Page 15 of 23 FirstFirst ... 5 11 12 13 14 15 16 17 18 19 ... LastLast
Results 351 to 375 of 567
  1. #351
    Dec 2011
    Whoa! I had no idea that fork had that kind of tire clearance. One last question, how is the durability / how long have you been running the fork? I think my gf will be getting a new fork soon... much appreciated!
  2. #352
    Gryphon
    I also posted this in the "29er Rigid" pic thread. Enjoy!
    This has been my daily commuter for 2 months now, but I've done the quick switch to offroad mode (remove fenders, rack and 50mm slicks, etc). I've really liked the Nuvinci on the road. Time to give it a proper test.
    Maiden trail ride is tomorrow.
    <Edit> Post ride report. Excellent offroad capabilities! Great climber, fun handling. I look forward to more. I replaced the Brooks B-17N with a 143mm Specialized Phenom Gel - MUCH better!!!!!!!!!!!!!
    The clearance with 2.4 Ardents. Not bad.
  3. #353
    Reputation: larryarroyo's Avatar
    Mar 2012
    Love the bikes, mine is a single speed 18t 29er. Do I need a new spokes to build a rear wheel with alfine8 using my existing wheel..Advice is much appreciated....
  4. #354
    Quote Originally Posted by larryarroyo View Post
    Most probably yes, unless your current hub is the same size as the Alfine 8, and even if it is, a new wheel build can always benefit from a new set of spokes.
  5. #355
    It is generally a good idea to use new spokes, unless the old wheel is relatively new.
    The Alfine has a much larger flange than most regular hubs, so (if the existing spokes are newish) they could be cut to the appropriate length. This also assumes that the spokes, if butted, have enough space on the end to allow the new threads to be cut without hitting the shoulder of the butted section.
    Add to these considerations that most bike shops have forgotten the art of spoke cutting (fairly easy to do with a Phil Wood machine and skilled user), so they charge for the inconvenience - sometimes more than the cost of new spokes.
    Yeah, go with new spokes.
    If you are new to wheel building, it would be best to have a reputable shop assist you with determining the spoke length, given your hub specs, rim, and desired cross patern (you can go 3x with an Alfine and 29er rim).
  6. #356
    Mar 2012
    Quote Originally Posted by canyoneagle View Post
    The existing wheels are new, what spoke size should i get to match with a 29er rim and 3x pattern? Thanks again...
  7. #357
    Mar 2012
    Quote Originally Posted by EFMax View Post
    Thanks, now i need to figure out what size of spokes should i get for alfine8 hub and 29er rim..
  8. #358
    Awesome!
    Here's what you'll need:
    Hub specs: Shimano Alfine SG-S500 (8-spd) 135mm Rear hub dimensions | Freespoke | Freespoke
    Rim ERD: While all "29er" rims will have the same bead diameter (622), they will vary in "ERD", which relates to the diameter where the nipples will sit. Google your rim name + ERD and see what comes up. This is also (sometimes) on the rim label. Your rim might be listed here
    Number of spokes: 32 or 36 - MAKE SURE YOUR RIM AND HUB HAVE THE SAME NUMBER OF HOLES
    Cross pattern: 3x
    Nipple length: Unless you are using something unusual, this will probably be 12mm
    There are a number of online spoke calculators - I always use 2 or 3 and average the results if they are close. The ones I use:
    Freespoke - only if your rim and hub are listed (select them in the tabs)
    Welcome - select "anonymous usage"
    Spoke Length Calculator
    If you will be re-cutting the existing spokes, measure them to the base of the threads and ensure that this is at least as long as your calculated spoke length.
    If you go this route, you will need to find a shop that cuts spokes (not all do), so I highly recommend that you have them verify your calculation. If you get it wrong, your build will not happen.
    Ask the shop what they charge. If it is more than 30-40 cents per spoke, you may as well buy new ones.
    Best of luck to you!!!!! I look forward to seeing your project come together.
  9. #359
    Man, that is really helpful. Good on ya!
  10. #360
    Mar 2012
    Yes, really helpful. Thanks again...
  11. #361
    Quote Originally Posted by jonnybags View Post
    Glad to help!
    By no means do I consider myself an expert - I'm a hobbyist when it comes to building wheels.
    Rep is certainly appreciated if you've found it helpful, but it was not my intent to fish rep.
  12. #362
    Reputation: Corporal Punishment's Avatar
    Nice writeup! When I built my alfine wheel, I bought a bag of 50 spokes that cost way too much. I couldn't find them online any cheaper. Later someone sent me this link:
    DAN'S COMP - Bmx Bikes, Bmx Parts, Bmx Clothing, Bmx Shoes and Bmx Accessories!
    They sell spokes individually and the price is great. Make sure you order a couple of extra ones JUST IN CASE. I like the double butted ones. If you want, buy some colored nipples also to spice up the build.
    One other thing - the spoke length for left and right side will be different - but very close - on the calculator. You can buy one size for both sides. Just split the difference between left and right. I think its less than 2 mm and any slack that small can be taken up by the nipple. The taller the wheel, the less of a difference there will be (calculated).
  13. #363
    Quote Originally Posted by Corporal Punishment View Post
    This is in line with what I found on my Alfine builds (I'[ve only built two). The flanges are pretty close to the same dimension from centerline. When I laced the wheels, I just left one side (the non-drive side with longer spokes) with 3-4 threads showing and snugged the drive side to the point where the threads just tucked into the nipple. That got me pretty close, and made the initial tensioning easier.
    I've typically bought my spokes/nipples from Universal cycles (DT Swiss and Wheelsmith).
    Rightly or wrongly (I blame Gerd Schraner ), I am in the habit of using spoke washers for my wheels, unless the dry fit is REALLY nice and the elbows are snug against the flange.
