I am not familiar with the quirks of the Pugsley, although I would like to be at some point, but here are my observations about fitting a Nuvinci to my Long Haul Trucker:
Chainline: Nuvinci has a fairly wide chain line. I had to keep that in mind when ordering my bottom bracket.
Grip shifter compatibility: Some handlebars won't work, but I think most mountain bike bars would be compatible.
Gearing: Nuvinci has a lowest allowable ratio of the rear cog to the front chainring. 1:1.8, I believe. If my math is right, that makes a front ring of 33 with an 18 tooth cog.
My original plan with my Trucker was to start with traditional gearing and eventually convert it, but when I realized that I'd also be replacing my bottom bracket, and maybe my chain rings, and possibly my handlebars, it suddenly looked more cost efficient to just buy all of those parts with the Nuvinci in mind. It's entirely possible that you could just add the Nuvinci and be ready to roll, but you might want to look at the various components and make sure it will all work properly. Fortunately it sounds like there are some Pugsley/Nuvinci owners who will know what pitfalls, if any, there are.
