Page 3 of 6 FirstFirst 123456 LastLast
Results 201 to 300 of 584
  1. #201
    1*14*29*2.1 & 1*1*29*2.4
    paragon make them too, but the issue you have is to find ones that are compatible with your frame. If the sliders aren't made by Kona, likely they are paragon. Look up paragon machine works, and ask them if they know if they will fit, or ask Kona.
  2. #202
    Reputation: Climbercraig66's Avatar
    Oct 2010
    Thanks Rich and Finch. I'll look into both those options and see what I can find.
  3. #203
    used to be RipRoar
    Reputation: TraxFactory's Avatar
    Sep 1999
    Hey Climbercraig66, where did you get those 90deg noodles coming out of the external gear box? are those just your basic noodles or did you need something specific.
    I want to do the same to my setup.
  4. #204
    Oct 2010
    Yep, just your standard V-brake noodles. I learned that trick from seeing it on someone elses ride here on the board.
    I think that is the best position for the cable box, and the noodles sure help to get rid of that 90 degree turn. I'm not a big fan of the "under the chainstay" mounts because they seem more prone to damage and also would be constantly blasted with crap from the front wheel spray.
  5. #205
    Dec 2010
    My 2nd hand 2008 Genesis iOiD:
    Chuffed to bits with it
  6. #206
    Music & Bikes
    Reputation: fokof's Avatar
    Quote Originally Posted by Climbercraig66
    I posted that trick 3 years ago.
    One thing worth mentioning , it's a good idea to add heat shrink tubing at the junction of the noodle and cable , it prevents elements to contaminate.
    See photo
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-eee.jpg
    "There is a big difference between kneeling down and bending over" -FZ
  7. #207
    used to be RipRoar
    Sep 1999
    Quote Originally Posted by fokof
    See photo
    probably would work well up on the shifter as well I imagine
  8. #208
    Music & Bikes
    Yep , I did that too.
  9. #209
    Oct 2010
    Thanks for the idea Fokof.
    And about the sliding Rohloff drops; I just ended up ordering a MoneyBone from CycleMonkey. Couldn't find anything on Carver Bikes and Paragon was a bit too $$. Gotta ease up on the bike budget this month.
  10. #210
    Oct 2010
    Finally got some trail testing done during a weekend charity ride. The new bike is awesome! One word to describe it? Trustworthy. It does exactly what I tell it, when I tell it. My old full suspension bike would squat while cornering, squish while climbing and squirm on uneven tracks, all of which led to a slightly unpredictable ride. But the new bike is rock solid. I also enjoyed the lighter weight and better geometry, and was able to kill every climb, some of which I used to have trouble with on my old bike, even when I was in better shape. But being my first hardtail, I still gotta remember to get my butt off the seat when things get choppy.
    I had some sense and mounted a new pair of SKS Beavertails before the ride. Got great coverage despite the fenders being largely unsupported. I like them because they don't look as goofy as clip-ons, but have just the right (for me) coverage and clearance for both commuting on the road during the week and doing backcountry rides on the weekends.
    Stiffer fork spring, Ergon Grips, and Monkey Bone are in the mail. Life is good.
  11. #211
    Reputation: dilelladesigns's Avatar
    Jan 2011
    Chumba HX2 29er 3 Speed
    Chumba HX2 Frame
    Rock Shox 120mm 20mm thru axle fork
    shimano inter 3 disc hub, DMR 20mm thru front, double butted spokes red alloy nipples to orange velocity blunts
    Red king head set
    Crank bros joplin post
    Shimano LX cranks salsa ring, custom polycarb bash
    Shimano deore mechanical brake levers
    avid BB7 7inch rotors
    Custom Shifter of my own design, CNC'd parts inline barrel adj and open cable from the stop to the hub
    tubeless with bontranger strips and stans
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-chumba1.jpg
  12. #212
    Reputation: biketuna's Avatar
    Nice
    _______________
    1x10 IS SO FINE on my 21.9 lbs IBIS SL-R
    11-36 XTR in the rear, 36T wide-narrow upfront
  13. #213
    niner wfo9/rohloff from germany:
  14. #214
    used to be RipRoar
    Sep 1999
    Thats a really nice Niner WFO build, congratulations.
