Page 2 of 2 FirstFirst 12
Results 101 to 126 of 126
  1. #101
    Dec 2011
    If you have steep climbs you will pay for it dearly.
  2. #102
    Well, steep climbs on a tandem are already a grind, it's part of ridin a tandem.
    But can I meet my low end requirements or better yet, can I beat them?
    GG Smash 29 (pending)
    Trek Full Stache 29+
    Kona Wozo 29+
    Devinci Hendrix 27+ (loaner)
    Specialize Levo FSR 27+ (wifee)
  3. #103
    Dec 2011
    Eh... it won't be nearly as low 22/34. Maybe more like 32/36
  4. #104
    So, there is "no way" to gear the NuVinci low enough to equal a 22/34 or it's just outside the warranty parameters?
    What's the lowest anyone has tried??
    I know there's a snow/sand bike running pretty low gears and not having problems...
    Kona Wozo 29+
  5. #105
    Reputation: Rob_E's Avatar
    There's a way: just change the gearing, but, yes, you'll void the warrantee. I don't what the lowest is that anyone has gone. I do know that people have gone lower, but there are other issues. The whole gearing issue is to prevent the hub from being over-torqued, from what I understand. Seems like a tandem would also increase the torque. In fact, just using the hub in a tandem voids the warranty unless it's specifically approved beforehand. I love the Nuvinci hub, but I'd think twice about using one in a way that could over-torque it, especially when you're stacking up situations that could over- burden the hub.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
  6. #106
    Rider on the Storm
    Reputation: Krakkreel's Avatar
    Hi!
    What do you think about this offers and seller? Is it frecuently or a very rare offer??
    Nuvinci N360 Internal Gear Bicycle Rear Bike Hub Silver 32 H 6 Bolt Disc Brake | eBay
    They sell it without cog and this "NOTE: 2012 Model, not Gates compatible" What is this?
    Thank you!
  7. #107
    NuVinci N360: Amateur Review
    My guess is that the hub was changed slightly in recent years to accommodate the Gates belt drive. I'm assuming "slightly" because they're still using the N360 designation and because I have 2 hubs. One was from the seller you link to and was designated as the 2012 model, and one was direct from Nuvinci with no mention made about production year and Gates drives. The only difference I could notice between the two hubs was a slight change in how the shifting mechanism attaches to the hub. My hub was pretty much the exact same deal last December, although I was able to get a 36 spoke, rim brake model. I don't know how often that kind of deal comes along, but shortly after I got my hub, they were no longer being offered at that price. I'm guessing that there's a certain number of the 2012 model floating around that someone is willing to let go cheaply so that they don't have to keep distinguishing between the two models. Given that only certain configurations are available at that price, it could mean they are getting scarce. But similar deals will probably appear the next time the hub is updated, whenever that is. If the model being offered suits your needs, I'd say grab it, because that's exactly what I did, and I had no problem with that seller, or with my hub. Also, I think my hub also said it came without a cog, but actually had a 16 or 18 tooth cog in the box.
  8. #108
    Dec 2011
    That's quite the deal. The difference is the freewheel. The newer models have a silver freewheel that can accommodate the Gates cog. The older black freewheels cannot.
  9. #109
    Dinner for wolves
    Reputation: buddhak's Avatar
    Wow. That is a deep discount. Come to papa, NuVinci!
    Responds to gravity
  10. #110
    Rider on the Storm
    Thanks for the information!
    New questions:
    - chain line for nuvinci360? I think is about 50mm (middle ring on a shimano crankset) but i would like to confirm it
    - Cogs (no Gates) are screwed or splined?
    - what is the Gates drive?
  11. #111
    Dinner for wolves
    Quote Originally Posted by buddhak View Post
    Hot damn! There is a Hong Kong seller blowing their stock out for $69 each. Zero feedback, so caveat emptor.
