I should say that the sprocket was not in when this happened. Also, the oil coming out seems to have flushed the grease out from around the bearings, I can see them in there all grease-less. What type of grease do I put around the sprocket when I put it back in?
Don't know a thing about this hub, but give it time, someone will probably provide some support.
The seal actually seals around the lip on the cog which is why it leaked out and why you can see the bearings. The bearings are lubricated by the hub oil. Put the cog back on and fill it up and ride away.
Why did you take the cog off when you changed the oil?
There is probably still enough oil in the hub, about 1/2 the oil remains coating the components after you drain the hub. I typically only put half the recommended amount as the excess eventually leaks out anyways. I've had it leak out in the car when the wheel was layed down. Messy...
There is a serpintine path through the axle to relieve pressure. It's also the source of oil weeping.
+1 - you can just run the hub and if you feel any concern do your next oil change early.
A friend had a Rohloff bike built up by a LBS. They forgot to put any oil in it. She ran it that way for a good long while until the mistake was noted. Rohloff got involved and indicated that limited amount of lube in the hub when it is assembled was enough to avoid any damage. Although an oil change and proper lubrication for her hub was advised going forward.
- You may not post replies
- You may not edit your posts
Forum Rules