    I am curious what size rear rotor and brake is that?
  15. #215
    2011 Shimano Saint with 203/203 Trickstuff rotors (www.trickstuff.de <- small but tricky german bike parts/brakes company)
  16. #216
    Quote Originally Posted by othu
    Stunning!
    How are you finding the reverb?
  17. #217
    Reverb works great but I'm not currently sure if I need a retractable seat post...
    I forget too often to push the trigger
  18. #218
    aka DummyDiva
    Reputation: cowboygrrl's Avatar
    Jan 2011
    Just finished my build of my Pugsley with an Alfine 11 (cross post Surly/Fatbike)..
  19. #219
    Nichetastic
  20. #220
    Rohloff Belt Drive
    More info here
  21. #221
    aka DummyDiva
    Jan 2011
    Yesterday's ride.......rest stop.
  22. #222
    Manchester, England
    Reputation: Chocolatebike's Avatar
    Mine's a road bike but it gets off-road from time to time:-
    11-01-27 Rohloff Enigma LHS by Chocolatebike1, on Flickr" width="549">
    11-01-27 Rohloff Enigma RHS by Chocolatebike1, on Flickr" width="549">
    11-01-27 Rohloff Enigma bars by Chocolatebike1, on Flickr
    Spec is:-
    Enigma Excel frame
    Kona P2 fork
    Avid BB7s front and rear
    Rohloff with Hubub mounted shifter
    FSA shallow drop bars
    Shimano brake levers
    SON dyno front hub, Supernova E3 dyno and IQ Speed battery lights.
    Mavic A317 disc wheels
    Marathon Extreme 35mm tyres
    Topeak rear rack
    Since the photos were taken, the front rotor has been changed to a Hope to match the rear, the pump has been relocated to the RHS seat stay, the battery has gone onto the down-tube and the rear brake cable has been re-aligned.
    The bike was originally fitted with derailleurs (XT) but I converted it after it was stolen, advertised on Ebay and recovered. I'd already ordered its replacement (lighter, faster) so I decided to go for a heavy duty tourer.
    So far, so good. I've done just under 1000 miles on it since I got it back in mid Jan and the Rohloff is getting better. Still lots of whirring though..........
    I'm definitely going to fit a half-link EBB to get rid of the chain tensioner and I'm contemplating the Ezyshift electronic shifter, if only because I miss being able to change from the hoods and drops. A carbon fork is also a possibility since the P2 seems a little harsh.
    I've broken two spokes in the past week so I'll be speaking to the wheel builder about that tomorrow.
  23. #223
    MONKEYMAN
    Reputation: finger51's Avatar
    Quote Originally Posted by Chocolatebike
    Good lordy! That thing needs more 'stuff' hung off it.
    -1 point for no bell
    -1 point for no rearview mirror
    -1 point for no bottle opener
    -1 point for only 2 bottle cages
    -1 point for no kick stand
    -1 point for no safety flag
    <img src="http://tricyclesforadults.net/wp-content/uploads/2011/03/M-Wave-Bicycle-Security-Flag.jpg">
    “I don't like jail, they got the wrong kind of bars in there”
  24. #224
    Manchester, England
    Quote Originally Posted by finger51
    It's a touring bike so it has "stuff", including a mount for an MF U-lock (paranoia after it was nicked) and I'm not a weight- weenie .
    When I get on the road bike, it seems to fly.
    Funny that
    Edit: bottle opener in my jersey pocket. Can't be too careful.
  25. #225
    Nice bike....is it just me or is that a really slack head tube? Was that a standard option, and how does it feel?
  26. #226
    PRETENDURO
    Whaaaaat?!?!? Clearly you missed the pictures of my IGH Surly 1x1. LOL!