    Responds to gravity
  12. #112
    Rider on the Storm
    Please, link xDD (PM if you prefer)
  13. #113
    I brought it from the same seller($150) and got mine in a couple days. Good seller. It was $200 for a while and they recently change to $150 price. I guess if you are willing to wait a bit longer, they might drop below $150. I think the the HK seller($70) is fake, their listing got taken off by ebay and they used the same pic from the $150 seller.
    -as for chainline, it shouldn't be a problem with the granny gear or the big chain ring, but you can also adjust your chainline if you have external BB by add and subtracting shims.
    -Cog is splined
    -Gates drive is a belt drive system that require a special frame
    I'm in the process of building the wheel, just deciding if i should build it myself or have my LBS do it. It will be laced to a mavic xm819 tubeless 26" rim.
  14. #114
    Rider on the Storm
    Re: NuVinci N360: Amateur Review
    I bought it! Now i have to buy rims spokes, etc but i got the most important item.
    Chainline is 49mm fallbrooks confirmed to me
  15. #115
    Spud State Rider
    Reputation: Doug_ID's Avatar
    Just picked up a used pugs off e-bay with the n360 hub. Kind of a blind purchase but what the hell...... LOL. The hub intrigued me and thought worst case I could always swap out the rear wheel and go back to standard setup.
    I took the bike up to the local mountains for the first ride yesterday. My feelings are the hub has somewhat of a narrow range low to high and that the resistance added at low end of the range was significant. That was the most disappointing aspect for me as we have to do a lot of climbing around here. I will say it added significantly to the workout level though....lol. I am thinking about trying a double chainring setup to see if I can broaden the range a bit. Though I suspect that will probably exceed the recommended range.
    It is a neat concept and I liked the way it felt at anything other than say the lowest 1/4 of the range. Will give it a few more rides as is before I make any changes though. The guy who sold it said he only put 75 miles on it so maybe there is still some break in period to do and perhaps things will loosen up a bit in low?
  16. #116
    will rant for food
    Quote Originally Posted by Doug_ID View Post
    I've used these hubs since they were first available and made the same observations as you.
    It won't loosen up with time. You're thinking of mechanical teeth wearing together, whereas this is driven by non-Newtonian fluid.
    If they could figure out the low end efficiency and broader range, I'd be happily running an improved hub.
  17. #117
    Spud State Rider
    Quote Originally Posted by Drew Diller View Post
    Ah good to know.....thx. Yea love the concept just not quite there yet for my type of riding. Still may try a double chainring up front though before I give up on it.
  18. #118
    Spud State Rider
    Went for my 2nd ride on the pugs w n360 hub today. I have to say I feel a bit better about it now. Instead of shifting all the way into low and staying mainly seated on longer climbs I tried just going to the middle of the range and standing more. That actually worked out really well for the most part. The only time I really felt the hub resistance strongly was on a couple of short steep pitches where my cadence dropped and I was really pushing hard on the pedals.
  19. #119
    Rider on the Storm
    I have been riding for a month and I like this hub. Some issues:
    - fuel leak. I fixed it using some silicone for cars (until now)
    - gear range. It is supposed 0.5 underdrive and 1.8-2.0 overdrive, but my hub works in a range from 0.6 to 2.1 I have got fullreset four times, but there is not changes. Is there someone with this problem?
  20. #120
    cargo bike wheel build
    Hey Guys
    Any thoughts of putting this on a yuba mundo cargo bike that can carry 200 lbs plus rider and will have a electric front hub? thanks
    I think yuba was going to or did spec some bikes with this hub.
    Thanks !
    Quote Originally Posted by aTomOfAllTrades View Post
    DISCLAIMER: I am not by any means an expert rider and I have not tried every piece of equipment out there or ridden every type of trail. The premise of this review is to provide observations of the real-world performance of the NuVinci N360 hub with as much detail as possible. It is not meant to be an endorsement or advertisement, just data for people to draw from, with a few of my personal opinions along with it. Yes, the hub is heavy. No, it's not for everyone. Just don't give me crap because I write way, way too much or have stupid opinions.
