Page 20 of 23 FirstFirst ... 10 16 17 18 19 20 21 22 23 LastLast
Results 476 to 500 of 567
  1. #476
    Reputation: biketuna's Avatar
    hey sriracha looks good. what kind of chain tensioner is that?
    _______________
    1x10 IS SO FINE on my 21.9 lbs IBIS SL-R
    11-36 XTR in the rear, 36T wide-narrow upfront
  2. #477
    rollin
    Reputation: sriracha's Avatar
    Quote Originally Posted by biketuna View Post
    It's a homemade chain tensioner, that I prototyped and built it in my garage.
    Want one? I am in conversation with a machine shop about doing a limited run.
  3. #478
    I might need one for a future project. I don't like the rear derailleur type.
    Does it move? Do you have more pics?
    _______________
  4. #479
    Feb 2006
    I am interested in the tensioner as well. Will it attach to a standard frame?
    I have a Moonlander.
    d
  5. #480
    will rant for food
    Yo synthesis (fellow fatty rider here), if you have a Moonlander, why not just use the horizontal "dropouts"?
  6. #481
    Feb 2006
    Quote Originally Posted by Drew Diller View Post
    Honestly Drew,
    The shop that built it recomended it. Said it would be easier to change wheel or swap rear cogs. So I am running a Paul unit now. Maybe I'll take it off and see how she runs.
    d
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-ml-c2.jpg
  7. #482
    rollin
    The version I have created currently only works on bikes with elevated chainstays, as it pushes the chain up.
    I will eventually work on a version that pushes the chain down.
    My chain tensioner attaches to a standard bottom bracket, the same way a chain guide with rollers would attach, by being sandwiched between the BB and frame.
  8. #483
    Jan 2011
  9. #484
    rollin
    Quote Originally Posted by rekrutacja View Post
    ^^^Nice looking chain tensioner! Looks like it might be reversible by switching the springs. I also like the giant bearing used. My tensioner uses a brass bushing.
  10. #485
    Carver 96er Alfine 11
    Here's my Carver 96er Alfine 11.........apologises about the goofy pose!
    EBB is good, running a 1/8" single speed chain, 32/23.
    The Alfine 11 is still a bit jumpy, but it is getting better.
    In my quest to improve slipping in addition to playing with the tension and cable length I switched to seat stay cable routing (from chain stay) using Bue / Green non-turn washers plus I flipped the cog's dishing inwards (to avoid the rubber cable housing rubbing the wider 1/8 chain).
  11. #486
    dru
    dru is offline
    You poor bastard! Where are you that you still have snow?
    Drew
    occasional cyclist
  12. #487
    Quote Originally Posted by dru View Post
    Drew
    Old'ish photo taken on the 17-March-2013 on Dartmoor in the U.K.
    I just got back from a business trip to Madrid and took the photo to wind up a Spanish cycling colleague who cycles in the sunshine near Barcelcona,
  13. #488
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Finally got an 8sp Alfine hub on the Coco, added 3 lbs to the ss weight but I am spinning up climbs I had to walk before.
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-coconino8sp.jpg
    I ride with the best people.
  14. #489
    Unhinged Aussie on a 29er
    Reputation: hunter006's Avatar
    Quote Originally Posted by synthesis View Post
    Honestly Drew,
    d
    While you're still fiddling with the bike getting ratios right, I highly recommend running a chain tensioner until you sort everything out, just so you don't have to keep adding or removing links. After that, it's a matter of personal taste - I still have mine, but I won't cry myself to sleep when I remove it.
  15. #490
    Feb 2006
    Quote Originally Posted by hunter006 View Post
    I switched to a 23T and got rid of the tensioner. Runs great now and no extra parts to get full of sand and grit. Was worried about the axle slipping in the dropouts but I torqued it to 32lbs (I think it was) and it hasn't budged. Very happy with the setup.
    d
  16. #491
    Trek District Carbon Belt Drive Rohloff Road Bike
    Here is my newest project. A district carbon with a a rohloff and belt drive. There had to be a few very unique solutions to make this possible and im still not done. I am just finishing up a drop shifter that I have been fabricating and then I have to find a more elegant way to route the cables. The front wheel will match the rear, just waiting on my philwood hub. Let me know what you think, or if you have any suggestions. Cheers.
    Internal Hub MTBs, post yours here!-img_20130522_194158.jpgInternal Hub MTBs, post yours here!-img_20130522_194152.jpgInternal Hub MTBs, post yours here!-img_20130522_194024.jpg
  17. #492
    Music & Bikes
    Reputation: fokof's Avatar
    WOW !
    Please report back your impressions.
    Curious about the feeling of the IGH on a road frame and if the extra weight in the back is annoying on a road rig.
    "There is a big difference between kneeling down and bending over" -FZ
  18. #493
    Quote Originally Posted by fokof View Post
    WOW !
    Actually Santos bicycles make a Rohloff road bike.
    Race Lite | Santos - Custombuilt Bicycles
    I just convinced Bill, one of my rando buddies, to add one to his bike. The biggest issue to solve is how to route the cabling for the shifters from the handlebars. I think the Santos solution is the cleanest, nicest solution, however it will probably add resistance to the shifting. It also removes the ability to easily grab the bottom of the drops.
    This district has taken an approach I haven't seen in a while - stem mounted. Nicely done.
  19. #494
    Just Ride!
    Reputation: kustomz's Avatar
    Quote Originally Posted by bsieb View Post
    That is a very nice looking rig! Mind if I ask what the cost of converting was? And also, did you purchase a pre-built Alfine wheel or build yourself? Thanks for any info you can give.
  20. #495
    I tested it out on the weekend, it rides really well! You dont notice any extra weight in the back although when you are in the lower 7 it does have a pretty loud hum. I am running a 60T ring and 19T cog so the hub RPMs are always pretty high.
    @hunter006 thanks . . . The stem shifter is a temporary fix though. I have modified a campy chorus(campy uses a duel ratchet system so when modified can pull 2 cables) shifter to pull the cables. . im just putting the finishing touches on it and ill get it installed.
  21. #496
    Quote Originally Posted by justilew View Post
    Great build! I would like to try Rohloff on road bike, and the belt makes a super clean bike!
    What is the weight?
  22. #497
    ...and please post some nice outdoor photos!
  23. #498
    saddlemeat
    Aug 2003
    Quote Originally Posted by kustomz View Post
    I had to shop around for my components, there seemed to be a shortage last winter. I have ~$275 in the hub, shifter, small parts kit, and cog. The rim, spokes, nipples, and tubeless liner were ~$175. I built the wheel myself, used the same size cog and the same centerlock rotor as I was running ss. My frame was built with cable clamps for this setup, so installation was simple. I set up the disc brake with the bare hub before I built the wheel, pretty much a drop in deal.
    Pacenti TL28 rim w/ Carver tubeless liner
    Wheelsmith black DB14 spokes and aluminum nipples
  24. #499
    Just Ride!
    bsieb, thanks for the details. I am not sure why I am so hung up on an IGH? Especially when my 1x9 Deore works absolutely flawless, but this helps me know that I am on the right track cost wise. Decisions, decisions...
  25. #500
    Hiya. I hope you realise what you have done if you get a brifter working with a Rohloff?!!!! If you can let me know how you did it or do another one, I would buy it from you! There are a LOT of people itching to get their hands on one and NOBODY is making any!