    QUOTE from MTBR.COM: You have given Brewtality too much Reputation in the last 24 hours, try again later.
  27. #227
    Manchester, England
    Quote Originally Posted by finch2
    Thanks.
    I guess that it is slack but I have no problems with how the bike handles. I had it up to just under 50mph on one long downhill and it felt rock solid.
    It's a custom build of the the original Enigma Excel which was a touring bike. The current Excel is more of a racer.
  28. #228
    Posted this on the 29er thread but I thought I'd post it here as well.
    My Redline Monocog with a Nuvinci N360 hub.. That thing is HEAVY! Pretty neat though, and a blast to ride.
    Swapped to crosstrail tires today for some paved trail riding with moms. Trying to motivate her back into riding again.
  29. #229
    Here's my Redline Monocog 29er with Shimano Alfine 8 speed.
    I *just* got done building the wheel and getting everything working. First time I assembled a wheel, and my first time using an IGH. Very nice. Bit heavy, but it was a compromise I was willing to make.
  30. #230
    Just got my Rohloff and other parts installed on a new frame and took it out on its first ride yesterday. Works great. First frame build I've done - went fairly smoothly except for some bearing service I had to get the LBS to do.
    SC Chameleon frame
    Shimano SLX cranks and BB
    Marzocchi Dropoff II fork
    Raceface stem and bars
    King headset
    Thomson post
    Sun Single Track wheels
    Specialized Clutch tires
    Avid BB7s (165/203)
    46/16 gearing
  31. #231
    Darris, how efficient this hub feels? The best thing would be to swap your bike numerous times with a dérailleur geared bike with some slicks on it and then try to tell the difference.
    smeagol, keep us updated how the hub copes with such high torque loads. Especially let us now if it explodes.
    Metalized, you've got some fantastic geometry on this bike. Seat shifted rearward, rear wheel weight bias, front fork fast forward, body not leaning much - for some loss of pedalling efficiency (irrelevant for non-professionals) the bike must feel very agile overall, fun to ride and safe on descents.
  32. #232
    Quote Originally Posted by bikeisbetter
    The bike is as you describe. Steers great and takes rough descents and jumps real well. No problems climbing steep hills with it either. Couldn't be happier with the build.
  33. #233
    Felt Nine Solo Alfined
    Three poor mobile photos:
    I need a more elegant solution for the cable mount (but I want the cable to be easily removable for ss interchange).
    The only reason I went for gears was that at weekends I do long rides on mixed conditions and I could not follow my co-riders on tarmac sections. Dérailleurs were out of the question.
    After 5-6 rides, I have to mention some things about alfine 8. The range is more than enough for me. Gaps between gears are a bit uneven but no problem. From 1 to 4 everything works almost perfect (mushy roller clutch); from 5 and up to 8 back pedaling is not smooth and feels like the gear is disengaging ( I'm not talking about the freewheel) and when you pedal again it can take a half stroke to engage. This has been mentioned to another thread Alfine making funny noises... is it wrecked?. This thing is annoying and dangerous when you have to overcome an obstacle and you have to backpedal. In this respect it is not for trail riding - at least for my riding capabilities - where I prefer my rigid ss. In conclusion it is great except for the issue above (does alfine 11 or Rohloff have the same issue? I suppose that Rohloff with clutch rings works like conventional freewheel).
  34. #234
    dru
    dru is offline
    That's weird. Obviously you've got your yellow marks lined up in 4th? I've had an Alfine 501 for 3 seasons now and it does none of the things you describe. I just serviced it after 2500 km or so, and I'd describe the hub as pretty much bullet proof. Ride your hub a bit more, maybe it's a break-in issue.
    Drew
    occasional cyclist
  35. #235
    My buddy is getting some crosstrail tires on his 26" mtb. I'll ride the two and compare them. As far as I can tell there's some "squishyness" to the pedaling, especially noticeable in the lower rage. I can feel the rollers giving resistance as I'm climbing. Higher gears not so much, but it's still there. I really need to put a smaller cog on the rear as the top end isn't as high as I'd like.