  14. #364
    Coconino Rohloff
    This bike rides great. I am impressed with how well the Rohloff is working. Have to get used to shifting down under load, but otherwise the noise is less than I expected.
    Attached Thumbnails Attached Thumbnails Internal Hub MTBs, post yours here!-lumix-060.jpg
  15. #365
    A Man Of The Truth
    Reputation: fellsbiker's Avatar
    I just got my 4th Alfine 11 back and it failed after ~3 hours of riding. Shimano either sent me back my original failed hub, or these hubs are only suitable for grandmothers riding bikes along paved rail trails. This hub's second gear is completely junk. Any pressure at all and it skips bad. This is just what my first Alfine 11 did, but it only started after 2 months of riding. #4 started after 3 hours of riding. I highly doubt I'm going to get my $900 back and right now I don't have a rideable bike. I'm ****ed.
  16. #366
    A Man Of The Truth
    The shop I bought it through has been handling everything. Plus why would I go to the UK boss?
    #1 - lost 2nd gear
    #2 - oil leak
    #3 - didn't run smoothly (shop returned it right away, I never road this one)
    #4 - lost second hear
    This hub sure does work great WHEN IT WORKs.
    I wish Rholoff would update their shifter to an XT style trigger shifter. I'd install that and be done with it.
    At this point, I'm looking at riding a singlespeed for a solid half of my season, by the time shimano/this bike shop gets me a bike that WORKS.
  17. #367
    Man, that sounds awful. Have you tried going to the UK boss of shimano?
  18. #368
    Oops sorry, your user name has fells in it and there are fells in the UK....anyhoo..... Have a search for the contact details of the shimano boss in your country and tell them what's happenned.....they hate bad press! And I've heard they are a really good hub.
    As far as Rohloff goes, Mittelmeyer (a small engineering firm in Germany) should be bringing a thumb shifter out in September - by which time the Rohloff you buy should be worn in ;-)
  19. #369
    Quote Originally Posted by fellsbiker View Post
    #1 - lost 2nd gear
    #2 - oil leak
    Wow. That really sucks. I've been following your "adventure" here. That's just crazy.
    There haven't been too many complaints like yours for the 11. I beat the crap out of my 8. I know they're different. I'm wondering if you just haven't been the recipient of some really, really bad luck.
  20. #370
    Music & Bikes
    Reputation: fokof's Avatar
    "There is a big difference between kneeling down and bending over" -FZ
  21. #371
    Music & Bikes
    Hey Fellsbiker , you should start a new thread , lots of people would benefit from reading that and it's not obvious to find that kind of info in a "show your bike" thread.
    Shimano doesn't suggest to use Alfine ( 8 or 11) off road.
    They are found under "pavement" section.
    Alfine
    You can buy a Honda Civic and use it off road but I don't know how long it will last.
  22. #372
    Quote Originally Posted by fokof View Post
    That's not really a fair analogy. If a certain riding style - standing on the pedals, shifting under load, etc - are the real contributors to alfine hub failure then they should fail just as easily on the road as the trail. To me, it sounds like fellsbiker had bad luck with multiple manufacturing defects. Especially his #2 and #3 hubs. Its a fair question to ask whether shimano has any kind of quality control on their new 11 speeds, but in my own experience and looking around the IGH forum here, the 8 speed is pretty mature and holds up well as long as you shift "properly".
    I'm a year into my 8 speed ownership and I stand on the pedals all the time, huck 3' drops and generally ride the wheels off my bike on the trail but I'm also very conscious of how I shift. No problems yet [knock on wood! ]
    I hope fellsbiker chimes in about his riding/pedaling/shifting style. The general consensus here on the board is that shifting should be gentle and I think that advice bares out pretty well.
  23. #373
    A Man Of The Truth
    There is a delay shifting on a derailer vs an IGH. Plus a derailer shifts when you release the lever, an IGH shifts when you push the lever. So there was a leaning curve on my first hub. And it is possible that that learning curve is what messed up that hub. But these days, I'm a pro at shifting. My timing is perfect. I shift between pedal stroke perfectly. Yesterdays skip happened nowhere near a shift. I put it in second, went to pedal up a hill and it skipped violently, then went a little crazy for the next half hour. I do stand up and pedal constantly. I'm a mountain biker, that's how you mountain bike. So I would say without a doubt, #2, #3 and #4 were defective. #1... impossible to say for sure. If I did accidentally shift while pedaling, I would get off the pressure, I wouldn't just keep on grinding it out like some people do with derailers when they're trying to shift while climbing a hill.
    What is seems like to me, especially after googling it, is that the 2nd gear in the Alfine 11 is very weak. I think that they break easily, and I think that's what has happened to me twice. after I got home last night, I did a little street ride to figure things out and 2nd gear works until you put pressure on it, then it slips right out and grinds violently. And I suspect every grind makes things worse. Thats what happened with my first hub. I kept riding and it would skip hard when I was in second gear trying to climb. It got worse and worse until it got to the point where it wouldn't take ANY pressure at all in 2nd, and I had to go 1 to 3 every time i shifted.
    So all I can really afford to do now (and I mean that literally $$) hope they replace it again, and hope that #5 is a rare and unusually strong hub. #2 was nice and solid, it just leaked all it's oil.
  24. #374
    A Man Of The Truth
    Another simple solution here is that they use refurbished hubs was warranty replacements, and their refurbishment process is ****.
  25. #375
    Firstly, as a disclaimer, I have a rohloff. Secondly, it seems you are jinxed in some unholy way. However you manage to get your hub replaced or refunded, could you sell it and go for something different, such as an 8 speed or stump up the extra cash for the Rohloff (i know they aren't perfect and there are occasional dodgy ones - but their customer service seems sh*t hot and they are fairly bulletproof)
