Results 1 to 9 of 9
    used to be RipRoar
    Reputation: TraxFactory's Avatar
    Sep 1999
    Preferred US Distributor for Rohloff?
    Looks like these are the only options is US?
    QBP
    6400 W. 105th Street
    Bloomington, MN 55438
    Tel: (952) 941-9391
    Fax: (952) 941-9799
    www.qbp.com
    Cycle Monkey
    Performance Cycling Services
    713 Solano Avenue
    Albany, CA 94706
    Tel: 510 868 1777
    www.cyclemonkey.com
    (US Service Partner)
    Bicycle Technologies International
    1216 Mercantile Rd
    Santa Fe, NM 87507
    Tel.: 800 558 8324
    Fax: 505 473 0011
    www.bti-usa.com
    On MTBR hiatus :(
    Only? Many imported products only have one distributor.
    If you want to deal directly, I'd start by talking with Neil at Cycle Monkey. He's more-or-less taken over the operation previously run by Thomas of Rohloff USA. Plus he'll build it into a mighty fine wheel for you if you don't want to do it yourself.
    If you're purchasing through a bike shop, then QBP and BTI are options.
    If you're looking for a retailer, then check with Harris Cyclery in PA, Web Cyclery in Bend, or Universal Cycles in Portland. They all come to mind as resellers who actually know about and stock the Speedhub, unlike all the others who simply list it through their online QBP catalog. (I'm sure I'm neglecting others, these are just the ones I'm familiar with.)
    speedub.nate
    MTBR Hiatus UFN
    used to be RipRoar
    Sep 1999
    Quote Originally Posted by Speedub.Nate
    Thats true...thanks for the info once again. Probably go for Cycle Monkey since it local..
    Quote Originally Posted by RipRoar
    Going local here in California is another 9 3/4% sales tax on top of the price, if you buy new. Something to consider.
    used to be RipRoar
    Sep 1999
    Good point. My LBS is sourcing the part I was just doing the leg work for him and we are working out a "labor trade".
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    Who is actually installing the Rohloff system?
    Few shops, even good shops, have the skills to do it well. I've seen the funny mistakes they make with spoke positioning and such. Just sayin....
    used to be RipRoar
    Sep 1999
    Gotcha, I didnt realize building the wheel with the Rohloff would be different, maybe ill suggest we send my Stans Flow out to them to do it all. Last thing I want is spoke issues. I am going to assemble the entire bike in the end. Ive always turned my own wrenches, except wheel building..
    Update: I appreciate the heads up. I just spoke with Niel at Cycle Monkey and his opinion on wheel building with the Rohloff is "basically no different than any other hub", in fact he felt it was easier to build due to the equal spoke lengths. Its two cross for these hubs and all other wheel building techniques apply. If you have confidence in your wheel builder to build you a non Rohloff wheel they should easily be able to build a Rohloff wheel.
    On MTBR hiatus :(
    Update: I appreciate the heads up. I just spoke with Niel at Cycle Monkey...
    Neil beat me to it.
    Hands down, a Speedhub is the easiest wheel you'll ever build, for all the reasons Neil cited PLUS the lacing instructions are clearly written and illustrated in the user manual. If you're going to be building your first wheel, there's really nothing better to learn it on.
    speedub.nate
    MTBR Hiatus UFN
    Neil beat me to it.
    Ditto... just make sure you have the acorn nuts on, otherwise you can get that black moly oil all over everything when lacing if you lay the hub horizontally.