    All in all an interesting setup but I'd like to find an alfine-equipped bike to compare inner hubs as well.
  36. #236
    Quote Originally Posted by dru
    Drew
    Yellow marks are perfectly lined up -I'm frequently checking- and gear changes are spot on. As for the mushy feeling it is not just a feeling; brake the rear wheel and try to pedal, you will see the sprocket moving a bit. This is the roller clutch giving the mushy effect.
    It is not something critical -or wrong- but it's there. Maybe this effect will be minimized with use through time.
  37. #237
    A Man Of The Truth
    Reputation: fellsbiker's Avatar
    **** derailers. Hopefully I will never own another one, ever.
    Of course my new BFF is chain slap. And in my case, I even get tensioner-slap. Once I get my rear triangle replaced (pesky frame cracks!), I'm going to do a lot better job wrapping it app up and I should be good to go.
    Oh and it's an Alfine-11 BTW, with 32/20 physical gears. Really great range. I just have to work at de-programming my brain for shifting with derailer-based timing. I'm always shifting too early with the Alfine.
    One more thing that may be of interest. Since I shortened my chain to what it is now (i think it's 96 links), I have not dropped my chain once. I have no guides on the cog, the tensioner does have guides on each side, and the only guide up front is the bash guard. The chain just doesn't go anywhere. I love it.
    <iframe width="425" height="349" src="http://www.youtube.com/embed/738Nrg1O6eI" frameborder="0" allowfullscreen></iframe>
    Check out my Mountain Bike Keychains on eBay
  38. #238
    Rigid Rohloff Steel 29er
    Already posted in other threads but thought I would dial in here as well.
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-bills-29er-drive-side-june-2011.jpg
    Internal Hub MTBs, post yours here!-bills-29er-waltworks-fork-crown-june-2011.jpg
  39. #239
    This is Preston he doesnt bite,,,,, often
    this is One of my Whyte Preston's he has been run as a single speed and in the winter with an alfine 8 speed,,
    despite the looks the old skool bb mounted sunn chain tensioner has been on there for 10 years and has done a number of endurance races and has been 100% reliable
    It has a 24" front wheel and 26" at the back,, i did this as i felt there wasnt enough weight on the front end,, the 24" wheel certainly seems to improve the turn in on the singletrack
  40. #240
    Jan 2011
    My new Marin Mount Vision with Alfine 11. Weight is below 14kg, which is quite an achievement given heavy frame (almost 3kg) and fork (130mm 2005 Marzocchi All Mountain 1, 2.2kg). Bike was build entirely by me except wheels - i asked professional wheelbuilder to do this. Total cost of the project was app. 2400 USD. Everything works and i like it :-)
  41. #241
    Jan 2011
    Better photo and wrote down full spec.
    Frame: 2008 Marin Mount Vision S in tangerine with DT Swiss M210 shock
    Fork: 2005 Marzocchi All Mountain 1 110-130mm
    Front wheel: Hope XC hub, Sapim Race spokes, Dartmoor alu nipples, Alexrims XED44 rim, Maxxis lightweight inner tube, Nokian NBX 2.3 tyre, Dartmoor skewer
    Rear wheel: Alfine 11 hub with 20t sprocket, Sapim Race spokes, Dartmoor alu nipples, Alexrims XD-Lite rim, Maxxis lightweight inner tube, Nokian NBX Lite 2.2 tyre, Shimano Centerlock Adapter
    Crankset: Ritchey WCS cranks, BBG bashguard, FSA single speed 32t chainring, MOWA alu bolts, Shimano Deore XT bottom bracket
    Under my ass: Specialized Pro 2 seatpost, WTB Speed-V seat, Tune Wurger clamp
    Brakes: Magura Marta
    Cockpit: CB Iodine C ahead set, Thomson Elite 70mm stem, Merek 650mm carbon handlebar, CB Iodine grips, Alfine 11 shifter with Jagwire Ripcord cables
    Pedals: Shimano PD-M520
    Tensioner: no name grabbed from my LBS :-)
    Total weight: ca. 14kg
  42. #242
    Reputation: Corporal Punishment's Avatar
    Here's mine. Revitalized junk specialized hard rock. I built the wheel the other day and I just finished fine tuning everything. Can't wait to ride it tonight!
