool hub for the uni!
    Quote Originally Posted by mojojojoaf View Post
    Thanks mojo!
    www.unigeezer.com
    Ever accidentally hit the shift button?
    Nice video what a great and original application of the Schlumpf system! Have you ever encountered instances when you accidentally hit the shift button?
    Ooops, duplicate post. See original below.
    www.unigeezer.com
    Quote Originally Posted by rokit831 View Post
    Thanks. Fortunately not, and that's because you have to make a deliberate inward pivot of your foot to depress the shift button, with the ankle area of your shoe. It's not actually that much of a pivot, but enough so that an unintentional shift is unlikely. And the only time it would be bad is if I was hauling butt in high, and inadvertently shifted to low!
    I would suddenly be spinning like I was in ultra-granny gear, and would be bucked off instantly, and probably go down pretty hard! Kind of like having a rug pulled out from under you (from behind) without warning. That's why when I have to downshift for a climb or whatever, I need to slow down quite a bit, and be ready for the 50% drop in gear ratio.
    www.unigeezer.com
    Cheesiest
    Reputation: intheways's Avatar
    Thanks for the info. Florian designs some cool products.
    Reputation: NZPeterG's Avatar
    ... and if we just ...
    Only Two gears?
    Do you not need more gears? and maybe more wheels?
    You have at last got a Guni
    Pete G..
  1. Schlumpf Cranks?
    By CarlosMeatPewps in forum 29er Bikes
    Last Post: 10-16-2012, 11:34 PM
  2. Round 2 - Downhill Uicycle Race
    By Father_Iain in forum California - Socal
    Last Post: 04-06-2010, 09:03 AM
  3. Schlumpf
    By AJT in forum Santa Cruz
    Last Post: 02-17-2009, 05:43 PM
  4. Schlumpf Maintainance Question
    By safetybike in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-08-2009, 08:01 PM
  5. Schlumpf drive..
    By Rainman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-29-2005, 09:50 PM
