Results 1 to 2 of 2
    Rohloff: external into internal gear mech
    Anyone converted a Rohloff DB with external gear mech in an internal gear mech??
    I've seen some of these modifications in the mtb-news.de but unfortunately the information is only available in German.
    This modification will save quite a lot of weight but it requires some expertise...
    Information and photos are very welcome!!!
    On MTBR hiatus :(
    Are you asking about the external shifter?
    If so, the external shifter box is required if you're going to use the disc brake. To convert to internal cable routing, you'll need a non-disc hubcap. This will expose the cable entry ports on the hub and allow you to do away with the external shifter.
    speedub.nate
    MTBR Hiatus UFN
  1. Internal to external headset
    By peternguyen in forum Bike and Frame discussion
    Last Post: 09-18-2008, 12:19 AM
  2. Internal vs External BB
    By kuksul08 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-04-2007, 07:26 PM
  3. External Vs. Internal BB differences
    By Eric Hoefer in forum Beginner's Corner
    Last Post: 05-21-2007, 03:18 PM
  4. How about a Internal/External geared hub
    By aka brad in forum Singlespeed
    Last Post: 04-07-2007, 08:14 PM
  5. Rohloff Internal VS. External shifter cable routing
    By SSchmoe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2006, 11:15 AM