    I love this IGH stuff. Mine's an alfine 8. After seeing how damned quiet this bike is, I noticed all the other squeeks and smacks and I nailed them all today (I think). Now its deadly AND silent. Love it!
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-bike.jpg
  43. #243
    Reputation: LukeSPOOK's Avatar
    Nice job
    What gear ratios you running ?
  44. #244
    Oct 2007
    My custom built carbon trail bike. It was a long time coming but well worth the wait. With a slack head angle, short chain stay and low bottom bracket, she is a super fun bike for throwing around the local trails.
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-img_8783.jpg
  45. #245
    Oct 2007
    From the other side.
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-img_8779.jpg
  46. #246
    Reputation: Wombat's Avatar
    Pipe, that looks interesting. What do you use for your rear hub,and have you had any caliper strike?
    Tim
  47. #247
    Oct 2007
    Quote Originally Posted by Wombat View Post
    Tim
    Rear hub is custom built using a carbon tube to space out the aluminium flanges. There is no freewheel in the hub so the secondary chain is always turning. A freewheel might be nice to have to cut down on drag and noise, but this way it is lighter and drag and noise seem negligible.
    I've only had it running for a couple of weeks but no issues so far with the caliper position. My friend Richie who designed the bike has been using his for over a year without issue. If it becomes a problem it is a relatively simple task to mount it up top. But it would not look as tidy.
  48. #248
    Quote Originally Posted by LukeSPOOK View Post
    Nice job
    32/22. By chance its the perfect ratio for no tensioner. The 22 isn't even the one I ordered! LOL. Turns out that not only is it better on the chainline, but I like the gearing better as well.
  49. #249
    - factotum -
    Reputation: Pooh Bear's Avatar
    Whoohooo. Now it's either singlespeed or internal gears. After 2 rides I started selling the external gear stuff. Now a while later I still don't regret it.
    1. Alfine 8-speed
    2. Sachs Torpedo 3-speed
    My other bikes don't belong here.
  50. #250
    Reputation: Stopbreakindown's Avatar
    Some really nice bikes in this thread, hope to join you guys soon!
  51. #251
    Rocky Mountain Hammer Alfine
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-rmbhammer_01web.jpg
  52. #252
    A shot on a ride recently (finally got a cool looking picture). The orange and black bottle is filled with an inner tube, tools and a first aid kit - which came in handy when my daughter scraped her leg. :-)
    Bike is a frankenbike. Bits from everywhere. 2002 Hardrock frame that I stripped and re-painted. Alfine 8 in the back. Its not a weight weenie bike, but its silent and deadly and handles like a dream.
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-silentdeadly-ot.jpg
  53. #253
    I like cake.
    Might as well
    I built up a Motobecane Outcast with a Nexus 3 speed to use as my commuter. I'm running a 36 tooth front ring and a 16 tooth rear ring. So far so good. The nexus shifter thing that goes on the axle had to be ground down with a dremel tool in order to fit, and I had to use one of the bolts for the sliding dropouts for the rack mounting, but it wasn't too hard to build.
    I would love to post pictures, but you need a post count of 10 or greater in order to post pictures. Thats just weak. So, pics to follow sometime soon?
    I like cake
  54. #254
    Mar 2006
    Here's my Ibis Tranny mated with a NuVinci N360. Had to make a special VinciBone because the dropouts were a bit too short for the anti-turn washers.
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-imag0115.jpg
  55. #255
    lovely tranny - my mates got one , love how solid it feels while still being race light worthy !
    quality chain tension method too !
