Results 1 to 2 of 2
    awesome
    Reputation: dblspeed's Avatar
    Idea! Lurcher + Rohloff - Yet another Chainline question
    Re post from the On One forum.
    Just Rohloffed my On One Lurcher for the summer season in the mountains, so far so good.
    I have a doubt about the chainline.
    In my previous build, a Scandal with external BB, Shimano HT2, I was using a SLX triple with a single chainring in the outer position, as Rohloff recommends a 54 mm chainline and the outer position should be the closest to that.
    Now I am using the same chainset on the Lurcher, but with the ring in the middle position (coming from a nexus 3).
    Eyeballing it looks just straight, also measuring with a metal ruler it looks fine.
    Am I doing something wrong?
    The setup works great btw, much better than with the alu frame, a carbon HT is spot on for the Rohloff imo.
    I don't understand your problem. It works great, and measures straight. What's the issue? IIRC it's 50mm to the middle on a shimano. Your concern is that it should be off by a few mm and doesn't appear to be? Perhaps you accidently flipped the Rohloff cog giving a different chainline.
  1. Lurcher + Rohloff - Chainline question
    By dblspeed in forum On One
    Last Post: 07-04-2013, 04:34 AM
  2. Lurcher size question...
    By benja55 in forum On One
    Last Post: 07-12-2012, 12:49 PM
  3. Correct Pugs Rohloff Chainline
    By suba in forum Fat bikes
    Last Post: 11-25-2011, 10:24 AM
  4. Niner MCR w/ Rohloff: chainline?
    By brettsportler in forum Niner Bikes
    Last Post: 11-01-2011, 12:57 PM
  5. SS Cranks that work with Rohloff chainline?
    By mbeardsl in forum Internal Gear Hubs
    Last Post: 03-09-2011, 05:44 PM
