Page 2 of 2 FirstFirst 1 2
Results 26 to 35 of 35
  1. #26
    Reputation: Climbercraig66's Avatar
    Oct 2010
    Hi Sjoerd,
    Interestingly enough, if I remember correctly, some parts of the Rohloff do "freewheel" while pedaling in certain gears. More accurately, some clutches and gears are rotating against each other in certain gears. In other gears, a clutch can be held stationary while an opposing clutch is dragged across it during pedaling.
    I do not think there is anything you can do to prevent this. One of the most unique components of the Speedhub is the "Silent Ring", a small rubber ring that lives on the axle, somewhere in between planet carrier 1/2 and planet carrier 3. This rubber ring deadens the noise created by the reverse-driven clutches. I would have liked to have been a fly on the wall during the engineering of this solution. Anyway, you should note the existence and location of this ring; a broken or misplaced ring would certainly amplify the noises you are experiencing.
    I would also suggest oil viscosity or quantity, as thinner oils and lack of oil both make a noisier hub. But since you have recently stripped and rebuilt, I assume you are topped off with the correct all-season Rohloff oil.
    Lastly, I agree with another posters theory of each Rohloff being unique, and somewhat agricultural as opposed to a Rolex watch. Every hub has a bit of personality. Despite wanting a more reserved fellow, you may have been paired up with the chatterbox of the group =)
    In my non-professional opinion, sounds like business as usual inside your hub.
  2. #27
    Oct 2013
    Hi Craig,
    indeed after some more Google-ing and listening to the Rohloff of my colleague I found out that also his Rohloff makes (very soft) freewheel rattles in the gears I mentioned. I was concerned about mine because unloaded and without hub it sounded very loud. (completely rinsed with Nebol) So there was no oil to be seen anywhere which made a somewhat noisy Rohloff even more loud...
    Do you think If I replace the silent O-ring for one a tiny bit thicker this will make the Rohloff somewhat less loud?
    It is hard to see on your video but looks like your O-ring is a little bit thicker than mine.
    I will try and see what it brings. Otherwise I'll move back to the original O-ring and accept my Rohloff is just more of a chainsaw drive trough the woods rather than a Silent geared hub...
    regards,
    Sjoerd.
  3. #28
    Even the "simple" 3 gear hubs have that freewheeling noise. Look at 10:45 of the following video https://www.youtube.com/watch?v=o6v5K-2zWMI . The speedhub has more than one star-ratchet type, clutches.
  4. #29
    Oct 2013
    Hi Selin,
    That I know, I also disassembled the the Speedhub. I've seen al the gears, pawls and clutches. After some more reading and thinking I understand what is going on. So yes, the ratchet sound needs to be there. totally cleaned whiteout hub and oil, this sound is pretty loud. Probably it will be less loud when in oil and inside hub.
    Cheers,
    Sjoerd.
  5. #30
    Oct 2010
    Sjoerd, you are correct that every hub will make these same noises, although some will be louder than others for a host of unique reasons, mostly manufacturing tolerances. And right again, a dry hub is noticeably louder than one containing oil.
    Personally, I would resist the temptation to change ANYTHING inside the hub. But if you do change your Silent Ring, please share your results!
  6. #31
    Jun 2013
    fixed
    I partly dismantled hub again(not planet mechanism,timing and etc.) and rode over 300mi.
    Hub is ok.
    Probably dirt or some of the shims from right side was not sitting properly.
  7. #32
    Dec 2015
    Reviving an old thread, I know, but I reckon this is worth contributing.
    I took my hub apart the other day (and, pleasingly, put it back together successfully), having seen climbercraig's very useful youtube video. I have developed an improvement in the method though by removing the planet carriers and gear rings as single units, which keeps the planet pinions synchronised as they are meshed with the gear ring:
    Rohloff Strip to Axle and Rebuild Videos (English)-p1060560.jpgRohloff Strip to Axle and Rebuild Videos (English)-p1060571.jpg
    On an earlier occasion, a friend of mine (who took these photos, BTW) disassembled his hub the usual way, and spent several hours fiddling around trying to correctly time the planet pinions, even though we only disassembled the first stage (the first 4 sun pinions). Without needing to re-time the planet pinions, we were able to reassemble the hub much more easily this time.
  8. #33
    Reputation: mbeardsl's Avatar
    The videos are always fun to watch. Anyone have a link to the Spanish version? Couldn't find it.
    Also, does anyone else remember seeing a blog post or forum post somewhere of a guy who drilled out the internals to lighten up the hub?
    Sent from my XT1585 using Tapatalk
  9. #34
    Reputation: gatouille's Avatar
    Mistake - Duplicate message
  10. #35
    I haven't Spanish version of disassembly hub, only English version you can watch on the web and my own video I have on my harddrive.
    There are several people who have lightened the hub :
    - Alpinibis
    Spanish. Image are no longer available on the web. I have image on my harddrive. It's a blue hub.
    - Zingel
    ROHLOFF Speedhub TUNING | Seite 69 | MTB-News.de
    P1060186.jpg Photo by oldschoolracing | Photobucket
    mein Trainingsrad wird abgespeckt! - Seite 4 - Light-Bikes Forum
    - FHS
    ROHLOFF Speedhub TUNING | Seite 78 | MTB-News.de
    - TitanWolf
    TR - Projekt "Deimos" - Das Trike [& Unterprojekte] | Seite 2 | Velomobil-Forum