    Love the rusty outer on the rohloff (its off my commuter - i have one hub i share between 2 bikes - i mostly run this bike SS)- a testiment to how impervious it is to crap because it still shifts like new ....
  56. #256
    MPU
    MPU is offline
    Here's mine in urban tires. The frame and fork is custom made by me from Columbus and Dedacciai tubing with lugs, Alfine 8 geard, Avid BB5 brakes, On One Mary handlebar, Brooks grips, some old leather saddle.
    Marko
  57. #257
    Cool Cruiser Marko!
    Kudos to you and your custom made frame and fork! Any more pictures or details..., like overall weight? Better yet, do you, can you or would you build one similar for interested cruiser/bike nuts?
  58. #258
    Quote Originally Posted by bikeny View Post
    I posted a seperate thread about this bike, but figured I would add it here as well. Black Sheep custom Ti frame with extending chainstays and black 32h Alfine hub. I run singlespeed in the summer, but like some gears for the winter, and maybe some endurance events. Enjoy:
    Hi bikeny,
    I see no EBB or slider on your frame, may I know how do you do the chain tensioning as I assume yours is a multi speed frame with verticle dropout.
  59. #259
    MPU
    MPU is offline
    Quote Originally Posted by rokit831 View Post
    This is a one-off frame. I don't have gas welding equipment so I can't make frames without loaning the needed equipment. More pics on framebuilding forum on "MTB cruiser starting to take shape".
    Marko
  60. #260
    Reputation: EGF168's Avatar
    Another Trance fitted with an Alfine. I like the hub but it needs a better tensioner and I’m not a fan of having it slip under power so it may not stay like this for long.
  61. #261
    Quote Originally Posted by EGF168 View Post
    If you have enough room, try with the tensioner pushing the chain up. Alternatively, use a 2 wheel tensioner like the Alfine version.
    Tim
  62. #262
    Another DIY Alfine build.
  63. #263
    nice bikes everyone... anyone know a site where i can get internal hub with wheel
  64. #264
    Music & Bikes
    Quote Originally Posted by ayuz View Post
    Internal Gear Wheels from Harris Cyclery
    Rohloff Hubs - Rohloff SPEEDHUB 500/14 Sales, Serice, and Parts
  65. #265
    Reputation: nateeprasan's Avatar
    Mar 2011
    I finished my full-loaded touring with 29er frame and 36 spokes Alfine 8 wheel. My bike+panniers+water is around 100 pounds. I still can not post any picture, need at least 10 posts before posting any picture! So, you can take a look at many pictures on my blog at Wordpress:
    lonewolfcyclist.wordpress.com
    I bought complete wheel with Alfine 8 hub for $261 as a spare from outsideoutfitters.com/p-18835-handspun-shimano-alfine-wheels.aspx
    It was shown as out of stock but when I called them, they can get it for me. This Handspun Wheel does not include small part kits ($16), Alfine Cog ($6), Alfine 8 Rapid Fire Shifter ($32).
  66. #266
    MONKEYMAN
    Quote Originally Posted by nateeprasan View Post
    Is that a Bokor frame? Interested to know which fork you put on.
    I'm using that frame for a polo bike right now!
  67. #267
    Mar 2011
    Quote Originally Posted by finger51 View Post
    Yes, it's Voodoo Bokor One 29er frame with Alfine8. It survived 3,900 miles full-loaded touring! Anyway, I'll try do light-weight mountain-bike touring from now.
    On my current trip, I put Salsa Fargo fork version 1 (445mm axle to crown length). It makes the bottom bracket as low as most of the road or cyclocross bike.
    But now I put a $30 suspension corrected fork-- Kona Project 2 29er Disc (465mm axle to crown length).
  68. #268
    My contribution..
    I have done things a little different but all in all, I love the way this bike rides..
    Just had the bike resprayed in a metalic black with a hint of red wine plus got the hub redone to match the wheels.. Just need to avoid falling off and scratching it all up again..
