Results 1 to 5 of 5
    Nexus 8 with coaster brake noise
    I’ve had a Nexus 8 w/ coaster brake for about 2 months now. Brakes fine (for a CB), shifts fine. I just noticed the other day that when it’s in the secondary gearing (5 thru 8) that when backing the bike up the hub makes a clicking noise. It does not make this in the lower gear (1-4).
    I’ve used the Nexus 8 (w/out coaster brake) and no such noise. Neither from my Alfine 8. Is this typical of the Nexus 8 w/ coaster brake?
    Thanks.
    To add: no noise on back pedal, just when pushing the wheel backwards.
    Dec 2008
    Quote Originally Posted by SingleSpeedSimian View Post
    I would not be worried about the sound, according to Shimano manual :http://techdocs.shimano.com/media/te...9830638061.pdf
    "The 8-speed hub has a built-in mechanism to
    support shifting. When this support mechanism
    operates during shifting, noise or vibration may
    occur. The shifting feel may also change depending
    on the gear position at the time of shifting.
    Noise may also be generated if the bicycle is
    pushed backward when the gear position is 5, 6, 7
    or 8.
    These occurrences are a normal result of the
    structure of the internal gear shifting mechanism,
    and are not a sign of a malfunction."
    thank you irrah
    Stand-up philosopher
    Reputation: drwx's Avatar
    Re: Nexus 8 with coaster brake noise
    I thought this was a thread about a Google device with a cool alert sound.
    *facepalm*
    Stephen
    stephen
    no one can appreciate the poor misunderstood
  1. Nexus 7: Is this noise normal?
    By lqbweb in forum Internal Gear Hubs
    Last Post: 04-27-2013, 01:57 PM
  2. Nexus coaster 135?
    By patirwin in forum Internal Gear Hubs
    Last Post: 09-27-2012, 02:01 PM
  3. Nexus 3 Coaster Brake vs. Non-Coaster Version
    By scooby214 in forum Internal Gear Hubs
    Last Post: 03-19-2012, 03:21 PM
  4. Shimano Nexus SG-3C41: can coaster brake be removed?
    By anga in forum Internal Gear Hubs
    Last Post: 12-04-2011, 10:56 AM
  5. Coaster Brake SS
    By Crosstown Stew in forum Singlespeed
    Last Post: 04-07-2011, 09:01 PM
