Results 1 to 8 of 8
    getting back into it
    Rohloff Speedhub 500/14 axle options?
    What axle options are available for the Rohloff? Are they available with Thru-axles, and if so, what sizes?
    Sorry, I'm new to IGHs (well, since my old schwinn 3-speed way back when ... )
    Reputation: 2xPneu's Avatar
    Quote Originally Posted by tedsalt
    Standard QR or bolt on (10 x 1 track standard)
    Quote Originally Posted by 2xPneu
    Thx 2xPneu!
    Which one is stronger? I'm a big guy ... need something strong ...
    On MTBR hiatus :(
    Ted, they are probably both about the same. Unlike other bolt-ons that are in effect a 10mm thru-axle, the Speedhub bolt-on 'bolts on" on the non-drive side, held in place by a handful of machine screws (same as the QR version -- look up "speedhub axle plates" if you are unfamiliar.
    The bolt-on version probably has greater clamping force versus the QR, which could reduce frame flex, maybe. But I'm aware of quite a few tandem drivers running the QR with no trouble, so I don't think ultimately the strength of one or the other will be a concern.
    speedub.nate
    MTBR Hiatus UFN
    As Nate says, strength is likely similar, but I use bolt-on because it looks a little cleaner (IMO) and perhaps a bit stronger clamping force as I run a full sus offroader. If you dremel off the acorn caps of the bolt on nuts it reduces the profile considerably. Just make sure you use loctite, and carry a 15mm wrench on your rides.
    Thanks for your replies 2xPneu and Nate.
    Any experience with Pitlocks with Rohloffs? It appears the Pitlocks work with the bolt-on Rohloff ?
    I have been using a Pitlock skewer in my Rolhoff for 3 years now.
    I carry heavy camping or shopping loads and usually ride on roads or tracks, so no extreme off-road usage.
    The only thing I did was shorten the skewer a few mm so that I could use a bar in the Pitlock special nut.
    The tightening torque recommended is 10N.m.
    ....just dont over torque the Pitlock - leads to shifting problems due to squshing the Q/R axle slightly.
    Strength does not differ but as 2xPneu mentioned, the TS (threaded axle) has a greater clamping force to support frame stability. Remember. A Q/R axle is only designed to secure itself to the frame (vertical dropouts) and so does not require a great clamping force to complete this task. Thanks to gravity, the wheel cannot move! The Threaded axle however is required to hold the wheel in place in a horizontal track dropout whilst the chain is constanly trying to pull the wheel forward! It therefore has to clamp itself firmly in place.