  69. #269
    Jan 2011
    What kind of cap nuts you use? Are they steel or aluminum? What brand it is? I'm ooking for orange cap nuts, but the only i can find are aluminum and i'm little bit afraid they will not work.
  70. #270
    Quote Originally Posted by rekrutacja View Post
    Not sure if they do orange but here is where I got them from -
    Gusset Alloy Axle Nuts | Buy Online | ChainReactionCycles.com
    ps.. they are alloy and they work just fine.. mine have been on for about two years now and all is good..
  71. #271
    Jan 2011
    Thank you. 10 or 14mm?
  72. #272
    10mm.. I made the mistake of buying 14mm first time around but they swapped them for me.
  73. #273
    As soon as I'm allowed you'll get my Rohloff Dambala.......
  74. #274
    Ride & Smile
    Reputation: KanzaKrūzer's Avatar
    Mar 2011
    Converted my single speed to IGH. The NuVinci 360 is as bombproof and quiet as a single speed. The expanded range covers all my needs. Total bike weighs in just under 34 lbs.
    KanzaKrūzer
    Salsa Warbird | Kona Unit
  75. #275
    Reputation: 77Zero's Avatar
    Quote Originally Posted by cowboygrrl View Post
    great build (and backdrop).
    Global Zero Fuel Expeditions. Sail. Bike. Paddle. Hike. 77Zero.
  76. #276
    Ti Rohloff 29er
    This is my Ti Rohloff 29er:-
    Burls 29er 5 by MacBludgeon, on Flickr
    custom ti frame from Burls a UK builder, Rohloff rear Hope ProII front hubs in red on Mavic TN719 rims, currently sporting Halo Twinrail tyres. Mary bars, On-One carbon rigid 29er forks, Hope headset and seatpost clamp, Thomson Elite setback seatpost, SMT hooknose saddle(still thinking about that), Avid BB7 speedial levers with BB7 MTB disc brakes. Deore chainset with single speed 38t ring and bashguard, Forward Components mini EBB for chain tension, and Monkeybone for the Rohloff torque. Some Be-One bottle cages and the pedals are Ming Shiju ones.
    All up weight as you see it is 28lbs but the tyres are 900g each so I expect I'll get it down by a lb or two fairly soon.
  77. #277
    Here's mine a mostly standard 2008 Monocog. And the beautiful Dambala (it was just too small)
  78. #278
    surly 1x1, rat ride graphics, dtswiss EX500 rims, surly front hub, rohloff rear,39x17
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-photo-2-.jpg
  79. #279
    Reputation: vikb's Avatar
    Safe riding,
    Vik
    www.vikapproved.com
  80. #280
    [IMG]http://lp1.pinkbike.org/p4pb6547673/p4pb6547673.jpg[IMG]
  81. #281
    sturmey archer 8 spd, wifes bike
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-photo-6-.jpg
  82. #282
    dru
    dru is offline
    I got a fork for my birthday.......yay!!!
    At least 2500 km and going strong....
    occasional cyclist
  83. #283
    know nothing at all
    I don't even know what an IGH is, but I want one now. I'm drooling over all of these bikes. I have got to shake this new found bike bug.
  84. #284
    Quote Originally Posted by banjo1981 View Post
    Internally Geared Hub aka hub gear aka IGH
    Safe riding,
    Vik
    www.vikapproved.com
  85. #285
    know nothing at all
    I was sort of kidding, but that cutaway pic of the internals looks impossible to service. Thanks for the pic.
  86. #286
    Ride & Smile
    Mar 2011
    The videos at the following link provide a brief explanation of CVP IGHs.
    KanzaKrūzer
  87. #287
    will rant for food
    You know, with me being such an IGH shill I thought I would have posted here.
    So here goes. Feeling sentimental about bikes that have gone to new owners or in one case are soon to be destroyed, hehe.
