Results 1 to 14 of 14
    How much power will an Alfine handle?
    I am sure I will be bashed for doing this, but I am looking to build an electric bike that uses the Alfine 8-speed hub. Does anyone know what kind of power these hubs can take? I was hoping for 4 kw. Thanks -David
    Long answer
    Power isn't the only number you should be looking at. Torque is going to be the most important number. Internally geared hubs typically have a minimum gear ratio to limit the torque on the hub. That minimum gear is typically picked based on the max power that humans can output (or more to be safe).
    This is totally speculation, but I'd guess that they're probably designing the hub to take around 1500 watts being applied at slow rpms (standing on the pedals) and therefore fairly high torque values. If you up the rpms (as I assume you will), you can probably get away with higher power numbers.
    That leads to the next problem: the hubs aren't designed to take any higher rpms than a cyclist can produce. That's not to say that they won't, but you may be the first to try it.
    All that being said, it's unlikely that you'll take off and have the hub explode. Many people on this forum are pushing the limits of what these hubs are made to do and are getting away with it for some period of time. Some people never have any problems. If you do end up running 4kw through a Nexus, I wouldn't expect it to work forever.
    Have you looked at the Nuvinci CVT hub? Staton motors has been using these hubs with gasoline engines for a year or two now, so one would assume that they're handling the stress.
    I hope I've been some help. Good luck with your project!
    Eddicycle,
    Thanks for your response. I think I will skip the Alfine in favor of the cassette for now. Once it wears out, I might try the Alfine or its replacement at the time. Thanks again, -David.
    Compressorman
    Quote Originally Posted by damcard
    Eddicycle,
    I would love to see you try this, I've been thinking the same thing for some time, but not with anything near 4 kw. What motor and batteries do you plan to use?
    JW
    I have a fair bit of experience with the NuVinci. I have built two motor assisted dual-suspension MTBs using the Nuvinci, with a Staton reduction gearbox, and a Robin 33cc 4-stroke engine, rated at 1.6HP, though it is nearer to 1.2HP in the real world. You won't damage the NuVinci with human power alone, or with the Robin engine alone. However, my mate and I use the bikes for serious off road use on inclines that require human and engine power together,and we have both damaged our hubs by applying excessive torque.
    I spoke to the NuVinci engineers about the torque limitation for these hubs. In the case of the NuVinci CVT, the clamping force on the drive balls (required to stop the balls slipping) is proportional to the input torque. If the input torque is excessive, the clamping force becomes so great that the surface of the balls becomes permanently flattened. If this happens, the drive becomes really "rough" due to the flat spots on the balls - sound painful, doesn't it! This is different to a geared hub, where a large torque will either do no harm, or else cause catastrophic damage due to tooth or shaft breakage.
    NuVinci gives a maximum torque specification for these hubs - look on their website and find the specs. Note that the maximum torque rating is referred to the INPUT shaft, not the output, because the clamping mechanism is driven from the input.
    It should be a simple matter to calculate whether your emotor will exceed the NuVinci input torque rating. Which motor are you thinking of using?
    Rohloff also give a max torque spec for their geared hub, which from memory is similar to the NuVinci. However, I suspect that in the real world the Rohloff can handle more torque. I say this because a number of very fit people have successfully used the Rohloff on off-road tandems, and from my experience I am fairly sure the NuVinci would not handle the power output of two fit people.
    I'm not knocking the NuVinci though. It definitely performs to spec, and with a little restraint and common sense I have not damaged my second hub, with the combined power of myself and the petrol engine.
    I am very interested in hearing people's experience with all types of geared hubs, in torque-abusive applications such as tandems or motor assist. For me, I would prefer the lighter weight and higher efficiency of a geared hub, compared to the NuVinci, if a geared hub was available that could handle my torque requirement.
    Colin
    Reputation: itsdoable's Avatar
    NuVinci CVT is not rated for tandems, but...
    ...what fun would there be if we always followed the rules.
    However:
    technically it's not a tandem...
    BTW: Rohloffs are rated for tandem use, even for a fit team.
    Quote Originally Posted by itsdoable
    However:
    OK, um, that kicks ass.
    It's torque that kills gearboxs (which is what an Alfine hub is essentially) not power.
