Results 1 to 2 of 2
    OC rim for Nexus?
    Would an off-center, rear-specific rim be of any use with a Nexus Premium hub?
    Do the spoke calc. You want a dishless wheel. My Alfine calculated to 278 and 279 mm spokes so I just used 278 for both. Tension is just a smidge higher on one side. Pretty good for me. If you can get it to take the same length spokes on both sides it will be optimal.
