Results 1 to 2 of 2
    Suffering Mightily
    Reputation: Drbbt's Avatar
    Karate Monkey bb for Nexus?
    Wanting to build a commuter KM with Nexus. I already have a crank w/ 42t and bash guard (square taper), but I am unsure that it will work with the flared chainstays of the KM without throwing off chainline. Any KM riders have advice?
    Thanks,
    Drbbt
    Without freedom of choice, there is no creativity. Without creativity, there is no life. The body dies.
    dru
    dru is offline
    Chainline is 47mm. 42 tooth is a big gear to be putting in the middle position. I doubt you'd have chainstay clearance. You could set it up by eye and see if it will clear before spending money on a bb. With a 42 tooth you'll have some serious speed. A 36 tooth will give you 22 mph at 90 rpm.
    Drew
    occasional cyclist