    Bear in mind that a strong cyclist is capable of producing as much torque through their legs as a small to medium sized car engine (yeah seriously!), but the cyclist only delivers it at say a maximum of 100rpm. Most car engines rev to 6000rpm or more, hence they produce a LOT more power. Without going too far into the maths, take something like a Toyota Yaris with a 1 litre engine, which produces circa 90 Newton Metres of torque (easily within the realms of possibilty for a strong cyclist to produce), but circa 48KW of power at approaching 6000rpm.
    As power is a product of Torque x RPM, you can see how the car engine produces its power... Via high revs! By comparison the cyclist would producing circa 800 Watts ((48KW/6000RPM)*100rpm) at 100rpm.
    Anyway, to cut a long story short... What RPM does the electric motor in the bike produce 4KW at? If you can find out the RPM, you can work out the torque of the motor. I'd hazard a guess, but I reckon the 4KW electric motor doesn't produce as much torque as an average cyclist, it will produce it's high power figure via high RPM like a car engine. Personally, I'd be inclined to give an Alfine hub a go on an electric bike! If you do, let us know how it goes...
    On MTBR hiatus :(
    <img src="http://gallery.mtbr.com/data/mtbr/500/Stickel_Tandem29_NuVinci_hub.JPG" width=400>
    Ok, I've been absent from the forums for a while, so what happened here? Got a link to another thread? How'd you jump from the Speedhub to the NuVinci? How's the shifting action on that thing? Lots of twisting? More pics?
    speedub.nate
    MTBR Hiatus UFN
    Reputation: andrepsz's Avatar
    Jan 2013
    Alright lets see if this works...trying to bring this thread from the ashes.
    I'm interested to know this by a lot. Does anyone know if the latest Alfine 11 "with improved internals" can handle more torque compared to older versions? I AM converting my XC MTB with the 11sp Di2 version in the near future, but this question on the max torque always cross my mind. No its not an electric bike, its human powered.
    Reputation: Velobike's Avatar
    Quote Originally Posted by andrepsz View Post
    The 11 speed Alfine seems quite delicate compared to its 8 speed. You shouldn't gear it lower so it' s probably the same max input requirement.
    But if you have an electric motor, why do you need gears? The motor doesn't need them.
    Latitude: 5736' Highlands, Scotland
    Dec 2011
    Quote Originally Posted by Velobike View Post
    At InterBike last September, all the bikes I saw that didn't have derailleur-based drivetrains were equipped with continuously-variable hubs (NuVinci), which apparently were able to handle the necessary torque.
    More InterBike observations: I don't remember seeing any e-bikes that didn't use some sort of transmission (possible exception: the GeoOrbital; maybe others I missed). The Tern GSD ("cargo-capable") bike I rode to the show had a derailleur. Electric motors generate their maximum torque from zero RPM and at some point it begins to drop off (https://evmc2.wordpress.com/2014/07/...nd-hp-ratings/). I'm guessing the transmission keeps the torque in a more useful range.
    Steve
    May 2015
    I believe the newer alfine models sg 7001-8 and sg 7001-11 have had slight changes to there internals in order handle increased torque as according to the shimano page they are both listed as suitable for normal and e-bike use now.
    I assume this would also mean that you could gear these newer hubs lower for normal use then what was once recommended with less chance of issue.
    Of course there seems lots of people have geared older models quite low with out issue as well.
    So in answer to one of the people above the newer 11speed hub should be able to handle more torque when used in an non e-bike.
    Oct 2016
    I'm currently running an Di2 11 speed on my commuter bike, and my gear ratio is about 1.7, which is lower than the recommended ratio for these things. I weight in at 230 lbs, carry panniers from time to time and climb some pretty steep hills with this thing. I do find that first gear can handle some pretty good torque, but once I get past that I don't really hammer it too hard. I've been running it year round for a year and it's pretty good. It did pop out of gear on me a couple times when I first got it, but that's just getting used to the shifting. I'm ready to put the 8 speed on a mountain bike. There are guys who run the 8 speed with a 32/23 chainring/cog combo, which is way below the recommendation, but it works for them. I'm going with a 32 chainring and a 22 cog. I can wait to get it going.
