Results 1 to 3 of 3
    Oct 2014
    Rohloff Monkeybone on Chainstay IS Mounts
    Morning
    Investigating the possibility of putting a Rohloff on my Stooge and how to anchor the hub.
    Stooge has chainstay mounted IS disc brake mounts so if use a monkeybone the OEM2 plate will be facing forward. I understand this is a big no no may force the rear wheel out of a vertical drop out under load and instant death!
    If this is the case what are my anchor options? Want o avoid the torque arm if I can
    Reputation: ladljon's Avatar
    My Monkey Bone....I have seen them upside down and backwards...so I'm not sure. check out all different axle plates Rohloff has to offer.
    Attached Thumbnails Attached Thumbnails Rohloff Monkeybone on Chainstay IS Mounts-fullsizeoutput_559.jpg
    Music & Bikes
    Reputation: fokof's Avatar
    If you can see in the photo:
    There was enough space between the frame tab and the caliper to fit the OEM2 without the need of a Monkeybone.
    My calipers were Hope Mono Mini
    Attached Thumbnails Attached Thumbnails Rohloff Monkeybone on Chainstay IS Mounts-img_0002.jpg
    "There is a big difference between kneeling down and bending over" -FZ
  1. IS disc brake mounts vs Post mounts
    By laxdad in forum Fat bikes
    Last Post: 11-15-2016, 07:18 AM
  2. show me your Chainstay post-style disc caliper mounts!
    By Meriwether in forum Frame Building
    Last Post: 10-07-2014, 04:17 PM
  3. seatstay vs chainstay mounts
    By vqdriver in forum Brake Time
    Last Post: 09-14-2011, 11:03 PM
  4. Is this right? Rohloff OEM2 / Monkeybone / Dropout not aligned
    By highaltitude in forum Internal Gear Hubs
    Last Post: 07-12-2011, 08:07 AM
  5. rohloff with chainstay brake mount?
    By syl3 in forum Internal Gear Hubs
    Last Post: 02-13-2011, 10:43 AM
Members who have read this thread: 8
