Results 1 to 15 of 15
    Tires
    Reputation: Gritter's Avatar
    Dec 2010
    Modify Surly TuggNut for Alfine non-turn washers?
    If I "connected" the two 10mm holes on my Surly Tuggnut (by grinding the area between the two holes, so it's just one big oblong oval), would it work with the non-turn washers, if I only used the front "hole" of the tuggnut?
    The rear hole of the TuggNut seems to be there so you won't have too much Tugg hanging off the end of your frame, if you want to run the axle further rearward.
    If I lost the "dual hole" function of the Tuggs, and made it an oblong, 10mm channel, would it still function as a chain tugg? Would it retain it's ability to keep the axle from sliding forward, and would it also provide the proper hold for the Alfine non-turn washers?
    Soma, Surly, Salsa, Schwalbe, SRAM, Sun-Ringlé
    Tires
    Dec 2010
    Reputation: loOse1's Avatar
    I use redline tensioners on mine, I drilled out the front hole the same size as the zero turn washer, the tab on the washer fits perfectly in the gap between the front holes, works perfect, aluminum is easy to drill and only cost $14 bucks.
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Just use the tugnut on the drive side without the non-turn washer. Keep the non-turn on the other side. Works good, no problems on my Alfine8.
    I ride with the best dogs.
    Reputation: vikb's Avatar
    With bolt on IGH you don't need to use any tugnuts at all. Centering the wheel and getting good chain tension is pretty easy and with the bolt on axle the hub stays in place without any problem.
    Safe riding,
    Vik
    www.vikapproved.com
    Recreational Racer
    Reputation: Jvan_wert's Avatar
    Quote Originally Posted by vikb View Post
    My results have varied and I had to use a Tugnut with my Alfine. What I did was slide the tugnut on the axle before sliding the wheel into the drops. You may have to spread the stays a little. see this threads for the pics;
    Chaintug for IGH?
    “Let me 'splain. No, there is too much. Let me sum up.”
    will rant for food
    I once *did* add some material to a Tuggnut and then dremel'd it out. Yeah it was cool. What wasn't cool was how I bent both of the adjusting bolts, rendering them almost useless (I had to use a pliers to turn the bolt).
    Reputation: zanq's Avatar
    Quote Originally Posted by Drew Diller View Post
    I know it is generally frowned upon to bring up old threads, but this thread and the thread linked above are directly related to my question. I've tried PMing a few people but everyone is no longer active on the site...
    Has anyone tried modifying their Tugnutt as mentioned in this or the linked thread? I will be picking up a tuggnut today for my Alfine 8 Surly Ogre and will be sorting out the issue of retaining (with mods) or eliminating the drive-side non-turn washer. Filing the tuggnut so the tab on the washer drops in or adding material to the hole (gas welding) and reshaping to match a non-turn washer seem like good approaches.
    Ventana El Rey - 3x9
    Schwinn High Plains w/ drop bars - 3x8
    Surly Ogre - Alfine 8/SS
    Zanq,
    I would echo what Vikb posted several years ago: you don't need a tensioner for a nutted IGH. That said, you can easily, albeit slowly, file an appropriate slot in the tugnut/tensioner to fit the anti-turn bit...Lowes/Home Depot/any number of area supply companies (Grainger, McMaster, et al) will carry needle files from the General brand that will work fine. In most cases, the Alfine axles have plenty of length to accommodate another 3-4mm.
    _CJ
    _CJ is offline
    May 2014
    I've modified chain tugs to work with the Alfine non-turn washers, and it works fine.
    An easier route is to use Box Components tensioners. If you're able to use the hole closest to the rear, the non-turn drops right in. No modifications required. They're also thinner than most tensioners, giving the nuts more purchase on the threads. I've been using hex nuts with nylon locking inserts lately, and they seem to hold on better.
    Jan 2014
    I'm stoked to see that there are some workable solutions for this problem, but I simple decided that I didn't even need to use Tug Nuts on my Alfine Pugsleys.
    On my Pugsleys, its easy to line up the rear wheel and set the tension where I like it with my hand. I use the blue and green axle nuts (which aligns the shifter arm for routing the cable up the seat stay). I have zero problems with my simple setup. My rear wheels stay lined up just fine when the axel nuts are torqued to spec. (30 ft-lbs using a torque wrench...or about as tight as possible using only a short 8" wrench from my tool kit).
    saddlemeat
    Aug 2003
    Quote Originally Posted by zanq View Post
    Using only one no turn washer works fine!
    Jan 2014
    Using only one non-turn washer worked fine for me, too. However, after another forum member mentioned the possibility that this may result in the axle twisting (after much use and time) on the drive side (the side where the Tugg Nut goes), I went back to using just the two non-turn washers.
    saddlemeat
    Aug 2003
    ^Cool, been using just one for years, don't think that's a worry, doubt anyone putting any more stress on the hub than me.
    Jan 2014
    Thanks, bsieb. That's reassuring to hear. I'm sort of a lightweight, but lately i've been standing and hammering up low rises and smaller hills in my higher gears, rather than downshifting and spinning, until I start to run out of steam and then must downshift. After being laid up with injuries for a spell, I'm into training mode. My old knees haven't complained, yet! So far, the Alfine hasn't slipped forward in the dropouts, either.
    Quote Originally Posted by bsieb View Post
