Results 1 to 13 of 13
    Reputation: vikb's Avatar
    Mounting Rohloff disc rotor?
    I mounted a Rohloff disc rotor onto my IGH and realized after the fact that I put it on opposite to the direction of rotation in the Rohloff manual. I'm feeling lazy so I wanted to check with the Rohloff gurus on MTBR to see if the direction of rotation really matters??...
    Safe riding,
    Vik
    www.vikapproved.com
    I think it most definitely does....
    Reputation: -jes's Avatar
    It's worth the effort to change it ........................... just to stop people pointing and laughing at you on the trails
    On a serious note don't chance it.
    I would be more worried with the torque plate/axle/dropout combination!
    1*14*29*2.1 & 1*1*29*2.4
    yeah I think it does matter...save yourself more headache later.
    Quote Originally Posted by estutjaweh View Post
    no I think he's good on that looks like and OEM 2 axle plate and Monkeybone combination, pretty standard and officially Rohloff approved.
    I would swap the disc rotor round though
    ...not approved in a fork-end dropout though. The skewers apparently dont hold tight enough either unless you crank them on tight (which then apparently leads to shifing problems).
    Vikb:- Have you got a tug nut on the other side or something to eliminate wheel movement? May be an idea.
    The other reason for my comment is that the brake must be undone every time you want to remove the rear wheel. That would get on my nerves after a bit.
    Surly Black Ops 1×1 Mountain Bike… « The Lazy Rando Blog…
    I have an IGH on my Surly Pugsley and it's never bothered me to swing the caliper up when I remove the rear wheel. I do it so infrequently it's hardly worth considering.
    Safe riding,
    Vik
    www.vikapproved.com
    I flipped the rotor around, but looking at it I can't see any reason why it would matter to the hub or the brake caliper which way the rotor was spinning.
    Safe riding,
    Vik
    www.vikapproved.com
    The spines on the rotor are angled towards the force of braking.
    I guess this is a mechanical/design element to minimise flexing/rotational movement in the braking surface.
    Quote Originally Posted by -jes View Post
    From this thread:
    "As a rule of thumb, you can assume that the tensile and compressive strengths of steel are the same. However, in your example of disc shape, I'd say shear strength will be the limiting factor provided you can keep the disc laterally stable.
    And the shear force will be about the same in both shapes so it doesn't matter which way the disc faces."
    Safe riding,
    Vik
    www.vikapproved.com
    Good find vikb,
    Also found this article where their technical data makes the case for trailing spines but the manufacturer now recommends installing rotors with them facing forward to resolve an issue they experienced with the rotor warping.
    MTB rotors are made out of stainless steel rather than steel, looking at this technical paper on stainless steel there a lot of "stuff" to disseminate in there but seems to indicates SS has "high tensile plasticity" and elongates more under tensile forces compared to compression.
    I don't suppose it's a huge issue until prolonged high force/drag braking and/or weight come into effect.
    facing forwards should keep the rotor in tension withthe spokes spreading outwards, instead of encouraging the spokes to fold down... well that's the way I see it anyway.
  1. 203mm Formula Rotor for Rohloff
    By TraxFactory in forum Internal Gear Hubs
    Last Post: 01-16-2011, 08:41 PM
  2. Rohloff + Rotor Cranks
    By brodielibido in forum Internal Gear Hubs
    Last Post: 09-08-2008, 07:50 AM
  3. Need help mounting my rotor
    By Qben in forum Wheels and Tires
    Last Post: 06-24-2007, 09:09 PM
  4. Rohloff rotor upgrade help
    By yoginasser in forum Brake Time
    Last Post: 05-10-2007, 10:29 AM
  5. Need Rohloff Rotor Bolts
    By tpmbt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-01-2006, 09:00 AM