    BACKGROUND: I'm 6'3", 215 lbs and like to break things. My singletrack bike is a large Surly Karate Monkey with a Fisher Rig build kit and a Fox F29 80mm fork. It's been set up mostly as single speed, but also ridden with a 1x9 setup for a while. As a SS it weighed in at just under 30 lbs. I built up the N360 hub to a Stan's ZTR Flow rim with a way-fatter-than-2.35 Bontrager FR3 tire. The whole setup brought the complete bike weight up to 33.6 lbs. There really isn't a single part of this bike chosen for weight reduction or speed, more for comfort and durability.
    WHEEL BUILD: A friend at my LBS helped me string up the wheel. I'll spare the details except for one anecdote: every time my friend lifted it out of the truing stand he kept thinking it was stuck, only to realize that it's just way heavier than an average cassette hub. Listen to the NuVinci recommendations and lace 2x at most (for 36h), because the diameter of the flange is so large it will be even stronger than a 3x Alfine, in fact because you end up with shorter spokes it's a lot like a 26" wheel laced 3x-4x on a standard hub. Otherwise, it builds up really easily. I noticed that the wheel has a significant amount of extra drag on the truing stand compared to a basic freewheel hub, but it is not really noticeable on the bike and that resistance drops as the hub goes through it's "break-in."
    BIKE SET-UP: Installing on the bike is straight-forward. Make sure the yellow marking on the hub are lined up, put the shifter mechanism in full overdrive, and line up the slots. There are manufacturer recommendations for the length of cable that needs to be showing out the end of the housing when the ends are installed (this is a two-cable set-up) with simple instructions that will get you in the ball park...follow those directions. Once everything is routed and (likely zip-tied) in place, shift the hub to full overdrive and check for cable slack, then do the same for full underdrive. Cable slack WILL screw up the shifter (more on that below).
    TEST RIDE: After installation and cable tensioning, a quick trip around the parking lot is a good idea to make sure the shifter is working properly and you're getting the full range of motion. I had some slack in both cables at first, which will cause the grip shifter to click and make noise and not behave properly. After adjusting the stops at the end of the cables, then tightening up the barrel adjusters on the shifter, all the clicks went away and everything works flawlessly. I recommend checking for cable slack after the first several rides, especially if you get any noise from the shifter, that will likely solve any problems.
    FIRST RIDE: I took a loop that would involve about 10 miles of speed road riding, with about 2.5 miles of flowy singletrack in the middle at Lake Crabtree. Nothing crazy, just wanted to see how the gear range felt, and how it felt on the road and on the trail. Mine is set up with a 32T front ring and 18T cog, making for a total range equivalent to 32:36 up to 32:10. On downhills I could spin out the top gear, but never needed to go any faster than I was going, then on the trails I ride regularly there aren't any climbs that I need a lower gear for. This is all the range I need for what I ride, but you can figure out if that's enough range for you.
    RIDE IMPRESSIONS: I'll say this first: after letting about 10 other people tool around on my bike and play with it, the first two words without fail they use to describe it are "weird" and "smooth." It's very appropriate. First, shifting is as you would expect (except that twisting forward shifts to a lower gear), you twist and it shifts. There is no grinding, crunching, or clicking...you're pedaling cadence just changes, making for a surreal feel over even the other IGHs. There is zero noise, no jerking forces on your legs, no missed shifts, no out-of-gear or ghost shifting sensation...it just shifts, is always in gear and works. My friend commented, "it's weird riding with you and being able to hear you shift gears."
