Results 1 to 5 of 5
    Reputation: mbeardsl's Avatar
    Rohloff + MRP Bling Ring?
    Anyone using an MRP Bling Ring with their Rohloff? I'm curious if you would have to run it backwards to get chainline to line up decently as it it is supposed to put the ring in middle ring position by design.
    Reputation: vikb's Avatar
    Bling ring chainline is ~51mm and the Rohloff wants ~54mm so you are close.
    You could just use a few spacers to adjust the BB.
    Can you install a Bling Ring flipped? If so what's the change in the chainline?
    Safe riding,
    Vik
    www.vikapproved.com
    Yeah, I think I'll get one and try it flipped. I've already got some spacers going on so don't need any more of those. Wish I could get a 38t or 40t...
    Jun 2013
    liza
    Does not appear to be an option.
    The back side of the ring is heavily concaved, I'd say at least 4mm and with the way the spline pattern works, you may not even be able to get the splines to grab enough of the mount to be secure. If it worked (with slightly longer bolts), the difference in chainline would be 10mm I bet.
    My bike's in the shop right now, but I'll play with it when I get it back.
  1. MRP Bling Ring? SS usable?
    By trrubicon06 in forum Singlespeed
    Last Post: 04-14-2014, 01:25 AM
  2. MRP Bling Ring
    By BigwheelsRbest in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-10-2013, 08:59 AM
  3. Where to by MRP Bling ring online ?
    By edle in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-14-2013, 07:19 AM
  4. Bling Ring Compatibility
    By seanpatrickb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-04-2012, 01:37 PM
  5. MRP Bling Ring ??
    By WHALENARD in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-31-2012, 08:07 PM
