Results 1 to 2 of 2
    Lord of the Chainrings
    Reputation: Mudd's Avatar
    Apr 2002
    NuVinci & HammerSchmidt Combo Anyone?
    <hr style="color: rgb(183, 183, 183);" size="1"> <!-- / icon and title --> <!-- message --> Sounds crazy, but has anyone ever tried a Fallbrook Technologies NuVinci hub in back with a SRAM HammerSchmidt up front? Sounds like it would be a "seamless" shifting setup with a lot of range....
    http://www.fallbrooktech.com/08_Bicycle.asp
    http://www.magicmechanics.com/home.php?lang=en
    "Hesitation is the Mother of Failure!"
    ~~ 951 for Dirt & Roadster for Asphalt ~~
    On MTBR hiatus :(
    On paper, the ratios look like they might work, except for one little problem:
    NuVinci calls for a <i>minimum</i> chainring:cog ratio of 2.0:1.
    The Hammerschmidt is 24/38 gearing, and NuVinci's recommended gearing is 38:18 (2.1:1).
    In theory, running Hammerschmidt + a 16T cog would extend your upper range and give you a whole bunch of low gear to play with, but 24x18 would result in a 1.3:1 ratio -- definitely below their suggested minimum.
    speedub.nate
    MTBR Hiatus UFN