    The added resistance of the hub is barely noticeable, but it is there. The added weight is only majorly obvious when you pick the bike up (remember, that's from my perspective, I'm not a weight weenie). During the first couple rides, the only odd feeling I noticed was when the bike was in full underdrive (32:36) and I was mashing up hill, I could "feel" the fluid in the hub. It wasn't a grinding, more of a swishing feeling that has since faded, as I suspect it is some break-in related symptom (note: there is no malfunction or slippage in this condition, just and odd feeling at first). I did put markings on the tire and test for slippage by checking rotation ratio under no load by just rotating the cranks freely with the bike in a stand, then did the same with extreme torque, mashing scenario. RESULT: there is zero slippage in this hub. You may perceive something as slipping, but I assure you that is not the case. Inefficiency via drag, sure, but you will not make it slip.
    This specific feature is one of the reasons I wanted to be an early adopter. It really is never out of gear, no jerking or sharp forces during shifting, you just pedal along so no matter what when you step on the pedal, you know what to expect. Already my knees feel better riding on this than they did on the 1x9. Of course, this is personal preference, so I'll leave it at that.
    So far, this bike has ridden like a SS. No drivetrain or chain tensioning issues, I can just spray it down after a ride if I want, no maintenance. I wail on wheels, not because I'm so skilled, but because I'm big and lack finesse. The point is, you'll break something else before you ever break anything in this hub. The next test is to go outside the NuVinci recommended gearing range and put a 22T cog on the back and start piling on the torque on the steepest climbs I can find (they say it should be at least 1.8:1 chainwheel/cog ratio as a very generic guideline). From my testing so far I am fairly confident in saying the hub is plenty stout for any type of riding you would do.
    SHIFTER: I'm putting a whole separate section for the shifter because in many ways it's the most used and most critical part of this whole set up. If not set up properly as discussed earlier and cable slack is not eliminated from both cables, then you will have shifter issues. For argument's sake, let's say anyone that has this hub will know how to turn a barrel adjuster and it will be set up properly. What I was interested in was how it shifted in different riding conditions. The gear indicator with the little cartoon dude on the hill is pretty awesome if you're goofy like me (I almost never look at it while actually riding anyways).
    First, you can shift at a dead stop. This can be handy for obvious reasons and it's very light pressure to shift, however if you are completely stopped then it will only shift through about half of its range before you're met with a ton of resistance. NOTE: do not wrench on it to try to get it to shift the rest of the way through, you will just stretch the cables. If you just rotate the rear wheel at all (i.e.- start moving) then you can just as easily shift through the rest of the range. Not a performance issue, just something to be aware of. Where I find the shift-anytime feature most useful is when descending, knowing I'm about to hit a steep climb and I need to be a lower gear to maintain my momentum. I can be standing up, focusing on the descent, just twist the shifter a quarter turn, and when I start pedaling I'm already in that gear, period. Once I got used to doing this and how far to turn the shifter for an approximate gear change, it became super easy and comfortable (and it can bail you out of sloppy riding with immediate shift response).
    Normal riding and shifting is extremely easy. There really isn't a better word for it than "smooth." It just works, try one and you'll get it, instantly. Now, what people are more concerned about is shifting under load. The best way I can describe it is that there is a limit to how quickly you can shift under a really high load. If you're loading the pedals to the maximum you will be met with a ton of shifter resistance, so you don't want to be really cranking on the pedals and the shifter at the same time, but it will work. If you let off for even just the top/bottom of your pedal stroke for just a fraction of a second, the shifter will loosen up and change gears easily. I found that it's easy to shift while climbing, particularly if shifting to a lower gear, but you do have to use more force on the shifter to get it to obey you. That will likely be another personal preference thing, because for me I'd trade a little extra wrist force for continuous, uninterrupted power transfer/gear change, instead having the crank slip a 1/8 turn while shifting or the sudden change jerking on my legs (again, this is a personal preference).
    OVERALL OPINION: Yes, that says opinion, because this is how I feel about this hub:
    If you have a chance to ride one, DO IT.
    Chances are you won't love it. It's not meant for everyone, but it is totally cool. The majority of riders, particularly trail riders, aren't even going to be able to get past the additional 3-4 lbs of weight. Obviously, it's aimed at recreational riding, not performance/racing and as my riding buddy says, "you'd have to be nuts to think I'm adding weight to my race bike." Granted, but that's not the point of this hub from a mountain/trail bike perspective.