    An older style Pugsley that I repainted in a "John Deere" theme (not Packers, hush it) and mated it to a NuVinci N360:
    Post commute
    At home studded fat tires
    Fat but graceful
    Just in time for Halloween!
    Technically not a hub, but it’s internally geared - I built the first bamboo/carbon fat tire bike because, well, I felt like it. It's a dinglespeed bike thanks to a Hammerschmidt crankset:
    Profile
    Currently mated to a custom Lefty clamp and offset front wheel
    EDIT: To elaborate on the "destroyed" bit, I consider my first frame to be a partial failure, and am willing to sacrifice it to the destructive testing gods. The new is going to be much more attractive at the lugs.
  88. #288
    www.bigrobracing.co.uk
    Reputation: robdeanhove's Avatar
    Dec 2005
    Here's my Alfine winter mountain bike (in non-winter friendly colour scheme!)
    Jones'd XTR Cranks
    Alfine 8s Out Back
    Alfine dynamo up front powering......
    800lm dynamo light!
    There's more on my DIY dynamo light on this thread HERE on the light forum
    Or you can read about my DIY dynamo light in more detail on my blog HERE
    My favourite bit is still the polished & white colour scheme though, even though it looks dirty immediately I hit the trail! I can always see a bit of polish through the mud somewhere :-)
  89. #289
    - factotum -
    Great!
  90. #290
    VooDoo Soukri w/ Alfine 11 on some flows
  91. #291
    Reputation: mr pinga's Avatar
    Here's my 2005 alfine 11 kona unit
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-img_0140.jpg
  92. #292
    Another pic of my kona
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-img_0138.jpg
  93. #293
    Hi everyone!
    Here comes my just-built Alfine 11 Kona explosif :-)
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-kona01.jpg
  94. #294
    Blown Sturmey Archer 8 Speed
    Hello everyone. This is my first post. Attached is my recently built winter bike with a Sturmey Archer 8 speed with drum brake rear, and SA drum brake generator front hub.
    There is bad news however. After 125 miles of riding, I blew the rear hub. I have ridden around 10,000 miles with bar end shifters on a touring bike. The Sturmey Archer was the first grip shifter riding experience for me. I was balancing the bike while standing still at a stop sign. I forgot to down shift. Before putting my feet down, the driver of the Suv let me take off. I was in fourth or fifth when I took off. I put anough torque on the crank that the hub spun out. I could feel the inside spin. Has any of you heard of this before? Would appreciate any input.
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-2011-11-25-15.10.18.jpg
  95. #295
    looks like your chainring is too small - the gear you are in shouldn't matter, but the ring and sprocket size does. What are you running?
  96. #296
    I think the SA hubs are geared way higher than most. They have no underdrive gears, ie, the lowest gear is 1:1, hence the small chainring.
    Am I right?
  97. #297
    A Man Of The Truth
    If my IGH's lowest ratio was a 1:1, I'd be running a road cassette in the FRONT and a big ring on my HUB.
  98. #298
    yeah, I don't know anytihing about the SA but in general IGH's lack low gearing. Rohloff is the only one to my knowledge commercially available. Gearing low will break things.
  99. #299
    Jan 2009
    Quote Originally Posted by finch2 View Post
    Looks like he's running SA cranks too, so the ratio should be "legal". Yes, 1st gear is 1:1 and it's all overdrive from there.
    I would think you should be more than fine for a commuter though. Hopefully SA will give you a new one.
    I don't have a lot of torque filled miles on mine, but I had researched they weren't known for their robustness... although the newer (W) version was supposed to be stronger.
    Here's mine: Internal Hub MTBs, post yours here!
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
  100. #300
    Sturmey 8
    I am running 30 chain, 25 rear cog at Sturmey's recommendations. My LBS is waiting for a return phone call from SA come the beginning of the year. I am anticipating being able to replace the internals.
    My bike machanic seems to think there may be a chance of switching from the SA grip shifter to a trigger shifter as well, even though SA doesn't make a trigger shifter.
    I'll post an update in January,