    I love this hub because it's: (A) easy to use (2) unbelievably predictable, (d) 100% reliable, and 4) I'm a big dude. I am the opposite of a weight weenie and am not a racer, so my bike is outfitted to be bullet-proof and fun, while allowing me to get a workout. Adding 2% to my total rider + bike weight? Not a problem to me. What I always hated was the way that derailers shift, the effect it has on your legs and pedal stroke, and the risk of damage to cages, chain slap, ghost shifting, adjustment and maintenance, etc. If you don't have a problem with derailers and prefer race-ready components, you likely will not be a huge fan of this hub. If you hate derailers, you'll probably fall in love with it instantly. Either way, it's completely fun and totally different from any other gear system out there.
    Hopefully the length of this post hasn't deterred people from bothering, I tend to ramble, I just figured that someone out there might actually appreciate knowing some of this stuff if they can't actually test one for themselves. If you're in the Raleigh, NC area I tend to ride at Lake Crabtree during lunch whenever I can, I'm always happy to talk about bikes and let you check it out. Pictures of my bike are attached below.
    -Tom
  21. #121
    Quote Originally Posted by beoutside View Post
    Hey Guys
    Thanks !
    Check out the allowable gear range and see how you feel about it. I guess a front hub motor wouldn't have any effect on hub tolerances since it's not actually transferring power into the hub. But then I don't really understand how pedalling works in combination with a front hub motor. I've seen mention of a Nuvinci used in a Big Dummy, so o don't see why not. I haven't had great luck with my hub, but I seem to be in the minority, and when it's working, I love it. Assuming the hub can handle it, this seems like it might be a perfect application.
  22. #122
    Reputation: ChiapasFixed's Avatar
    Apr 2013
    Great info on here! Getting ready to put a Nuvinci N360 into my Pugsley Special Ops. Will be running it on the inside chainring so a 22/16 for about a 1.4:1 ratio. Anybody on here run a ratio this low? Will give me a range somewhere in the neighborhood of 18 to 80 gear inches, which is what I need.
    My wife's Big Dummy has a Nuvinci with a 22t cog and a triple chainring up front, and it does pretty well so far. Happy to post a longer term review of both setups in a few months if people are interested. Both are eBay hubs no longer covered by warranty, so not too concerned about violating the low limit.
    In the meantime, please share your experiences undergearing the Nuinci!
  23. #123
    Rider on the Storm
    Quote Originally Posted by ChiapasFixed View Post
    I´ve been using my N360 with 22/16, but now I´m using with a 20/16 (yes! 1.25:1 ratio). Theorically, the nuvinci gives 0.5 underdrive, but in my case gives 0.58, so i had to go more far...
    This hub leaks some oil, so I´ll change it from my mtb to a CX singlespeed. I hope with 36/16 (2.25:1 ratio) will stop leaking oil, but im not sure if this issue was created because I went under ratio recomendations.
    EDIT: are you from Chiapas, México? Im from Chihuahua, wey! xD
  24. #124
    Apr 2013
    Simon, Chiapas Mexico!
    Interesting to hear about the oil leak... What year/version is your hub? Also, cN you feel any squish or loss of efficiency from gearing it that low?
  25. #125
    Rider on the Storm
    I think is from 2012, v-brake. I feel efficency runs down near underdrive. I've got control the leak making a "mexicanada": teflon, látex and automotive silicon
  26. #126
    Oct 2016
    Necro thread alert!!
    I've been considering a Nuvinci. I think I'll get one for a commuter build. Some comments were made regarding the shifter. It seems to me like motorcycle riders will adapt quickly because it's similar to rolling the throttle on my ZX11. I think for the commuter I'll use the recommended 2:1 ratio to start with.
    DAMN THE MUD, FULL SPEED AHEAD!!
Members who have read this thread: 34
